Asus P5WDG2-WS Professional [Thread ufficiale]
Pagina 1 di 3 1 2 3 ultimo
    tebibyte L'avatar di amd4ever
    Dec 2005
    Rovigo
    Predefinito Asus P5WDG2-WS Professional [Thread ufficiale]
    Salve a tutti ....
    Mi sembrava doveroso aprire un thread su questa ormai datata ma bella e potente scheda .
    Sono poche ore che ce l'ho sotto mano e da subito si è dimostrata molto stabile e dalle grandi prestazioni.
    Ma veniamo alla presentazione :
    Cpu :
    Intel® Quad-core CPU Ready
    LGA775 socket for Intel® Pentium Processor Extreme Edition / Pentium D / Pentium 4 / Celeron CPU
    Support Intel 65nm, Core™2 Extreme / Core™2 Duo
    Compatible with Intel 06B, 05B/ 05A and 04B/04A processors
    Intel EM64T and Hyper-Threading Technology ready
    * Please update the latest BIOS to support Intel Quad-core CPU
    Chipset :
    North Bridge: Intel 975X (support ATi CrossFire dual Gfx technology)
    South Bridge: Intel ICH7R
    PCI-X Bridge: Intel 6702 PXH
    Front Side Bus
    1066/800 MHz
    Memory :
    4 x DIMM, max. 8GB, DDR2 667/533, ECC and non-ECC un-buffered memory
    Dual channel architecture
    Native DDR2 800 Support
    Expansion Slots :
    2 x PCI-E x 16 slots
    2 x PCI-X
    2 x PCI 2.2
    Storage :
    Intel ICH7R controller supports:
    - 4 x SATA 3.0Gb/s (RAID 0,1,10,5)
    - 1 x UltraDMA 133/100
    Marvell 88SE614x supports:
    - 4 x SATA 3.0Gb/s
    Audio :
    ADI 1988B 8-channel High Definition Audio CODEC
    Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking
    Coaxial, Optical S/PDIF out on back I/O port
    LAN :
    Marvell 88E8052 + 88E8001PCI-E Dual Gb LAN controller
    Support Teaming function
    USB :
    8 x USB 2.0 ports
    Advanced Thermal Design :
    8-Phase Power Design
    Stack Cool 2
    Q-Fan 2
    ASUS Heat-pipe thermal solution
    ASUS AI Lifestyle Features :
    Multi-language BIOS
    SATA on the Go
    AI Nap
    AI Gear
    My Logo 2
    Special Features :
    ASUS AI NOS™
    AI Overclocking
    AI Clock Skew
    ASUS PEG Link
    Hyper Path 3
    ASUS BIOS Profile
    ASUS C.P.R.
    ASUS AI Booster
    Adjustable FSB/DDR2 ratio. Fixed PCI/PCIe frequencies.
    Precision Tweaker:
    - vDIMM: 25-step DRAM voltage control
    - vCore: Adjustable CPU voltage at 0.0125V increment
    - SFS (Stepless Frequency Selection): allowing FSB tuning from 200MHz up to 450MHz at 1MHz increment
    - PCIe x16 Frequency: allowing PCIe x16 frequency from 100MHz up to 150MHz at 1MHz increment
    Other ASUS Special Features :
    ASUS AI NET2
    CrashFree BIOS 3
    EZ Flash 2
    Q-Connector
    ASUS AI Quiet
    TPM (Trusted Platform Module) 1.2 (optional)
    Back Panel I/O Ports :
    Parallel
    PS/2 Keyboard
    PS/2 Mouse
    RJ45
    S/PDIF Out (Coaxial + Optical)
    4 x USB
    eSATA
    Audio I/O
    WLAN antenna jack (Optional)
    Internal I/O Connectors :
    4 x USB
    8-pin ATX+12V power
    24-pin ATX Power connector
    Chassis intrusion
    CPU fan with PWM control
    Chassis fan1 with Q-fan control
    Chassis fan2 with Q-fan control
    PWR fan
    IDE connector
    Floppy disk drive connector
    Serial ATA connectors
    CD audio in
    IEEE 1394a port
    Front panel audio connector
    BIOS :
    8Mb flash ROM, AMI BIOS, Green, PnP, DMI, Wfm2.0, ACPI v2.0a, SMBIOS v 2.3, EZ flash, CrashFree BIOS2
    Manageability :
    WOL by PME, WOR by PME, PXE, AI NET, Chassis Intrusion
    Support CD :
    Drivers
    BIOS flash utility under DOS
    AI Booster
    ASUS PC Probe II
    RAID utility
    Anti virus software
    Adobe Acrobat Reader ver 7.0
    Microsoft Direct X ver 9.0C
    Accessories :
    User's manual
    UltraDMA cable
    FDD cable
    2-port USB module
    2-port 1394a module
    I/O shield
    SATA cable
    SATA power cable
    Form Factor :
    ATX Form Factor, 12"x 9.6"(30.5cm x 24.5cm)
    News :
    Da un paio di mesi è in commercio la nuova versione la 1.03G
    Raccolta Bios ufficiali direttamente dal sito ASUS :
    http://support.asus.com/download/dow...20Professional
    l'ultimo Bios 0803 ( beta )
    http://www.atris.it/files/bios0803.rar
    è un file .RAR ... scompattate e copiate tutto dentro ad un floppy precedentemente formattato con file di sistema .... in modalità dos fate partire INSTALL.BAT e fa tutto lui ....
    secondo me è il migliore attualmente .... risolti molti problemi di compabilità con ram e supporto ufficiale ai nuovi proci ( bus 333 ) ...
    ho notato anche un leggero incremento prestazionale .... e una minore escursione della Vdroop ...
    da provare sicuramente ....
