Eurocom d900f panther - [ impressioni d'utilizzo ] -
    pebibyte
    Jun 2005
    Predefinito Eurocom d900f panther - [ impressioni d'utilizzo ] -
    -Intro
    -Caratteristiche tecniche in test.
    -Design esterno
    -Design interno
    -Benchmarks e Overclock
    -Impressioni reali d'utilizzo , pro e contro.
    Intro:
    Benche' la struttura di questo portatile sia stata testata ormai a fondo e si possano trovare in rete molte reviews ho voluto sperimentare di persona cosa avesse da offrire questo tipo di tecnologia brandizzata Eurocom. L'intento e' dunque confermare i punti di forza e le note dolenti che caratterizzano questo prodotto.
    Ultima modifica di giostark : 09-04-2010 a 13:46
    pebibyte
    Jun 2005
    Caratteristiche tecniche in prova:
    System Architecture
    Main ChipsetIntel X58 + ICH10RRAID 0/1/5 support
    BIOS Size/NamePHOENIX
    Processor
    LGA1366i7 950 3.07GHzCache L3: 8MB
    Video and Graphics
    Nvidia GTX280M; MXM3.0b
    Built-in PC Camera 3M
    Display
    17-inch; WUXGA 1920x1200 or WSXGA
    Memory6GB; 3RAM DDR3-1333; 204pin; (*)
    (*) they will work at 1333Mhz for Extreme processors and 1066Mhz for lower processors
    StorageHard Drives: total 3 (*)
    Corsair Ex 128GB
    Card Reader/Type7-in-1; MMC/RSMMC/MS/MS Pro/MS Duo/SD/Mini-SD
    DVD BurnerCombo DVD-ROM/CD-RW DVDxWxRWxR
    Audio
    Audio ArchitectureUAA (Universal Audio Architecture); Internal Speaker(s)4Audio-Out1-S/PDIF 7.1CHMicrophone Audio-in1- Mic inHeadphone Out/Jack1Built-in Microphone/Spec1
    Communications
    on-board LAN / Chipset1Gigabit;
    RealTek RTL8111C;
    PCIInternal Modem Type/ Spec56K V90/92;
    Intel 5300Internal Wireless LAN
    PC Card Slot(s)
    PC Card Architecture/ChipsetExpress Card
    Interfaces (Ports)Serial Port1USB # of ports/Version4;
    1-DVI with HDCP supportVideo-In interface1-HDMIRF-in Port0TV-Out (chipset/spec)1;
    HDMI with HDTV supporton-board FireWire (IEEE1394)1-4pin;
    IEEE1394aLAN on-board interface1-RJ45
    Input Devices
    Full-size 102-keys keyboardhot keys
    Internal Pointing DeviceTouchPad with scrolling function
    BatteryBattery: # of cells; capacity; life12-cells; 6600mAh
    DimensionsProduct Dimensions WxDxH (mm)397x298x51-60Product Weight (kg)5.4kg/11.9lbsPackaging L xWx H / N.W. / G.W.N/A
    Included AccessoriesAC Adapter/Model #/Max Output220W; 100-240V 47-63Hz; 20V 14A;
    Caratteristiche tecniche a disposizione per configurazioni piu' performanti:
    Procesori intel i7 975Ex o Xeon 5590.
    (ebbene sul loro sito ho visto per un breve periodo anche il 980x …la cui vendita credo , per motivi o tecnici o commerciali, sia stata poi posticipata)
    Nvidia GTX285M o FX3800Q.
    Memorie at 1600Mhz
    4 (3+1) Hdds (1 con rimozione unita' ottica)
    ecc ecc.
    Per specifiche complete visitare il sito del produttore:
    http://www.eurocom.com/
    Ultima modifica di giostark : 09-04-2010 a 15:22
    pebibyte
    Jun 2005
    Design esterno :
    Scocca interamente in plastica lucida di colore nero e grigio. Pochi particolari color cromatura.
