Sul sito Madshrimps è stato recensito il Tecon 55, un amplificatore a valvole dedicato ai PC.
Queste le caratteristiche tecniche:
Integrated amplifier with RCA single ended inputs and USB DAC port
Approx. 4.5 Watts r.m.s. per channel, class A
Zero global negative feedback
Choke input filter
Metal film resistors
Total Harmonic Distortion (T.H.D.) @ 1kHz, 8 Ohm:
Less than 1% at 4.5 Watts
Frequency Response **
17Hz - 27kHz (-3 dB)
30Hz - 17 kHz (-1 dB)
Tube Complements
EL84 x 2 output tubes [fitted with 6P14 "Beijing" in current production]
5755 Raytheon NOS driver tubeInput Impedance: 47 KOhms
Unique blue LEDs under tubes for special effect
Power Source: 115/230VAC switchable
Power Consumption: 80 Watts
Dimension: 7 1/2" (W) x 10" (D) x 7" (H)
Weight: 13 lbs
