raga help me!
Mi hanno attivato stamattina alice 20 mega!
ho configurato cosi il router WAG320N in questione!
Ho provato sia con rilevamento automatico on e off!
ma la passante la becca al volo (supero i 18000 sulla spina principale) ma quando quando va a connettersi il mondo di internet diventa rosso e dopo 30 secondi si disconnette il led della portante e va in loop! portante attiva, led rosso di internet!
Ho chiamato alla telecom e per loro è tutto ok e addirittura vedono il router collegato!
Ho l'ultimo firmware, che potrebbe essere???
ecco i parametri!
--- System Information ---
Vendor: Linksys
ModelName: WAG320N
Firmware Version: 1.00.12 , 2010-03-22T10:51:43
Boot Version: 1.06
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB023k.d21d
DSL VPI/VCI: 8/35
DSL Status: Showtime
DSL Mode: ADSL2+
DSL Channel:
DSL Upstream Rate: 786 Kbps
DSL Downstream Rate: 16995 Kbps
Down up
DSL Noise Margin: 12.3 dB 13.5 dB
DSL Attenuation: 18.0 dB 3.1 dB
DSL Transmit Power: 1.3 dBm 4.6 dBm
--- Wireless Information ---
Wireless Driver Version: 5.10.85.0.cpe4.402.4
Wireless Status: Enabled
Wireless Wide Channel: 9
Wireless Standard Channel: 11- 2,462 GHz
Wireless SSID: linksys
--- Dynamic Information ---
LAN Mac Address: 00:25:9C:82:11:5A
WAN Mac Address: 00:25:9C:82:11:5C
Wireless Mac Address: 00:25:9C:82:11:5B
ed ecco l'errore
Sat, 2000-01-01 00:00:22 - ioctl(s, SIOCGIFADDR, ...): No such device
Sat, 2000-01-01 00:00:22 - Failed to get ip address for interface ppp0
Sat, 2000-01-01 00:00:51 - atm_backend_br2684_22 = 2-----ret_22 = 0
Sat, 2000-01-01 00:00:51 - Interface "nas0" created sucessfully
Sat, 2000-01-01 00:00:51 - Communicating over ATM 0.8.35, encapsulation: LLC
Sat, 2000-01-01 00:00:51 - Initialize LCP.
Sat, 2000-01-01 00:00:51 - Plugin pppoe loaded.
Sat, 2000-01-01 00:00:51 - PPPoE Plugin Initialized
Sat, 2000-01-01 00:00:51 - Plugin pppoe called.
Sat, 2000-01-01 00:00:51 - Enter: tdb_store.
Sat, 2000-01-01 00:00:51 - tdb_store: calling tdb_update.
Sat, 2000-01-01 00:00:51 - Enter: tdb_update.
Sat, 2000-01-01 00:00:51 - pppd 2.4.1 started by root, uid 0
Sat, 2000-01-01 00:00:51 - Sending PADI
Sat, 2000-01-01 00:00:52 - Sending PADI 1...
Sat, 2000-01-01 00:00:54 - Sending PADI 2...
Sat, 2000-01-01 00:00:58 - Sending PADI 3...
Sat, 2000-01-01 00:01:06 - Sending PADI 4...
Sat, 2000-01-01 00:01:22 - Restart adsl...
Sat, 2000-01-01 00:01:23 - Connecting PPPoE socket: 00:00:00:00:00:00 0000 0x1004e180
Sat, 2000-01-01 00:01:23 - Couldn't get channel number: Transport endpoint is not connected
Sat, 2000-01-01 00:01:23 - Doing disconnect
Sat, 2000-01-01 00:01:23 - sendto returned:
Sat, 2000-01-01 00:01:23 - Exit.
Non so più che fare... ho provato su tutte le spine di casa, su quella principale raggiungo i 19000, per la telecom è tutto ok! :2sigh
Help me! :2sigh
