4870 x2 vmod
    Predefinito 4870 x2 vmod e bios flash
    ecco cosa ho trovato sul forum di OCTeamDenmark
    two 50 Ohms multiturns vrs on the card
    "First of the 2 Vgpu mods.
    Here is the solderpad on the back of the card for the gpu at the rear of the card.
    6And here is my own discovery the solderpad for the other gpu in front of the card on the back i dont think that others have found it and that is because it is hidden under the laquer on the print abd you have to scratch the laquer of whit a razorblade to get to the solderpad.
    Now we just have to solder some wires to the 2 solderpoints so here we are first the gpumod for the gpu at the back of the card.
    And then the gpumod for the gpu at the front of the card.
    And now to solder two 50 Ohms multiturns vrs on the card.
    BIOS FLASH
    When this is done we will flash the card with the asus top bios so we can clock the card a little further than normal.
    First you have the get som files on the Inet.
    http://frip.dk/riget/asus0.rar
    http://frip.dk/riget/asus1.rar
    The 2 Asus top bios With 900mhz core and 1000mhz mem in CCC and 790/915mhz default 3D clocks
    http://www.techpowerup.com/downloads...lash_3.60.html
    Atiflash for flashing the card in dos
    http://dlsvr04.asus.com/pub/ASUS/vga...martDoc524.zip
    Asus smartdoctor for controlling the fan and oc the card if u dont like the ATI CCC and i you want you ca use Amdgputool but then you have to set the fan after you have ocet the card
    http://www.techpowerup.com/downloads/330/.html
    HP tool to make your usb stick bootable
    http://www.techpowerup.com/articles/...s/USBImage.zip
    Boot image files for the usb stick
    And a guide to flash the card
    http://www.techpowerup.com/articles/...g/vidcard/34/5
    atiflash -f -p 0 asus0.bin
    atiflash -f -p 0 asus1.bin
    what to write in atiflash to flash the card
    Enjoy
    "Edit" this asus bios has a more aggressive fan profile than the normal
    HD4870X2"
    Fonte OCTeamDenmark forum
    Ultima modifica di brugola.x : 13-09-2008 a 19:07
    exbibyte L'avatar di wasky
    May 2004
    Roma Vittoriosa
    Aggiorno il topic per la 4870x2 della XFX dato che c'è anche la vmod del voltaggio delle RAM
    Controllate bene il layout se volete attuare la Vdimm per una scheda di altra marca
    il topic di riska sul forum del team Danese lo trovate QUI oltre alla mod trovate un how to su come migliorare il sistema di dissipazione
    Le zone dove sono situati i componenti segnalate in rosso
    Il resto ve lo lascio leggere al link sopra, sono un botto di foto
    n.b. L'autore del Topic Nexhardware, Memoryextreme e il suo staff non si assumono nessuna responsabilità data la difficoltà dell'operazione, per danni a persone o beni derivate da una non corretta esecuzione della modifica riportata.
    Ultima modifica di wasky : 02-12-2008 a 05:03
  1. 8800gtx vmod's
    By Leghorn in forum Modifiche Elettroniche VGA
    Risposte: 41
  2. 4870 1GB + 4870 512MB possibile?
    By Caos85 in forum Assistenza tecnica
  3. 4870 512 Mb Toxic vs 4870 1 Gb!
    By Nano Gelato in forum -= Schede video e acceleratori =-
  4. Crossfire tra 4870 1gb e una 4870 x2
    By Diego_JAH in forum -= Schede video e acceleratori =-
  5. Vmod 3870 X2
    By lukas69 in forum Modifiche Elettroniche VGA
