Ancora alle prese con AREA 51...HELP ME PLEASE!
    Predefinito Soluzione Area 51 per PC...HELP!...PLEASE!
    Salve a tutti,
    sono bloccato al quadro "LA RICERCA" del gioco per PC Area 51...nn so se avete presente. Comunque, ad un certo punto la voce fuori campo mi chiede di cercare una certa scheda L1 prendendola dalla postazione di sicurezza...ecco...è esattamente lì che sono rimasto, alla ricerca della scheda L1 che cerco da tre giorni e nn ho ancora trovato! H E L P !!! Qualcuno sa dirmi come si trova o quale sarebbe questa postazione di sicurezza? Grazie in anticipo a chiunque mi risponderà.
    benvenuto .
    spero non sia un problema l'inglese x te .
    Follow
    them in and they will tell you to get Crispy a "L1 Security Card". Leave this
    room and cross over the walkway bridge to your left. Go into the door to the
    left or right on this walkway (it doesn't matter they go to the same place).
    Follow the hallway that you find inside of the door and kill the mutants that
    you come to. You should see some debris to your left or right (depending on
    which door you entered) near an open doorway (you should see a small fire
    near it). Go to that open doorway and take the "Severed Arm" on the floor
    near the corpse. Turn around and go towards door you see in front of you.
    Before you reach it you will want to back up because there are two mutants
    coming from each hallway on your left and right. Kill them off and then go
    into that door you were going towards. You will see two hand scanners in
    here. Use (X) one of the hand scanners to place the "Severed Arm" on it and
    quickly go over to the other scanner to use it before the Severed Arm falls
    off the other scanner (If it falls before you get to use the other scanner go
    pick it up and place it on the scanner again). Quickly go into the room and
    blast the mutant to your left. Turn around and blast the mutant that is
    coming in through the door you just came through. Turn around again and go
    around the corner to the left to find the "L1 Security Card" (if you want
    ammo on the shelves in this room you need to shoot the glass before you can
    collect it). Head back to the room your team is at and go over to Crispy at
    the computer console to give him the card.
    Smile
    Grazie per il benvenuto e grazie mille per le dritte...l'inglese nn era un problema! Ti auguro un buon proseguimento di giornata, grazie ancora :hihi
    ciao e buona giornata anche a te .
    Unhappy Ancora alle prese con AREA 51...HELP ME PLEASE!
    Mi trovo nel quadro "Segreti sepolti";nella raffineria dopo aver distrutto le torrette come faccio ad arrivare nella stanza da dove si apre il cancello?...HELP!...
    Apr 2002
    Porcia (PN)
    Dade per favore non aprire mille thread sullo stesso topic.
    Red face
    Grazie infinitamente! Mi scuso con "CALMA INSOLITA" ma nn sono molto pratico di forum...
    Apr 2002
    Porcia (PN)
    Originariamente inviato da Dj_Dade
    Ok no problem.
    Facci visita + spesso così impari!
  1. Prese e ciabatte con fusibile? Che scelgo?
    By Sigfried.m in forum -= Modifiche Elettroniche =-
    Risposte: 39
  2. MemoryExtremeTeam alle prese con QX9650 e 8800 GTS (G92) - [NEWS]
    By Chicco85 in forum -= Overclocking e CPU =-
  3. Ancora alle prese con Corsair, che fo?
    By fvbarc in forum -= Hardware generico =-
    Risposte: 12