    Pannello da 17” sorretto da due ottime e robuste cerniere con doppia chiusura a molla. Il display in formato 16:10 e di risoluzione 1920x1200 e' di tipo lucido. Cosi' com'e' lucida anche la cornice di colore nero. Nella cornice e' integrata una webcam da 3Mpx.
    Questo monitor (pannello TN) da 17" con una risoluzione di 1920 x 1200 presenta una tra le maggiori densita' per pollice (133.2 ppi) e una dimensione per pixel di 0.1907 mm.
    Indicatori luminosi a vista appena al di sopra della tastiera. Due pulsanti hotkey sulla sinistra della tastiera e tre al di sopra accanto al pulsante di accensione.
    La tastiera , benche' estesa presenta diversi tasti piccoli. (Enter e frecce direzionali). E' molto compatta e non e' presente distanza tra la fila di tasti funzione ed il corpo centrale. Lo stesso vale per il tastierino numerico che si trova ugualmente adiacente al corpo centrale.
    Il touchpad piuttosto distanziato dalla tastiera e dal termine della scocca e' leggermente decentrato sulla sinistra . E' caratterizzato da una plastica leggermente ruvida piuttosto resistente all'usura. I due pulsanti hanno una risposta rigida e precisa.
    Ai lati della tastiera e sul bordo frontale troviamo gli altoparlanti del sistema sonoro. Che come per la maggior parte dei sistemi portatili sono di dimensioni piuttosto ridotte.
    Sul bordo posteriore e' presente solo l'ingresso per l'alimentazione e l'uscita DVI.
    Le prese usb son tutte posizionate sul lato destro del portatile e vicine tra loro.
    Sono presenti sul lato sinistro del portatile uscita HDMI , ESata , CaTv , Modem , Ethernet , 1394J , Card slot , SD slot , unita' ottica. Sul lato destro ci son solo le 4 USB, sul lato posteriore DVI e alimentazione, ed infine sul lato anteriore abbiamo i jack della scheda audio. Ingresso microfono, ingresso segnale audio, uscita cuffie, uscita (“digitale”).
    Per favorire la ventilazione la base del portatile e' rialzata da piedini di plastica con estremita' in gomma antiscivolo .
    La batteria e' sprovvista di aggancio rapido e vine fissata con 3 viti a taglio.
Nome:   full_close.jpg
Visite: 255
Dimensione:   152.0 KB
ID: 8285   Clicca sull'immagine per ingrandirla
Nome:   full_open1.jpg
Visite: 243
Dimensione:   170.1 KB
ID: 8286   Clicca sull'immagine per ingrandirla
Nome:   cam2.jpg
Visite: 183
Dimensione:   156.3 KB
ID: 8288   Clicca sull'immagine per ingrandirla
Nome:   button1.jpg
Visite: 295
Dimensione:   83.7 KB
ID: 8289   Clicca sull'immagine per ingrandirla
Nome:   button4.jpg
Visite: 190
Dimensione:   56.2 KB
Nome:   key2.jpg
Visite: 235
Dimensione:   65.9 KB
ID: 8292   Clicca sull'immagine per ingrandirla
Nome:   pad1.jpg
Visite: 321
Dimensione:   75.7 KB
ID: 8293   Clicca sull'immagine per ingrandirla
Nome:   left2.jpg
Visite: 196
Dimensione:   60.4 KB
ID: 8294   Clicca sull'immagine per ingrandirla
Nome:   right.jpg
Visite: 245
Dimensione:   47.8 KB
ID: 8295   Clicca sull'immagine per ingrandirla
Nome:   back.jpg
Visite: 213
Dimensione:   52.6 KB
    Ultima modifica di giostark : 09-04-2010 a 16:38
    pebibyte
    Jun 2005
    Design interno :
    Cio' che colpisce a differenza di molti altri portatili e' che in questo Laptop e' possibile accedere alla maggior parte dell'hardware semplicemente togliendo dei pannelli posti sul fondo. E' sufficiente rimuovere delle semplici viti per poter accedere a tutto il sistema di dissipazione. La vera utilita' di questa possibilita' va a favore della pulizia delle alette del sistema di dissipazione e per eventuali upgrade delle memorie o della cpu.
