Scheda Audio Professionale E-mu 0404 pci
    mebibyte
    Feb 2008
    Valutazione
    0
    Predefinito Scheda Audio Professionale E-mu 0404 pci
    E-MU 0404 PCI
    SCheda Audio Professionale (utilizzata anche negli impanti di registrazione) che non ha bisogno di presentazioni, chi cerca cose del genere sa bene di cosa si tratta.
    Technical Specifications
    General
    Sample Rates: 44.1, 48, 96, 176.4, 192kHz from internal crystal or
    externally supplied clock (no sample rate conversion)
    Bit Depths: 24-bit I/O, 32-bit processing
    PCI Specification:
    - PCI 2.2 Compliant
    - Form Factor: Universal Keyed, Short PCI Card
    - 3.3V I/O, 5V Tolerant
    - PCI Bus-Mastering DMA subsystem reduces CPU usage
    E-MU E-DSP™ 32-bit DSP with 67-bit accumulator (double precision w/
    3 headroom bits)
    Hardware-accelerated, 32-channel mixing, and multi-effects processing
    Zero-latency direct hardware monitoring w/effects
    ASIO 2.0, WDM/MME/DirectSound Drivers
    Anti-Pop speaker protection minimizes noise during power on/off
    Ultra-low jitter, clock subsystem: < 1 ns in PLL mode (44.1kHz,
    Opt. S/PDIF Sync)
    Analog Line Inputs (2)
    Type: DC-coupled, low-noise input circuitry
    A/D converter: PCM1804
    OpAmp: NJM2068
    Level: -10dBV nominal, 6dBV max (unbalanced)
    Frequency Response (20Hz - 20kHz): +0.20/-0.10dB
    Dynamic Range (1kHz, A-weighted): 111dB
    Signal-to-Noise Ratio (A-weighted): 111dB
    THD+N (1kHz at -1dBFS): -100dB (.001%)
    Stereo Crosstalk (1kHz at -1dBFS): < -120dB
    Analog Line Outputs (2)
    Type: low-noise, 3-pole low-pass differential filter
    D/A converter: AK4395
    Frequency Response (20Hz - 20kHz): + 0.05/-0.10dB,
    Dynamic Range (1kHz, A-weighted): 116dB
    Signal-to-Noise Ratio (A-weighted): 116dB
    Stereo Crosstalk (1kHz at -1dBFS): < -109dB
    Digital I/O
    S/PDIF:
    - 2 in/2 out optical or coaxial (transformer coupled)
    - AES/EBU or S/PDIF format (software selectable)
    MIDI:
    - 1 in, 1 out
    Synchronization
    Internal crystal sync at 44.1, 48, 96, 176.4, 192kHz
    External sample rate sync via
    - S/PDIF (opt. or coax 44.1 - 96kHz)
    PREZZO 80€ + Spedizione
    Ultima modifica di Carneo : 24-02-2011 a 02:08
    mebibyte
    Feb 2008
    Valutazione
    0
    up...
    Valutazione
    1 (100%)
    un up per il venditore ...
  1. SCheda Audio Professionale ESI Juli@
    By Carneo in forum -= Multimedia Market : vendite =-
  2. Risposte: 6
  3. Scheda audio professionale per registrazioni
    By cooling in forum -= Alta Fedeltà =-
  4. Scheda Audio professionale
    By Mirk0 in forum -= Alta Fedeltà =-