    Driver for Vista 32bit / Vista 64bit : http://support.asus.com/download/dow...20Professional
    p.s. anche qua solito problema di NO DOWNGRADE se si usa AFUDOS 2.20 o EZ flash .... CONSIGLIO DI USARE AFUDOS 2.07
    ( http://www.driverskit.com/freedownlo..._07/15825.html )
    creare un floppy di ms-dos , copiare al suo interno AFUDOS 2.07 + xxxx.rom ( xxxx sta per il bios che si vuole installare )
    e sulla riga di comando digitare :
    a:\afudos /ixxxxxx.rom
    Modifiche :
    Vdroop :
    Vmch :
    Vdimm :
    i voltaggi :
    Vdroop : sembra essere quasi basilare da fare per questa scheda, infatti oltre a downvoltare parecchio
    ( tipo 0.05 / 0.06 ), sotto prime o altro c'è un ulteriore calo di 0.02 ....
    Vdimm : anche il voltaggio ram non è altissimo, c'è un calo di un 0.03 , quindi se settiamo 2.40 ( il max sotto bios )
    ci troviamo con 2.37 in windows ...
    Vmch : preciso, stabile, anche se oltre i 1.80 non si può andare... un peccato visto la bontà della scheda...
    chissà con 2.00V cosa potrebbe fare.... ???
    Si può clokkare in windows usando Clockgen 1.0.5.0 ( http://www.cpuid.com/download/ClockGen.zip )
    Impostare ICS 954123 e mettere il segno di spunta su IGRORE GSB/PCI
    usare MEMSET 3.0 per settare la RAM ( http://rv.page.cegetel.net.perso.ceg...t/MemSet30.zip )
    Infine si può usare CrystalCPUID 4.8.0.305 ( http://www.chip.de/downloads/c1_downloads_13012986.html )
    per cambiare il moltiplicatore in windows
    Test HD :
    dopo aver settato gli hd nel seguente modo :
    ho eseguito HD TACH 3.00 , ed ecco i risultati :
    2x Raptor 74Gb in Raid0 :
    1x Maxtor 160Gb SataII :
    come sempre il South Bridge Intel ICH7R si dimostra lineare e molto stabile anche ad alti Fsb ...
    Dec 2005
    Rovigo
    Ecco fin dove sono riuscito a spingere la mia MB, senza alcuna Vmod , bios 0701 con Vfsb a 1.40 - Vmch 1.80 - Vdimm 2.20
    Vcore 1.60 ( 1.55 reale )
    Configurazione :
    E6700 Es (lappato)
    P5WDG2-WS Prof.
    2x1Gb Cell Shock Pc1000
    XFX 8800 Gtx XXX Edition
    X-fi extreme music
    2x 74Gb Raptor Raid 0
    1x 160Gb Maxtor SataII
    Windows XP prof Sp2 D.U. non ottimizzato
    raffr. liquido con X-R1 + V3 + pompa Eheim ( temp. liquido/ambiente 21° )
    Fsb max ( 470Mhz ) :
    SuperPI1Mb con procio alla max frequenza :
    stessa impostazione ma con Vcore al limite ( 1.70 da bios, però poi scende fino a 1.64 / 1.65 reale ) :
    ( temp. liquido/ambiente 17° )
    Windows XP mezzo ottimizzato by amd4ever
    e un bel 3dmark05 :
    grande Giulietto, bel sistema e bel Topic sulla mobo....
    sempre il solito perfezionista...
    Giostark te sarà molto grato dato che ha la tua stessa mobo...
    Dec 2005
    Rovigo
    ......Giostark te sarà molto grato dato che ha la tua stessa mobo.....
    si lo so .... infatti gli avevo promesso un aiuto ....
    exbibyte L'avatar di lore85bg
    Nov 2005
    Gandino (BG)
    ottima la sorella semi gemella della p5w64...
    ottimi anche i vari screen... e il wallpaper... :-;
    Dec 2005
    Rovigo
    continuo .......
    link comporativa completa : http://www.bjorn3d.com/read_pf.php?cID=1010
    leggermente + prestazionale la sorellina P5W64 WS Prof. in questa prova ....
    Aug 2001
    Provincia di Caserta
    Sta Mobo Mi ingrifa sempre Piu'
    Aug 2001
    Ho visto anke ke c'e' una versione non PROFESSIONAL
    ASUS P5WDG2-WS
    A Parte i Dissi HEAT PIPE mancanti cos'ha di differente?
    http://www.anandtech.com/mb/showdoc.aspx?i=2631
    ciao a tutti, mi confermate che neppure con un beta la mobo supporta i 6850, i nuovi conroe con fsb a 1333? neppure boota?
    pebibyte
    Jun 2005
    uscito 20 minuti fa il bios 0803 che supporta la regolazione dello strap a 1333... lo provo e vi fo' sapere
    ps: pensavo che il sito fosse down come al solito ed invece ecco la sorpresina.. han cambiato qui e li la grafica, a volte pare più rapido, e soprattutto hanno messo il bios che mi interessa...
  1. Asus P5W64 WS Professional [Thread ufficiale]
    By lore85bg in forum -= MotherBoards =-
    Risposte: 535
  2. (TV) Vendo Asus P5WDG2-WS Professional!
    By dj883u2 in forum -= Vendite : Hardware - Software =-
    Risposte: 15