    La struttura del sistema di raffreddamento sembra davvero ben ingegnerizzata. Diverse Pipe si collegano dai vari processori ad alette di alluminio anodizzato. L'aria viene catturata dal fondo del portatile mediante 4 griglie e convogliata sul lato posteriore del Notebook.
    Delle 4 griglie solo 3 presentano realmente una ventola. Vi sarebbe la possibilita' di installarne una 4a . Ma a detta dei produttori del notebook quest'ultima non e' necessaria per un reale raffreddamento. (Ci sarebbe dunque da domandarsi se l'effettivo guadagno di questa ulteriore dissipazione non potrebbe esser poi penalizzato da un piu' alto livello di rumore prodotto).
    La parte dissipante e' posta su un'intera meta' del fondo. Sulla restante parte vi sono gli alloggi dei 3 hdds (uno sotto la batteria e due sovrapposti accanto ad essa), la batteria e l'unita' ottica.
    Eurocom a differenza di altri brand offre la possibilita' di configurare il portatile per uso server.
    Sono selezionabili infatti processori Intel Xeon ed un 4o hdd da posizionare al posto dell'unita' ottica.
    Sarebbe cosi' possibile espandere le gia' presenti possibilita' RAID e totalizzare una maggior capacita' d'immagazzinamento dati senza dover ricorrere ad unita' ESata o USB.
Nome:   down2.jpg
Visite: 300
Dimensione:   92.6 KB
ID: 8297   Clicca sull'immagine per ingrandirla
Nome:   down3.jpg
Visite: 272
Dimensione:   89.1 KB
ID: 8298   Clicca sull'immagine per ingrandirla
Nome:   down4.jpg
Visite: 253
Dimensione:   125.9 KB
    Ultima modifica di giostark : 09-04-2010 a 15:25
    pebibyte
    Jun 2005
    Benchmarks e Overclock :
    La scheda video marchiata GTX280M corrisponde circa a una GTS250 da Desktop.
    La possibilita' di miniaturizzare e comprimere le nuove tecnologie permetterebbero di avere anche piu' potenza, tuttavia rimane il problema dell'alimentazione. L'alimentatore , che presenta gia' dimensioni per nulla ridotte , eroga fino a 220Watt. La meta' di questi viene assorbita in full load dalla CPU (circa 130Watt) . Tutti noi sappiamo quanto consumino le schede video per desktop con alte prestazioni. La funzione di almeno trasportabile dovrebbe rimanere tale e quindi aumentare ulteriormente le dimensioni della PSU non sarebbe saggio.
    L'unica soluzione per avere piu' potenza sarebbe quella di ridurre il processo produttivo e diminuire i consumi. Allo stato attuale delle cose questa e' la soluzione trasportabile piu' performante in circolazione.
    Fuori discussione anche il discorso Overclock . In rete si trova qualche recensione che mostra come fare a overclockare un 975EX . Il discorso al quanto dubbio sulla tipologia di quell'overclock risiede nel fatto che nessun altro possessore di quella configurazione hardware sia riuscito ad ottenere gli stessi risultati pur adoperando lo stesso software utilizzato per cambiare i parametri sotto Windows.
    E' da precisare anche che quei risultati sono stati solo nominali. Non e' stato presentato a favore della stabilita' e solidita' del sistema , nessun benchmark serio. E' una questione di consumi.
    Inoltre ad oggi non vi e' nemmeno un reale supporto per il BIOS , che risulta praticamente intoccabile se non per sole 3 voci. Hipertrading , Virtualization , TurboBoost. Non e' possibile sfruttare la reale velocita' delle memorie in dotazione.
