Lian Li PC-343B
    Predefinito Lian Li PC-343B
    sul sito della Lian non sono riuscito a trovarlo.. forse è perchè essendo troppo grosso e non ci stava..
    "Designed by a crack squad of Norwegian super-nerd engineers with the intent on creating the ultimate modular case, perfected and manufactured by the king da pimp of cases, Lian-Li, the PC-343B Modular Cube Case will not disappoint! The PC-343B is hands down one of the most versatile cases on the market today.
    It's flexible nature allows the hard to please power users and watercoolers of the world the absolute ultimate in flexibility. The PC-343B packs in the hardware with plenty of room to spare featureing a whopping 18 5.25" flex drive bays. There are literally dozens of accessories ranging from HDD air cooling cages, watercooling mounts, radiator mounts, redundant PSU mounts, the sky is the limit with this case.
    You won't find the PC-343B in the homes of fainthearted noobs, this baby belongs to the 1337 modders, power users, performance junkies, watercoolers, system designers, and hardcore gamers of the world that demand nothing but absolute perfection!
    We are not sure what homage or blood sacrifice those 'wegian super-nerds paid to Sesacretupmoc, the god of computer cases, to create such a perfect modular case, but we are sure there is some desolate farm somewhere out in the badlands of Norwegia that is just a few chickens shy of a flock of seagulls."
    Specifications:
    • Chassis Material: Aluminum
    • Motherboard Form Factor: ATX
    • Drive Bays:
      • 5.25" External: 18
    • Cooling:
      • 2 x 80mm Rear Ports
      • 3 x 120mm Rear Ports
    • Front I/O Ports: 2 x USB2.0, 1 x IE1394 Firewire, 2 Audio
    • Dimensions: 515 x 458 x 460mm
    bestia se è grosso..
    metto anche un link per qualche altra foto.. link
    Ultima modifica di brugola.x : 09-12-2008 a 18:12
    alla fine se uno ha bisogno di un server ad uso casalingo, mi sembra una soluzione definitiva e senza compromessi ...
    mi piace ...
    la qualità la garantisce Lian Li.. deve proprio fare impressione dal vivo..
    Oct 2004
    Vacca boia, ma va dichiarato tra gli Immobili quando si compila il 740????
    Comunque bello e' bello!
    lo spazio per una bella integrazione ci sarebbe tutto..
    L'avatar di Vincent Vega
    Siena
    L'avevo scambiato per una cassettiera .
    Long Live Rock & Roll
    sarebbe perfetto.. dentro ci metterei il pc daily use con la propria waterstation (tanto lo spazio non manca..) e sopra appoggiato invece ci starebbe bello comodo il banchetto da bench..
    Oct 2004
    Fermate Gerryyyyy!!!!!!!!!!!!
    Non farti venire idee malsane, devi mettere da parte i soldini per le casse dello stereo!!!
  1. Case Lian-LI
    By SanDiego in forum Worklogs
    Risposte: 14
  2. [PD+SPED]Case Lian Li Pc-343b Modulare
    By TeknØ in forum -= Vendite : Hardware - Software =-
  3. Lian L'ìintegrazione
    By vkbms in forum Integrazioni
    Risposte: 119
  4. Lian-li? no.. lian ribaltabile!!
    By cjcavin in forum Modding from the world
  5. Scambio Lian-li 65usb con Lian-li Pc7x o L72
    By N.A. in forum -= Acquisti : Hardware - Software =-
