Salve
Devo cambiare il Monitor (mi serve uno per giochare)
ma non so quale prendere tra questi modelli
Model:20" 204B prezzo 471€
Model:20" 204Ts prezzo 460€
Model:21" 214T prezzo 795€
Model 204B Specifications:
Features | Specifications | Size |
Panel Type: a-si TFT/TN
Viewable Size: 20.1"
Pixel Pitch: 0.255mm
Brightness (Typical): 300 cd/m²
Contrast Ratio (Typical): 800:1
Viewing Angle (H/V, Typical): 160°/160° (CR>5)
Aspect Ratio: 4:3
Interface: Analog/Digital
Response Time (Typical): 5 ms
Native Resolution: 1600 x 1200
Maximum Color: 16.7M
Input Video Signal: Analog RGB, DVI Digital Link
Sync Type: Separate H/V, Composite HV, SOG
Input Connectors: 15-Pin D-Sub, DVI-D
Power Consumption: 36 Watts (max)
VESA® Wall Mount: 100 mm (optional)
Emission Standard: TCO '99
Bezel Color: Silver
Dimensions: 17.5x16.8x7.9 (WxHxD) inches (w/stand)
Weight: 16.9 lbs
Special Features: Narrow bezel, rear main power switch, Magic Tune with asset management, MagicColor, Magic Bright, and Magic Speed.
Warranty (P/L/B): 3/3/3 (years)
mi date un sonsiglio:
Model: 20" 204Ts Specifications:
Panel Type a-si TFT/SPVA
Viewable area 20"
Pixel Pitch 0.26
Brightness (cd/m2) 300 cd/m²
Contrast Ratio 700:1
Viewing Angle (H/V) 1780/1780
Response Time (ms) 16
Interface Analogue / Digital
Horizontal Frequency (kHz) 30 ~ 81Hz
Vertical Frequency (Hz) 56 ~ 75Hz
Bandwidth (MHz) 162
Maximum Resolution 1600x1200
Colours Supported 16.2 Mil.
Input Video Signal Analogue RGB, DVI Digital link,
S-Video, Composite
Input Connectors 15pin D-sub,DVI-D,
S-Video, Composite
On Mode 65 Watt (Max)
DPMS Mode <2 Watt, 0 Watt (Power off)
Energy star / NUTEK
Multimedia Speakers n/a
OSD-Digital Display DirectorTM
Wall-Mount VESA 100
Emissions Standard TCO'03
Colour Silver
Mac Compatible
Set (WxHxD) (with stand) 445 x 457 x 228
Set (WxHxD) (w/o stand) 445 x 345 x 76
Packing (WxHxD) 432 x 580 x 275
Weight Net 5.8
Weight Gross inc packaging 11.1
Warranty 3 Year
Stand Height Adjustable with Pivot
Advanced Features MagicBright™
MagicSpeed™
Model: 214T Specifications:
Panel Type a-si TFT/PVA
Viewable area
21"
Pixel Pitch (mm) 0.27
Contrast Ratio
900:1
Viewing Angle (H/V) 178˚/178˚
Response Time (ms) 8
Interface Analogue/Digital
Frequency Horizontal Frequency (kHz) 30~81
Vertical Frequency (Hz) 56~75
Bandwidth (MHz) 162
Colours Supported 16.7 Mil.
Signal
Input Input Video Signal
Analogue RGB,
DVI Digital link, CVBS, S-Video
Input Connectors 15pin D-sub, DVI-D, Compiste, S-Video
Power On Mode 65 Watts (Max.)
DPMS Mode <2 Watt
0 Watt (Power off)
Energy star / NUTEK
OSD-Digital Display Director™
Wall-Mount VESA 100mm
Colour Silver
Mac Compatible
Dimension Set (W*H*D) mm (with stand) 389 x 402.5 x 206
Set (W*H*D) mm (w/o stand) 389 x 386 x 63
Packing(W*H*D) mm 482 x 542 x 148
Weight Net (kg)
5.35
Gross inc packaging (kg) 6.95
Warranty 3 Year
Stand
Foldable Stand
