Asus MAXIMUS EXTREME [thread ufficiale]
Pagina 1 di 33 1 2 3 4 5 6 7 8 9 10 11 ... ultimo
Visualizzazione dei risultati da 1 a 10 su 326
    Nexthardware Staff L'avatar di Leghorn
    Sep 2004
    San Miniato
    Predefinito Asus MAXIMUS EXTREME [thread ufficiale]
    Eccola finalmente la tanto attesa MAXIMUS EXTREME!
    specifiche tecniche:
    CPU LGA775 socket for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 Processors
    Support Intel® next generation 45nm Multi-Core CPU
    Compatible with Intel® 06/05B/05A processors
    Chipset Intel® X38/ICH9R with Intel® Fast Memory Access Technology
    Front Side Bus 1600 / 1333 / 1066 / 800 MHz
    Memory Dual channel memory architecture
    4 x DIMM, max. 8GB, 1800(O.C)/1600(O.C.)/1333/1066, Non-ECC, un-buffered memory
    Support Intel® XMP Technology
    Expansion Slots 3 x PCIe x16 slot, support dual PCIe2.0 x16 or 1x PCIe2.0 x16, dual x8 speed
    2 x PCIe x1, PCIex1_1 (black) is compatible with audio slot
    2 x PCI 2.2
    VGA Support ATI CrossFire™ graphics cards
    Storage Southbridge
    - 6 x SATA 3.0 Gb/s ports
    - Intel Matrix Storage Technology supports RAID 0, 1, 5 and 10
    JMicron® JMB363 PATA and SATA controller
    - 1 x UltraDMA 133/100/66 for up to 2 PATA devices
    - 2 x External SATA 3.0 Gb/s port (SATA On-the-Go)
    LAN Dual Gigabit LAN controllers, both featuring AI NET2
    Support Teaming Technology
    Audio SupremeFX II Audio Card
    - ADI 1988B 8-channel High Definition Audio CODEC
    - Noise Filter
    Coaxial, Optical S/PDIF out at back I/O
    IEEE 1394 2 x 1394a ports(1 port at back I/O, 1 port onboard)
    USB max. 12 USB2.0/1.1 ports(6 ports at mid-board, 6 ports at back panel)
    Overclocking Features Fusion Block System
    Crosslinx Technology
    Extreme Tweaker
    Loadline Calibration
    2-Phase DDR3
    Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Overclocking (intelligent CPU frequency tuner)
    - ASUS AI Booster Utility
    - O.C Profile
    - Frequency LED
    Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
    Special Features LCD Poster
    EL I/O
    Onboard Switches: Power / Reset / Clr CMOS(at rear)
    Q-Connector
    Q-Fan Plus
    ASUS EZ Flash2
    ASUS CrashFree BIOS3
    ASUS MyLogo3
    Back Panel I/O Ports 1 x PS/2 Keyboard port(purple)
    1 x Optical + 1 x Coaxial S/PDIF Output
    2 x External SATA
    2 x LAN (RJ45) port
    6 x USB 2.0/1.1 ports
    1 x IEEE1394a port
    1 x Clr CMOS switch
    Internal I/O Connectors 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
    1 x Floppy disk drive connector
    1 x IDE connector for two devices
    6 x SATA connectors
    8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
    3 x thermal sensor connectors
    1 x IEEE1394a connector
    1 x S/PDIF output connector
    1 x Chassis Intrusion connector
    24-pin ATX Power connector
    8-pin ATX 12V Power connector
    1 x En/Dis-able Clr CMOS
    1 x EL I/O Shield Connector
    System panel connector
    BIOS 16Mb AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.4, ACPI2.0a Multi-Language BIOS
    Manageability WOL by PME, WOR by PME, Chasis Intrusion, PXE
    Accessories Fusion Block System Accessory
    DIY Pedestal
    ASUS Optional Fan
    3 in 1 ASUS Q-Connector it
    UltraDMA 133/100/66 cable
    Floppy disk drive cable
    SATA cables
    SATA power cables
    2-port USB2.0 module+IEEE1394a module
    EL I/O Shield
    Thermal sensor cables
    Cable Ties
    User's manual
    Support Disc The hottest 3D Game: S.T.A.L.K.E.R.
    Support DVD:
    Drivers
    ASUS PC Probe II
    ASUS Update
    ASUS AI SuiteLPRS
    Futuremark ® 3DMark® 06 Advanced Edition
    Kaspersky® Anti-Virus
    Form Factor ATX Form Factor, 12"x 10.6" (30.5cm x 26.9cm)
    bios ufficiali:
    0403
    0601
    0702
    0904
    rewiew by vr-zone
    Sep 2004
    San Miniato
    Alcuni screen del bios.....
    a questo giro Asus non si è proprio risparmiata...neanche sulle dimensioni della scheda
    Sep 2004
    San Miniato
    riservato 2
    sarai mia..
    Bannato L'avatar di Nachthymnen
    Sep 2005
    where dead angel's lie
    Bellissima!!!
    Originariamente inviato da Leghorn
    sarà una bella prova si strada mi sà.. (già una vmod? )
    Sep 2004
    San Miniato
    se ti riferisci a quel filo che si intravede nella foto si tratta del cavetto della microventolina che c'è sul blocco alettato alla sinistra del fusion
    Jan 2006
    Bergamo
    Ed ora Max facci sognare
    Sono veramente curioso di vedere come si comporterà questa motherboard nelle prove su strada!
    kibibyte L'avatar di parcher
    Taranto
    tuned
  1. ASUS MAXIMUS FORMULA [Thread Ufficiale]
    By Hyradus in forum -= MotherBoards =-
    Risposte: 209
