La prima scheda wi-fi su slot PCI-E 1X
CARATTERISTICHE
# PCI-Express 1X interface
# High speed wireless connection up to 54Mbps
# Solid design with external antenna
# Low power consumption and high performance
# Enhanced wireless security
# Software AP mode
SPECIFICHE
# WLAN Standard IEEE 802.11b/g, Wi-Fi compliant
# Host Interface PCI Express
# Dimension 46.5mm x 68mm x 12mm
(not including SMA connector and pin headers)
# Frequency Range 2.4 GHz ISM radio band
# Number of Channels 802.11b: USA, Canada and Taiwan – 11(2412~2462MHz)
Most European Countries – 13, France – 4, Japan – 14
# 802.11g: USA, Canada and Taiwan – 11(2412~2462MHz)
Most European Countries – 13, Japan – 14
# Receive Sensitivity 802.11b: typical -80dBm at 11Mbps
# 802.11g: typical -71dBm at 54Mbps
# Data Rates 802.11b: 1, 2, 5.5, 11Mbps
# 802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps
# Security WEP 64-bit and 128-bit encryption
# WPA(Wi-Fi Protected Access)
# Operating System Windows 2000/XP/server 2003/64bit XP
LINK
