lo scorso 19 agosto è stata rilasciata una nuova versione per l'utile SpeedFan..
v.4.35
released to the public the EXOTICS tab
fixed 120 DPI issue in CONFIGURE dialog
added full support for Areca RAID controllers
greatly improved SCSI support
added support for Abit uGuru 3 (uGuru 2005)
added full support for Intel FB-DIMM temperature readings
added full support for ITE IT8720F
added full support for Andigilog aSC7611
added full support for LM96000 (it was previously detected as LM85B)
added full support for Analog Devices ADT7490
added full support for SMSC SCH5327
fixed Windbond W83766HG hardware monitor detection on some Asus motherboards
improved CPU identification routines
added support for a new revision of the WINBOND W83637HF
added support for WINBOND W83637HF at unusual addresses
added support for Asus F8000 at unusual addresses
added identification of the SMSC SCH5514
added identification of SMSC EMC2300
added ITE IT8718F fifth fan speed reporting
added identification of Analog Devices ADP3228
added identification of ITE IT8512F
added identification of Winbond W83667HG SuperIO chip
identified a new revision of Fintek F71872 hardware monitor subsystem
added preliminary detection of the HECI driver
fixed a bug in SMSC LPC47M172 support code that prevented fan speeds to be properly reported
45nm Intel CPUs with CPUID=0x10676 now use a Tjmax value of either 105C or 90C
added full support for nVidia MCP65 SMBus
added full support for nVidia MCP67 SMBus
added full support for nVidia MCP73 SMBus
added full support for nVidia MCP78S SMBus
added full support for VIA CX700M SMBus
added full support for Intel 82801JIB SMBus
fixed an issue where the Intel SMBus couldn't be accessed and messages like SMBus msg : SMB Error $14 : FAILED (50) were generated
enabled Intel ICH8M-E SMBus device, if needed
enabled 631xESB SMBus, if needed
enabled SMBus on Intel ICH9R, if needed
preliminary detection of AMD CD5536 SMBus
some SMBus addresses on Asus Striker Extreme are no longer scanned
SMBus is no longer scanned at address $2E on DELL XPS710
Tyan S2927 second SMBus is no longer scanned
some addresses on the SMBus of Asus P5NT WS are no longer scanned
some addresses on the SMBus of the Intel DX38BT are no longer scanned
some SMBus addresses are no longer scanned on Asus M2N32-SLI DELUXE
the second nForce SMBus is no longer scanned on FIC AU31
some addresses on the SMBus of Supermicro H8DCE are no longer scanned
added some SMBus scan exclusions for Intel D5400XS
added /NOGIVEIO command line parameter to disable access to giveio.sys
added /NOGEFORCEROM command line switch that will prevent SpeedFan from reading nVidia GeForce ROMs (useful if it takes too much time)
nVidia video BIOS is now stored in a file for later retrieval
fixed an access violation under Win9x with some nVidia video cards
battery status messages are no longer displayed
upon resume, all controlled fans are set to 100% for half a second, then set to their minimum fan speed
added new configuration option SHOWSTATICICON
enabled Intel 6300ESB SMBus if needed
download diretto SpeedFan v.4.35
