[Recensione] Mount&Blade: Warband
Pagina 15 di 18
... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ultimo
Visualizzazione dei risultati da 141 a 150 su 173
  1. #141
    byte L'avatar di jab
    Oct 2010
    ...E' uscita una nuova versione per la mod multiplayer NORDINVASION:...
    New Features:
    Huge armor re-balance!
    A lot of armors have had their stats adjusted and have been moved around between the different class tiers. This will hopefully make the different classes stand more apart in the fashion department. Every tier you unlock new armor the armors have been given flat stats as well, so you can freely choose between different looks without taking a hit to stats!
    Archers have had their overall armor values decreased and Cavalry has been put in the middle of Infantry and Archers armor wise.
    Archers have received small damage boost on arrows for every class tier. And quite a decent damage boost at the Sniper tier.
    Horses now have lower speed and maneuver across the board. Heavy horses has gained some armor and hitpoints. All lances have received damage boosts.
    Commando tier shields have received a significant armor and hitpoint boost to withstand hardmode better.
    More crafting!!!
    As some of you might have noticed some strange and foreign crafting blueprints have started to show up over the last few days. With this patch we are adding a large amount of new items that will be made available over the coming days as craftables for every crafting profession.
    Hardmode now drops materials you can only get your hands on there and are required for even better items then has ever before been crafted in all Swadia!
    Old blueprints have been re-balanced to be more useful and will over the coming days have their requirements reduced to make them available for newer players.
    New materials available in the goods section of the market place
    New quests
    You might have already noticed we have put in a handful new quests lately, some specifically aimed at making the the entry into the Swadian ranks abit easier for recruits, some for the veteran soldier fighting in hardmode.
    Keep your eyes open for more quests to come!
    Fixes!
    Hardmode as been toned down abit more.
    All weapons not giving experience and gold rewards should now be fixed.
    Ammo Boxes for Tinkerer are back again
    New map!!!
    New stunning map by Freddex, Old Lake town!
    N.B.:...qui trovate la notizia sul forum ufficiale:...
    Client Release 0.3.2 - Fashionable Fighting
    ciauz^^,
    Jab
    @Jabdimelborn
  2. #142
    Oct 2010
    ...Aggiunte nuove immagini per la fantastica mod in lavorazione sul mondo di Warhammer:...
    REMAKE of Elite Marauder of Norsca:
    N.B.:...qui trovate il forum ufficiale da cui ho tratto le immagini:....
    Taleworlds Forum: daily database backup in progress...
    ciauz^^,
    Jab
    @Jabdimelborn
  3. #143
    byte L'avatar di Sebastian
    Feb 2012
    Pianezza(TO)
    Beh che dire... GG ^^
  4. #144
    Oct 2010
    Originariamente inviato da Sebastian
    ...Grazie...-_^
    ciauz^^,
    Jab
    @Jabdimelborn
  5. #145
    Oct 2010
    ...Grazie alla segnalazione di TurambarMakart eccovi un breve video da cui si intravedono spezzoni di un gioco simile a Warband con grafica migliorata:...
    ANADOLU AJANSI
    ...presumibilmente M&B2...-_^
    N.B.:...faccio notare che questa notizia e' nata da forum Taleworlds tramite la segnalazione di un'utente captain lust e non da un'annuncio ufficiale della Taleworlds, anzi era apparso un video intitolato "M&B 2 alpha (in game)" oggi oscurato...
    ciauz^^,
    Jab
    @Jabdimelborn
  6. #146
    Oct 2010
    ...Oggi sono venuto a conoscenza di questa mod "multiplayer" per M&B Warband, nata dagli stessi autori e sulle ceneri di "M&B with Fire and Sword" (la mod non il nuovo titolo Taleworlds !), mod di vecchia data, molto conosciuta all'interno della communtity della TaleWorlds...
    ...qui sotto ho cercato, con l'aiuto di Google Translate di tradurne la parte descrittiva in italiano...
    ...ho cercato di sistemarla alla meglio, quindi considerate che non avra' una dizione perfetta:...
