Novità per il chipset X38
    Mar 2006
    Predefinito Novità per il chipset X38
    Intel is currently developing two new technologies which will be introduced along with the upcoming high-end X38 chipset, according to sources at motherboard makers. Both technologies target the enthusiast market.
    The two new technologies are named Extreme Memory and Extreme Tuning Utility. Both new marketing lead architectures will be introduced along with the X38 chipset in October this year, according to motherboard makers.
    Extreme Memory technology will function similar to Nvidia's SLI Memory allowing specially branded and certified memory modules to operate at higher performance levels when installed in a supporting motherboard, said the sources. Extreme Memory technology will only be available for DDR3 modules and will not support DDR2 memory, the sources added. In addition to X38 and P35 chipsets for desktops, the next-generation Intel 3-series notebook Centrino platform will also support Extreme Memory technology, noted the sources.
    Currently, Intel is cooperating with memory makers including Kingston Technology and OCZ Technology Group to deliver Extreme Memory certified modules, with engineering samples predicted to be delivered in mid to late September, added the sources.
    Intel's Extreme Tuning Utility technology will provide an interface to enable the changing of BIOS settings directly from within the operating system making it easier to tweak settings and overclock the system, the sources detailed. Intel's partners have the option to customize the interface of the software tool, according to the sources. Initially, the technology will only be implemented in the X38 chipset, the sources added.
    Monica Chen, Taipei; Joseph Tsai, DIGITIMES [Tuesday 7 August 2007]
    Fonte digitimes.com
    [SIGPIC][/SIGPIC]
    exbibyte L'avatar di lore85bg
    Nov 2005
    Gandino (BG)
    notizia molto interessante...
    soprattutto per il tuning utility sperando funzioni come si deve...
  1. CERCO MOBO con chipset X38/X48 + CPU ed eventualmente OTTIME RAM..
    By breakz in forum -= Acquisti : Hardware - Software =-
    Risposte: 12
  2. SLI su X38
    By Querty in forum -= MotherBoards =-
  3. Problemi al PCIe per il chipset Intel X38 - [NEWS]
  4. Intel X38: chipset con Heatspreader
    By Chicco85 in forum -= MotherBoards =-
  5. Ci risiamo..........Novità...Novità
    By asphalt in forum -= Hardware generico =-
