un robetta da poco, insomma
ammazza che mostro, stratosferico (anche nel prezzo) ...
E io che pensavo che la certificazione Platinum fosse il massimo xD
Strepitoso
...per chi riuscirà a sfruttarlo
estremo sotto ogni aspetto!
sarei curioso di vedere qualche immagine dell'interno...
si saa nulla se è single o multi rail?
più di tanto non si sà..
cavolo, 450w e lui "dorme".. che belva!The AX1500i’s high efficiency results in reduced heat, allowing the PSU to operate in silent Zero RPM Fan Mode until the load reaches 450 watts. A custom-designed fluid dynamic bearing 140mm fan, specifically designed for low-noise operation, allows the PSU to run quietly even when running at full 1500 watt power output.
94% efficiency at 50% load at 115V
Includes 8 PCI-E cables for support for up to 4 GPUs
Native USB onboard for Corsair Link real-time monitoring and customization
100% Japanese capacitors
Custom-designed fluid dynamic bearing 140mm low-noise fan
Silent Zero RPM Fan Mode up to 450 watts and ultra-quiet operation at full 1500 watt output (26.5 dBa)
Dimension: 150mm x 86mm x 225mm
7-year warranty
$449.99 MSRP
info: Corsair Announces AX1500i, the World?s Most Technologically Advanced and Efficient PSU for PC EnthusiastsAX1500i's DSP-based design, combined with Corsair Link™ technology, gives enthusiasts unprecedented control over the features and performance characteristics of their PSU. This includes real-time monitoring of temperature, current draw, and power efficiency, as well as the ability to adjust the speed of the internal 140mm fan. These features also allow for a unique level of customization, including the ability to set overcurrent protection points on a per-rail basis in the default multi-rail +12V configuration or simply switch to single +12V rail mode.
info 2: http://www.corsair.com/ax1500i