    (Solo Multiplayer)
    Il Diluvio è una mod che ci porta nelle guerre crudeli e sanguinose del 17° secolo in Europa orientale. Ti verrà data la possibilità di giocare come i vari personaggi di questi conflitti: un imbattuto ussari alato che combatte nei ranghi polacco-lituani del Commonwealth, e coraggiosi ribelli Cosacchi, un Ottomano ambizioso, Tartari selvaggi e indipendente e un attrezzato Svedese. Inoltre, altre fazioni sono state considerate, come lo Zarismo di Mosca, l'Austria e la Germania...
    A seconda del periodo temporale cambieranno le impostazioni e le fazioni ; le armature e armi non sono le uniche cose che la nostra mod ha da offrire. In Deluge' troverai enormi quantità di cambiamenti che renderanno la vostra esperienza di gioco "magica". Abbiamo aggiunto tonnellate di nuove caratteristiche - alcune sono grandi, alcune sono piuttosto piccoli - molte dei quali sono uniche e non le troverete in nessun altra mod.
    Fazioni giocabili:
    Invasion - nuova modalita' di gioco
    Ti piace affrontare innumerevoli lotte disperate contro orde di soldati nemici? Ti piace combattere insieme ai tuoi fratelli-in-armi, facendo del vostro meglio per sopravvivere pochi minuti in più e proteggere i vostri compagni? Se sì, allora questa modalita' fa per te.
    Le Regole di Invasion sono semplici - un gruppo di giocatori si riuniscono in una squadra e cercare di difendere la loro posizione contro orde di nemici bot, sopravvivendo piu' a lungo possibile. Ciò richiederà un sacco di gioco di squadra e di pianificazione. Il concetto principale è abbastanza simillare alle mods Invasion gia' presenti o uscite in passato, ma la meccanica e le caratteristiche sono diverse. Cosa c'è di più ? "The Deluge" introduce una "AI bot scripting" che rendono i nemici meno stupidi di quanto normalmente siano in M​​&B e li fa interagire con ambiente in qualche modo (es. cercheranno di distruggere la porta se i giocatori si nascondono in una stanza chiusa a chiave). Quindi meglio prepararsi per alcuni scontri epici...
    Cannoni
    "Il Diluvio" introduce il sistema avanzato di cannone. Supporta diversi tipi di cannoni di varia potenza e portata, che può essere caricato con due tipi di munizioni - e palle di cannone grapeshots. Palle di cannone sono utili quando intervengono i nemici a lunga distanza e per la distruzione dell'ambiente. Grapeshots sono inutili per il combattimento a lunga distanza e il poco danno alle strutture, tuttavia, a causa sparando proiettili e la loro diffusione più ampia, sono davvero letali a distanza ravvicinata. Un colpo di questo tipo può abbattere un intero gruppo di nemici.
    Barche e traghetti
    In "Il Diluvio" barche sono completamente controllate dai giocatori. Letterali, si può navigare dove vuoi ... fino a quando resterai sull'acqua, ofcourse. Attenzione però, poiché la gente in barca può essere un Sharpshooters facile per pregare o anche di artiglieria nemica. Colpo di cannone ben posizionata può affondare una barca insieme a tutti gli uomini a bordo.
    I traghetti sono molto più sicuro di prendere e possono fare buone posizioni difensive a volte. Non sono così mobili come barche e il loro movimento è limitata da corde, in modo che possano navigare solo in due direzioni - da un fiume / lago bancario ad un altro.
    Difese
    Mentre debole in combattimento diretto, ingegnere può essere l'angelo custode ai suoi compagni di squadra. Grazie alle sue uniche abillities per riparare, scavare e costruire (e distruggere) roba, egli può decidere il destino della battaglia. Si può costruire scudi su ruote, che può essere spinta verso il nemico e proteggere le truppe amiche dal fuoco nemico. Si può riparare cannoni rotti, si può facilmente distruggere le strutture nemiche in legno con la sua ascia potente. Egli può anche usare la pala per scavare su alcuni cumuli, che possono essere usate come una copertura provvisoria.
