Oltre alla serie HX, Corsair ha presentato oggi due alimentatori facenti parte di una nuova serie, la TX. Si tratta di due prodotti da 650 Watt e 750 Watt rispettivamente.
Corsair TX Series Features:
Supports ATX12V v2.2 standard and older ATX12V 2.01 spec
Ultra-quiet 120mm (140mm on TX750W) double ball-bearing fan delivers excellent airflow
80%+ energy efficiency at 20%, 50% and 100% load condition for less heat generation and lower energy bill
99% Active Power Factor Correction provides clean and reliable power to your system
Universal AC input 90~264V automatically scans and detects the correct voltage
Dedicated single +12V rail offers maximum compatibility with latest components
Over Current/Voltage/Power Protection, Under Voltage Protection, and Short Circuit Protection provide maximum safety to your critical system components.
High quality Japanese capacitors provide uncompromised performance and reliability.
Extra long cables support full tower size chassis.
TX750W Dimension: 5.9"(W) x 3.4"(H) X 6.3"(L);
TX650W Dimension: 5.9"(W) x 3.4"(H) X 5.5"(L);
MTBF: 100,000 Hours
Corsair TX 650 e 750 Watt
