velocità wi-fi improvvisamente abbassata
Pagina 3 di 3
1 2 3
Visualizzazione dei risultati da 21 a 23 su 23
  1. #21
    Originariamente inviato da marcosaurus
    purtroppo non ho la minima idea da dove tu abbia fatto quello screenshot. Puoi darmi indicazioni?
  2. #22
    mebibyte L'avatar di marcosaurus
    Sep 2006
    Non è esattamente lo stesso menu...però vedo statistiche xDSL e ottengo questo:
    xDSL Training Status: Idle
    Mode: G.DMT
    Traffic Type: Inactive
    Link Uptime: N/A
    xDSL Port Details Upstream Downstream
    Line Rate: 0.000 Mbps 0.000 Mbps
    Actual Net Data Rate: 0.000 Mbps 0.000 Mbps
    Trellis Coding: N/A N/A
    SNR Margin: 0.0 dB 0.0 dB
    Actual Delay: 0 ms 0 ms
    Transmit Power: 0.0 dBm 0.0 dBm
    Receive Power: 0.0 dBm 0.0 dBm
    Actual INP: 0.0 symbols 0.0 symbols
    xDSL Counters
    Downstream Upstream
    Since Link time = 0 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 204283 0
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Retr: 0
    FailedRetr: 0
    FailedFastRetr: 0
    Latest 15 minutes time = 14 min 43 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 853 853
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Retr: 0
    FailedRetr: 0
    FailedFastRetr: 0
    Previous 15 minutes time = 15 min 0 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 914 914
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Retr: N/A
    HostInitRetr: N/A
    FailedRetr: N/A
    Latest 1 day time = 8 hours 44 min 43 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 31440 31440
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Retr: 0
    FailedRetr: 0
    FailedFastRetr: 0
    Previous 1 day time = 24 hours 0 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 86404 86404
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Retr: 0
    FailedRetr: 0
    FailedFastRetr: 0
    Total time = 1 days 8 hours 44 min 43 sec
    FEC: 0 0
    CRC: 0 0
    ES: 0 0
    SES: 0 0
    UAS: 204283 204283
    LOS: 0 0
    LOF: 0 0
    LOM: 0 0
    Retr: 0
    FailedRetr: 0
    FailedFastRetr: 0
    INOLTRE
    Informazioni GPON
    Presenza SFP
    SFP inserito
    Potenza segnale RX
    -19.0 dBm
    Potenza segnale TX
    1.7 dBm
    Temperatura
    76.3 °C
    Produttore SFP
    DLNK
    Modello SFP
    DPN-100
    Seriale SFP
    444C4E4B204019C7
    CPU: i7 6700k DISSI: noctua
    VGA: Nvidia GTX1070oc
    HD: toshiba RD400me
    CASE: Silverstone HTPC
  3. #23
    Dividi i problemi in due parti e analizzali separatamente: Se la linea è lenta, collegati con un cavo al router e verifica la linea (cosa che stanno comunque facendo loro a quando ho capito).
    Una volta che sei sicuro della linea, passa a verificare il Wi-Fi altrimenti impazzisci.
    BlueRaven likes this.
Pagina 3 di 3
1 2 3