    Mappe e Architettura
    Azione di "The Deluge" si svolge in ambiente molto diverso da Warband. Pertanto, si può aspettare di vedere un sacco di nuove strutture create per il mod. La sensazione del mondo hanno bisogno di essere cambiato, per cui sarebbe un aspetto molto più simile al XVII secolo. "Il diluvio" artisti grafici realizzati molti nuovi modelli, per rendere questo possibile ed il XVII secolo portare questa visione della vita.
    Polvere nera armi
    In "The Deluge" mod troverete diversi tipi di armi utilizzate in questo periodo di polvere nera della storia. Portiamo non solo i moschetti, archibugi, pesci palla e pistole, ma anche armi unico, secco come tromboni mortali (cui il fuoco multipla Proiettili in una sola volta), doppie pistole a canna e alcune armi combinate, come le spade, pistole, per esempio.
    Armi polvere nera non sarebbe così divertente da usare se non ci fosse un buon suono e gli effetti visivi ad essa collegate. Quindi in "The Deluge" mod vedrete un sacco di nuovi effetti particellari correlate a colpi di proiettili e colpi di fucile, il tutto supportato da questo campioni sonori nuovi. Battaglie da fuoco non sono mai stata spettacolare a secco in M ​​& B, mi creda.
    E se non ti senti come sparare al vostro nemico, si può buttare alcune cose contro di loro. Prendi una mano sulla Granate pochi e inviare un intero gruppo di tuoi nemici in una sola volta direttamente al produttore di loro.
    Nuovi modelli di armi
    Poco parlando, in "The Deluge" mod troverai tonnellate di roba nuova, che può essere usato per uccidere i nemici nel modo che ti piace. Lungo e corto, grandi e piccoli, a punta, schietto e tagliente, pesante e leggero, in mischia ea distanza ... Abbiamo spade, sciabole, le scorte, yatagans, pugnali, tutti i tipi di nuovi archi e frecce, asce, picconi militari, mazze, lance, lance, picche, berdishes, bollette ... et cetera, et cetera. C'è un sacco di che, proprio check it out.
    Arma Resistenza
    "Le cose si fanno danni. Le cose si fanno rotto." Non mi aspettavo di scegliere un ussaro alato, scegli la più lunga lancia poi con noncuranza e senza fine giro intorno la mappa, redatta-pungidito Helpless contadini cosacco, vero? Beh, non è possibile farlo qui. Alcune armi in "The Deluge" hanno durata molto bassa e può rompersi Durante l'attacco, lasciando un inutile pezzo di spazzatura nelle vostre mani.
    Araldica
    Araldica era molto importante nel secolo in Europa XVII, così in "The Deluge" mod nel notevolmente ampliato il suo significato. Noi tutti Warband Sostituito con nuovi banner, quelli storicamente accurati. Il codice nativo fortemente modificati, quindi aggiungere avanzata Araldica Migliorare il sostegno ed è visiva in-game di qualità.
    Meteo e tempo
    In mod "The Deluge" sarete in grado di giocare le mappe multiplayer in diverse condizioni atmosferiche L'e in momenti diversi del giorno (e notte). Non solo cambierà l'effetto visivo, ma richiederà anche una modifica alle vostre tattiche.
    Meteo e tempo può essere modificato da un amministratore o accettato un sondaggio a maggioranza.
    Mondo animato
    World in "The Deluge" non è più statico. Si noterà che l'ambiente intorno a te risponde alle condizioni meteo La forza animata e acording al vento. Tale disposizione si applicherà non solo la flora, ma anche per altre cose, come striscioni, tende o addirittura tende.
    Queste sono solo poche caratteristiche del nostro mod ha da offrire. Scarica, controllarli tutti fuori da soli ... e di incontrarci sul campo di battaglia.
    Home Page:
    http://thedeluge.net/en/
    Tread su Forum Talewolds:
    [M] The Deluge - old thread
    N.B.:...questi attualmente i server attivi per la mod "The Deluge":...