    Chiariti questi punti vediamo un po' qualche punteggio:
    _________________________________________________________
    3D MARK 06
    GeForce 280GTXM >>>13520
    Zotac GeForce GTS 250 AMP! >>>15613
    3D MARK VANTAGE
    GeForce 280GTXM >>>6755
    Zotac GeForce GTS 250 AMP! >>>7751
    CINEBENCH R10
    OpenGL 6310
    SING CPU 4432
    MULT CPU 17527
    Crysis very high 4x 1280(f/s) 1920(f/s)
    GeForce 280GTXM >>>15 >>>9
    Zotac GeForce GTS 250 AMP! >>>20 >>>13
    PC MARK VANTAGE >>>14148
    SANDRA
    Multicore Efficency >>>33.3GB/s
    Memory Bandwidh >>>19GB/s
    Filesystem >>>227.6MB/s
    pebibyte
    Jun 2005
    Impressioni reali d'utilizzo , pro e contro :
    Chi si avvicina a questo genere di prodotto sa gia' a cosa va in contro.
    Questo Laptop piu' che un portatile e' un trasportabile.
    Piu' di 5Kg ai quali andranno aggiunti il peso dell'alimentatore e tutto cio' che normalmente si trasporta assieme ai portatili rendono questo prodotto non propriamente comodo da usare in situazioni di movimento.
    Come tutti i prodotti ,non e' esente da critiche : 4 USB poste su un solo lato non sono molto comode. Posizionate subito accanto al mouse (per coloro che sono DX) in caso vengano adoperate con pennette voluminose si avrebbe il mouse troppo vicino a cio' che e' attaccato alla porta USB.
    La batteria , non ha una reale funzione di batteria cosi' come e' concepita sui portatili, e cioe' per un vero utilizzo. E' vista invece come soluzione tampone in caso di perdita di alimentazione e per poter usare tecniche di sospensione o ibernazione. Ad esempio in caso di trasporto casa-ufficio.
    La tastiera sarebbe stato preferibile averla realmente estesa con tutti i tasti grandi. Per poter montare la stessa tastiera su diversi modelli si e' ricorso a questa soluzione.
    Il sistema sonoro con i 4 altoparlanti svolge adeguatamente quello che puo' fare un portatile.
    Due altoparlanti sono posizionati ai lati della tastiera , rivolti verso il viso dell'utilizzatore. Altri due sono posti sul lato frontale vicino agli angoli.
    (E' palese che non si possa avere un grande qualita' audio con quei micro diffusori)
    Il monitor con la suddetta risoluzione presenta fonts piuttosto piccoli che impostati a valore 8 (per avere le classiche proporzioni da sempre adottate da Windows) costringe l'utilizzo dello stesso ad una distanza di circa 30-40cm. Ad una maggior distanza lo sforzo per mettere a fuoco i caratteri inizia a essere fastidioso. ( Il primo allegato mostra le proporzioni del quadro - il secondo allegato mostra la reale qualita' e grandezza dei fonts (da tener conto che nel caricamento della jpg avviene una perdita' di qualita')
    L'angolo di visuale lavorando a distanze cosi' ridotte diventa un parametro meno importante. Per visualizzare qualche filmato il quadro non e' sufficientemente grande per grandi distanze , ci si trova costertti quasi sempre a mantenere una certa perpendicolarita' rispetto al pannello.
    Come tutti i pannelli TN non eccelle nei colori.(e da possessore di un pannello pva posso confermare che in certe condizioni la differenza e' percepibile). L'effetto lucido attenua leggermente questa carenza (in modo ingannevole, nel senso che quest'effetto da come l'impressione di bagnare i colori, e di renderli quindi piu' reali. Peccato che la gamma di colori sia un'altra cosa pero').
    Avendolo provato con diversi degli ultimi videogames posso affermare d'esserne soddisfatto, la tipologia di pannello e' ben nota ai giocatori.
    Ed anche in ambito produttivo questa risoluzione permette di avere un buon numero "cose" sotto gli occhi.
    Cosa che in assoluto mi e' garbata meno e' stata la mancata dichiarazione (a caratteri cubitali) della reale velocita' di funzionamento delle memorie. Il bus dei processori i7 e' di 1066Mhz , sugli EX puo' arrivare a 1333Mhz. Sui modelli non equipaggiati con processori EX vengono ugualmente montate memorie a 1333Mhz che pero' lavorano con timing piu' tirati a 1066Mhz. Presumibilmente anche le nuove memorie a 1600Mhz lavoreranno ad un massimo di 1333 sui processori EX ma con timing piu' performanti. Si potrebbe risolvere questo “spreco” di risorse producendo un BIOS regolabile.
