[New][Case Moddati]ModdArt....Test Ring..Banchetto prova
    tebibyte L'avatar di asphalt
    Sep 2004
    Thumbs up [New][Case Moddati]ModdArt....Test Ring..Banchetto prova
    Questo si che è un banchetto prova ben fatto.....ha pure la possibilità di montare differenti radiatori e differenti tanichette......poi è ben rifinito e esteticamente ha una resa notevole.....complimenti all'autore.....
    Thats right folks...it's finished. And boy oh boy did it turn out better than all of us ever thought it would. Take a look at this informative write up about the rig from TagYourIt.
    "Paul decided he wanted to expand his site and give you more than just great modding information, he wanted to provide you with the best advice on computer hardware. It was decided to get some test rigs for reviews. Paul said, "I can make those for $30 in parts." But he forgot one thing, and I'm sure you've noticed it if you have already looked at the Test Rig... he forgot he's Paul Capello. He can't make just a test rig. It's got to be the sweetest, slickest, and hottest Test Rig around. It is a type of computer case after all isn't it? So scroll down and take a look at Paul's latest creation - the envy of testers, techies, and reviewers alike."
    Oct 2004
    Bellissimo e ottimamente rifinito. Personalmente pero' trovo sia scomodo avere la mobo la' sotto e non poterci accedere dall'alto.
    Jan 2005
    Quoto in pieno....
    tebibyte L'avatar di ToXSysDwn
    Oct 2004
    non so perchè ma io preferisco smontare la parte posteriore del case e appoggiare il tutto sulla mia scrivania
  1. [New][Case Moddati]ModdArt....Tutto in Legno "Stormbrin
    By asphalt in forum Modding from the world
  2. [New][Case Moddati] ModdArt... Bonzai Mods
  3. [New][Case Moddati] ModdArt....Cobra project
    By asphalt in forum -= Modding =-
  4. [Case Moddati]ModdArt tutta Italiana Spider's Web G69T
  5. [Case Moddati] Blackmesa HL²
