I have modded sapphire Bios, GPU Core upper limit to 850MHz, memory upper limit to 1300MHz. You can download here. Try and Good luck! :D
I - HD4850 Bios (Modded by Leonarderman).
1. Sapphire HD4850 Hard Overclocked. DF Core 750MHz Mem 1100MHz Auto Cool Fan.
GPU Core upper Limit 850MHz
Memory Upper limit 1300MHz
Vcore Modded to 1.327V for higher Overclocking.
2. Sapphire HD4850 Light Overclocked. DF Core 700MHz Mem 1000MHz Auto Cool Fan.
Vcore DF 1.12V
Sapphire HD4850 light Overclocked
3. Asus HD4850 Light Overclocked. DF Core 700MHz Mem 1100MHz Auto Cool Fan.
GPU Core upper Limit 1200MHz
Memory Upper limit 1400MHz
Vcore DF 1.12V
4. Sapphire HD4850 Toxic. DF Core 675MHz Mem 1150MHz Auto Cool Fan.
GPU Core upper Limit 700MHz
Memory Upper limit 1200MHz
Vcore DF 1.12V
You should create an USB Bootable to Dos. You can make it from the guide here:
http://www.thepcspy.com/read/bootable_usb_flash_drive
Then you have to copy ATIFlash programs 3.6 (download below) or newer (Dos) and Bios file to USB Disk. Try it done! :D
http://www.techpowerup.com/downloads...lash_3.60.html
Please note: Updating by ATIFlash 3.6 or newer (Dos), don't try to use ATI WinFlash, because I found the problem from bios file maked by RBE1.12! :)