    Eurocom ha dichiarato in via informale (con tutto il valore che puo' avere una dichiarazione informale) di star lavorando affinche' vengano prodotti BIOS piu' configurabili.
    Tuttavia la scelta di questo Notebook sembra essere vincente qualora fossero necessarie grande potenza di calcolo su CPU e GPU e una discreta possibilita' di storare dati.
    Non va tralasciata la possibilita' di poterlo adoperare come Server trasportabile. Chi ha esigenze di un certo tipo nel campo aziendale potrebbe trovare in questo prodotto una reale e completa soluzione.
    Il portatile pur rimuovendo la batteria rimane stabile , grazie al suo peso e grazie alla presenza di un gommino nella parte centrale/anteriore sul fondo del notebook .
    Debbo ammettere che nel complesso son rimasto favorevolmente impressionato.
    Ho tutta la potenza di calcolo che mi serve. La scheda video fa il suo lavoro senza avere eccessive pretese. Il livello di rumore a ventole a pieno regime e' assolutamente sopportabile. Sembra persino poco rumoroso rapportato al reale consumo della cpu e della vga.
Nome:   fonts.jpg
Visite: 253
Dimensione:   129.7 KB
ID: 8300   Clicca sull'immagine per ingrandirla
Nome:   fonts2.jpeg
Visite: 193
Dimensione:   94.8 KB
    Ultima modifica di giostark : 09-04-2010 a 17:41
    Alessandria
    :O orca, bel bombardone adatto a professionisti che possono portarsi appresso un pò più di peso ma hanno bisogno performance alte!
    molto interessante, sarei curioso però di leggere qualcosa di più sullo schermo, che immagino per un prodotto del genere, sia sopra la media ...
    posta delle impressioni tue più approfondite su questo argomento ...
    pebibyte
    Jun 2005
    Ho aggiunto qualcosina che avevo lasciato indietro. Ero partito nel voler fare una cosa mastodontica ed avevo impostato tutto in quel senso. Poi pero' non ho piu' comprato un phonometro e la ciabatta che misura il consumo in tempo reale (volevo misurare i parziali).
    Ed anche ero intenzionato a fare paragoni tra i diversi sistemi operativi. Ma purtroppo mi son reso conto che questo non e' fattibile. Pochi programmi sulla misurazione dei filesystem sembravano , da linea di comando ,svolgere le stesse operazioni seppur scritti in modo differente ma poi i risultati si sono dimostrati troppo diversi o sfalsati.
    Le foto non le ho smanettate a dovere (a parte la qualita' non ho tolto la vignettatura , ecc ecc)
    Alla fine pur di non tenermi tutto in mano ho tagliato parecchio e ho postato solo questo.
    Mi sarebbe garbato smontare tutta la dissipazione per beccare il codice del generatore di clock da mandare a quelli di cpu-id , ma credo che lo sbattimento non sarebbe valso la candela. (specialemnte se utilizzabile solo sotto windoz)
    Appena sara' disponibile l' x980 ci faccio un pensierino :P
    pebibyte
    Jun 2005
    Gia' da un po' e' disponibile anche la 480M e l'X980 e memorie 1600.
    E' un prodotto molto particolare , terro' aggiornato (per quanto possibile) le rilevanti novita' che andra' montando
  1. Intel Panther Point: ecco le specifiche - [NEWS]
  2. Intel Panther Point supporterà nativamente USB 3.0 - [NEWS]
  3. N900 - Impressioni d'utilizzo.
    By giostark in forum -= PocketPC e Smartphone =-
  4. Windows 7 beta primo utilizzo e impressioni d'uso
    By Querty in forum Microsoft Windows 7
    Risposte: 44
  5. RAID: utilizzo
    By Dimas in forum -= Periferiche di memorizzazione =-
    Risposte: 14
