AIUTO MI SI PIANTA TUTTO
    Guest
    VI PREGO AIUTATEMI POSSIEDO UN K63 450 SU UNA ASUS P5A,SCHEDA VIDEO GUILLEMOT 3D PROPHET 128 MB DI RAM ED UNA SOUND BLASTER 128.
    IL PROBLEMA E' CHE FINO A POCHI GIORNI FA TUTTO ANDAVA BENISSIMO POI ALL' IMPROVVISOA COMINCIATO A PIANTARSI TUTTO.
    QUESTO PERO' ACCADE QUANDO USO I GIOCHI E GLI EMULATORI MENTRE SE RIMANGO IN WINDOWS O NAVIGO IN INTERNET VA TUTTO LISCIO COME L'OLIO.
    SE PUO' ESSERE UN INDIZIO TUTTE LE VOLTE CHE SI PIANTA EMETTE UN FISCHIO ASSORDANTE CHE NON SMETTE FINCHE NON RESETTO.HO GIA I DRIVER ED I BIOS PIU' NUOVI PER TUTTE LE PERIFERICHE CHE POSSIEDO PERCIO' NON CREDO CHE SIA QUELLO. VI PREGO AIUTATEMI!!!
    Guest
    vuoi un consiglio reinstalla il win 98
    Guest
    Eccoti qualche consiglio in english :
    There are 3 things you MUST make sure you have setup properly before a successful install of the GeForce256 on a Super7 motherboard:
    You must make sure you have the proper (and latest) AGP-driver installed correctly.
    You must flash your BIOS to the latest revision (in case of better support for AGP-cards)
    You MUST set your VGA adapter to Standard-VGA.
    After you have completed these tasks (small, but very important) you can now proceed to install the driver for your GeForce256. In case you do not know how to install the AGP-driver correctly, then follow these steps:
    Boot up your computer, and install your old Graphics-adapter as a Standard-VGA.
    Reboot.
    Install the AGP-driver for the motherboard.
    Reboot.
    Install the correct driver for your GeForce256 graphics accelerator.
    Note: If you want to install the GeForce256 right away then install the driver for the GeForce256 just after step2, which means do not reboot, shut down and plug your GeForce256 in. Then proceed to the next step, and voila!
    If you encounter further problems with your GeForce then disable AGP 2x, provided you have tried all the newest drivers, in the BIOS. On some Ali V boards the option is called "AGP bus turbo mode", if you disable this you will run the card in AGP 1x (trust me, it does work even though people sometimes think it's AGP 4x/2x - only)
    Spero che ti siano di aiuto.
    Ciao.
    Guest
    TI RINGRAZIO TERMINATOR DEL TUO CONSIGLIO MA E PROPRIO QUELLO CHE VORREI EVITARE, TENTANDO DI USARE QUESTO RIMEDIO SOLO IN CASO ESTREMO.
    E COMUNQUE HO PROVATO GIA ANCHE TUTTO QUELLO CHE MI CONSILIA RMARANGO, MA PURTROPPO NON CAMBIA ASSOLUTAMENTE NULLA, IO RINGRAZIO ANCHE TE PER IL SUGGERIMENTO.
    SPERO SOLO DI RIUSCIRE A FARCELA, E DICO SOLO CHE SE AVESSI SAPUTO CHE IL GEFORCE DA COSI' TANTI PROBLEMI MI SAREI TENUTO LA MIA VECCHIA VOODOO 3 2000 CHE TANTO BENE ANDAVA.
    SONO DISPERATO!!!
    VI RINGRAZIO PER LE RISPOSTE
    CIAO
    Guest
    RAGAZZI CE LO FATTA installando i detonator 368 la scheda non si pianta piu' ma se provo ad installare da i 5.08 in su lo fa di nuovo.
    come e' possibile c' e' una ragione precisa.
    vi prego spiegatemelo.
  1. Aiuto! problema con scheda madre ...si blocca tutto
    By agnellone in forum -= MotherBoards =-
    Risposte: 16
  2. Ho Montato Tutto Ma... Aiuto
    By fvbarc in forum -= Hardware generico =-
    Risposte: 15
  3. A volte mi si pianta il pc...AIUTO!!
    By CALMA INSOLITA in forum -= Insanity !!! =-
  4. aiuto urgente tutto in blocco!!
    By Leomeya in forum -= Hardware generico =-
  5. ho cambiato tutto, un aiuto!!!!
    By slivio... in forum -= Overclocking e CPU =-
