PREMETTO CHE NON SONO ESPERTO DI PC QUINDI VI PREGO DI NON USARE TERMINI TROPPO DIFFICILI
ciao sono nuovo e ho un problema da parecchio tempo:
ogni qualvolta gioco a un videogame dopo pochi minuti o mi fa la schermata nera e rimane tipo uno sfasamento ( non saprei come definirlo si vedono i pixel di altri colori)
oppure mi fa schermata blu e mi riavvia il pc... il mio pc è un packard bell easynote tj65
pentium dual core T4400 @2.20 GHz - 4 Gb ram -windows 7-nvidia ge force gt 240m cuda 1gb.
ho fatto il test con Whocrashed ed è venuta sta roba:
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 01/11/2012 08:51:51 GMT your computer crashed
crash dump file: C:\Windows\Minidump\110112-36145-01.dmp
This was probably caused by the following module: nvlddmkm.sys (nvlddmkm+0x119CF8)
Bugcheck code: 0x116 (0xFFFFFA80045E5290, 0xFFFFF8800F31ACF8, 0x0, 0x2)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\nvlddmkm.sys
product: NVIDIA Windows Kernel Mode Driver, Version 258.96
company: NVIDIA Corporation
description: NVIDIA Windows Kernel Mode Driver, Version 258.96
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nvlddmkm.sys (NVIDIA Windows Kernel Mode Driver, Version 258.96 , NVIDIA Corporation).
Google query: NVIDIA Corporation VIDEO_TDR_ERROR
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: nvlddmkm.sys (0xFFFFF8800F31ACF8)
On Wed 31/10/2012 19:48:34 GMT your computer crashed
crash dump file: C:\Windows\Minidump\103112-51651-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80064E34E0, 0xFFFFF8800F378CF8, 0x0, 0x2)
On Wed 31/10/2012 19:04:32 GMT your computer crashed
crash dump file: C:\Windows\Minidump\103112-34710-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8004CCD4E0, 0xFFFFF8800F3FDCF8, 0x0, 0x2)
On Wed 31/10/2012 18:08:37 GMT your computer crashed
crash dump file: C:\Windows\Minidump\103112-43071-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80048D6110, 0xFFFFF8800F37DCF8, 0x0, 0x2)
On Tue 30/10/2012 22:12:59 GMT your computer crashed
crash dump file: C:\Windows\Minidump\103012-63008-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8007B16110, 0xFFFFF8800F34BCF8, 0x0, 0x2)
On Sun 28/10/2012 10:43:19 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102812-39390-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80043394E0, 0xFFFFF8800F3E5CF8, 0x0, 0x2)
On Fri 26/10/2012 20:57:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\102612-57923-01.dmp
Bugcheck code: 0x116 (0xFFFFFA800830E010, 0xFFFFF8800F367CF8, 0x0, 0x2)
On Thu 18/10/2012 20:34:05 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101812-43524-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8003E764E0, 0xFFFFF8800F38FCF8, 0x0, 0x2)
On Tue 16/10/2012 10:35:35 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101612-46207-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8006F7E4E0, 0xFFFFF8800F373CF8, 0x0, 0x2)
On Mon 15/10/2012 13:19:15 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101512-35942-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80072E44E0, 0xFFFFF8800F3E9CF8, 0x0, 0x2)
On Sun 14/10/2012 16:38:42 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101412-37689-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8006BD04E0, 0xFFFFF8800F35ACF8, 0x0, 0x2)
On Sun 14/10/2012 15:39:53 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101412-37955-01.dmp
Bugcheck code: 0x116 (0xFFFFFA80045984E0, 0xFFFFF8800F3ADCF8, 0x0, 0x2)
On Sun 14/10/2012 15:02:54 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101412-53336-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8004CB4010, 0xFFFFF8800F3FFCF8, 0x0, 0x2)
On Wed 10/10/2012 18:43:52 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101012-32151-01.dmp
Bugcheck code: 0x116 (0xFFFFFA8006A3E4E0, 0xFFFFF8800F3B2CF8, 0x0, 0x2)
