AIUTO configurazione router adsl wi-fi Planet ADW4401 v4
    Jul 2009
    Predefinito AIUTO configurazione router adsl wi-fi Planet ADW4401 v4
    Salve a tutti, vi posto la configurazione attuale del mio router/modem:
    System Status
    This page shows the current status and some basic settings of the device.
    System
    Alias Name ADW-4401
    Software Version 1.3.9.14
    DSP Version 2.8.1.6
    DSL
    DSL mode T1.413 G.Dmt ADSL2 ADSL2+
    DSL Status ADSL2+, SHOWTIME.L0
    Upstream Speed 637 kbps (Interleave)
    Downstream Speed 10939 kbps (Interleave)
    Upstream SNR 17.5dB
    Downstream SNR 11.4dB
    reconnection Counts 0
    Uptime 4:37
    Showtime 4h:36m
    Lan Status
    This page shows some basic status of Lan.
    LAN Configuration
    IP Address 192.168.0.1
    Subnet Mask 255.255.255.0
    DHCP Server Enabled
    MAC Address 00-30-4f-6e-1e-f3
    DHCP Client Table
    IP Address: None
    MAC Address: ----
    Time Expired(s): ----
    WLAN Status
    This page shows some basic status of wireless lan.
    Wireless Configuration
    Wireless Enabled
    band 802.11 b+g
    Mode AP
    Broadcast SSID Enabled
    root
    Status Enabled
    SSID planet
    Authentication Mode Open System
    Encrypt Mode WEP
    Key Length 128bits
    Key Format ASCII
    Encrypt Key1 *************
    Use 802.1x Authentication Disabled
    vap0
    Status Disabled
    vap1
    Status Disabled
    vap2
    Status Disabled
    vap3
    Status Disabled
    Wireless Client List
    MAC Address: 00-22-43-6f-a2-51
    Tx Packet: 2169
    Rx Packet: 2789
    Tx Rate (Mbps): 36
    Power Saving: no
    Expired Time (s): 300
    WAN Status
    This page shows some basic status of Wan.
    Interface: Internet_B_8_35
    VPI/VCI: 8/35
    Encap: LLC
    Protocol: br1483
    IP Address
    Gateway
    Status: up
    Il mio problema è il seguente:
    Premetto che non ho alcun problema con la rete wi-fi e la mia linea adsl è Alice 20 Mega.
    Il mio problema riguarda la connessione ad internet.
    Nella sezione di configurazione WAN del router ho impostato il protocollo (o channel mode) 1483Bridged attraverso il quale riesco ad andare in internet solo su comando; ovvero sul notebook o sul pc collegato alla rete devo creare una connessione PPPoE (del tipo user:aliceadsl pass:aliceadsl) per poter navigare. Tuttavia ho la necessità di collegare in rete anche 2 palmari che devono poter sfruttare la connessione adsl, ma i palmari non supportano le connessioni PPPoE. Per questo motivo avrei bisogno che il router/modem si connettesse autonomamente e in modo continuo ad internet così da poter andare in internet senza ulteriori operazioni, ma semplicemente stando connessi alla rete wi-fi.
    Per completezza devo aggiungere che prima del router Planet ADW 4401 v4, avevo la versione_1 settata in PPPoA e connessione (user/pass: aliceadsl) continua, in questo modo avevo la connessione autonoma e continua del router ad internet e potevo navigare con i palmari senza problemi.
    A causa di un guasto sia alla linea adsl (poi riparata) sia al vecchio modem, ho preso la versione 4 dell'ADW 4401.
    Naturalmente ho provato a settare il nuovo modem utilizzando la stessa configurazione del precedente, ma mettendo in WAN il protocollo PPPoA e user/pass di alice, il router non si connette ad internet.
    A questo punto, leggendo qua e là sui forum ho provato a settarlo in modalità 1483Routed, però in questo caso i moduli (cerchiati in rosso nello screenshot) per l'inserimento dell'user e della pass di aliceadsl si disattivano e quindi non posso compilarli, mentre si attivano i moduli (cerchiati in verde) per l'inserimento dei Fixed IP.
    EBBENE, SE LA MODALITA' "1483Routed" E' LA STRADA CHE DEVO SEGUIRE PER RISOLVERE IL MIO PROBLEMA, QUALI SONO QUESTI "Fixed IP" DA INSERIRE?
    IN OGNI CASO,C'E' QUALCUNO CHE PUO' GENTILMENTE ESSERMI D'AIUTO?
    CI STO SBATTENDO DA OLTRE 10 GIORNI MA NON SONO RIUSCITO A RISOLVERE NIENTE!!!
    Grazie mille per l'attenzione.
Nome:   WAN-SETTINGS.gif
Visite: 817
Dimensione:   22.5 KB
  1. Configurazione router tp-link?
    By Agno92 in forum -= Internet/Reti e Sicurezza =-
  2. Aiuto configurazione router - access point - rete lan
    By Skull82 in forum -= Internet/Reti e Sicurezza =-
  3. Aiuto Configurazione Gateway Linksys AG241+ Router Linksys WRT350N
    By CrisHow10 in forum -= Internet/Reti e Sicurezza =-
  4. aiuto configurazione router d-link DSL - G624T
    By boogeyman in forum -= Internet/Reti e Sicurezza =-
    Risposte: 28
  5. Configurazione router us robotics
    By Guglio in forum -= Internet/Reti e Sicurezza =-
    Risposte: 11