    1_Deluge_Tawerna
    1_Deluge_INV_Tawerna
    ...Buon divertimento...-_^
    ciauz^^,
    Jab
    @Jabdimelborn
  7. #147
    Oct 2010
    ...Negli ultimi giorni sono state rilasciate ben due Patches per NORDINVASION la 0.3.3 e l'ultima 0.3.4...
    New Features:
    0.3.3
    • New support class tiers!
    • New blueprints for Alchemists, make new stronger healing kits for the medics and some proper barricades for the Engineers.
    • 2 New maps
    • Horse nerf redone: The slowdown should now happen more gradually as your horse gets damaged and it stops going down when your horse reaches low health, so it should maintain around the speed of a running player and not a half-dead snail
    • More weapons that where bugged and didn't give experience and gold rewards should be fixed now.
    • Some small weapon fixes (No more stab on Messer )
    • Deployable items now disappear after a round ends.
    • Difficulty has been reduced slightly on higher levels of normal mode.
    • Difficulty slightly reduced across the board on hard mode. Less Rangers!!
    • Number of enemy bots now increases for every player that joins and not at the old set player intervals.
    • And of course all your new custom banners have been added.
    0.3.4
    • Support Classes
    • All tiers of the support classes are now available.
    • 2 new items for the Medic class. Surgeon's kit, only has one charge but fully heals everyone in a large radius and takes a lot less time to use. Resurrection Tome, revives dead players in a large radius and makes them spawn back at spawn.
    • 2 new items for the Engineer class. Heavy Barricades, same health as the Barricade but a lot bigger and total cover against enemy ranged units. Explosive Barrel, kills all enemies within a short radius with a explosion. Downside is you only get one so use it wisely and using it gives no experience, gold or loot.
    • Fixes
    • Minor fixes to some maps. Jeldan Citadel has been taken out.
    • Minor weapon changes, mostly some items have lost the ability to be used on horseback.
    • Horse speed fix should now work as intended.
    • Lessened the default numbers of spawning enemies, especially on hard mode, scaling stays the same.
    • More Rangers!!
    Client Release 0.3.4 - Explosive Resurrection!
    ciauz^^,
    Jab
    @Jabdimelborn
  8. #148
    Oct 2010
    ...Oggi sono usciti i tabelloni con i gironi del Torneo...
    ...la Nazionale italiana dovra vedersela al primo giro con Germania, Yuloslavia, Svezia e Belgio/Olanda...
    ...qui trovate tutti i gruppi mentre devono ancora essere completati gli accoppiamenti delle singole partite:..
    http://forums.talewo...c,218309.0.html
    ciauz^^,
    Jab
    @Jabdimelborn
  9. #149
    Oct 2010
    ...Sono state rilasciate un buon numero di nuove immagini per questa mod in costruzione, sulla nuova classe degli "Empire":...
    Pistolier!
    Part 1
    Part 2
    N.B.:...qui trovate la discussione originale:...
    http://forums.talewo...html#msg5224999
    ciauz^^,
    Jab
    @Jabdimelborn
  10. #150
    Oct 2010
    ...E' da pocco uscita una nuova patch per NORDINVASION la 0.3.5...
    ...quest'ultima apportera' piu' fix per bug e bilanciamenti dei mob che vere e propie novita'...
    Changelog:
    • Default numbers of bots spawning has been decreased on both normal and hard mode.
    • Boss minions spawning has been decreased.
    • Hard mode troops have been nerfed again.
    • Barricades and Heavy Barricades now have more hit points.
    • Change to horse speed reduction and horse healing, should hopefully not bug out anymore after horse has been healed.
    • Map fixes.
    http://forum.nordinv...pic,1659.0.html
    ciauz^^,
    Jab
    @Jabdimelborn
Pagina 15 di 18
  1. Recensione Scythe KamaBay Amp SDA-1000 - [NEWS]
    By pippo369 in forum -= Alta Fedeltà =-
  2. Risposte: 0
  3. Recensione Black Ice Gts 240 & 360
    By vkbms in forum -= Water Cooling =-
    Risposte: 16
  4. mount fat 32 con linux suse 7.1
    By mbenecchi in forum -= GNU/Linux e sistemi operativi alternativi =-
