There are three critical indicators in the OPN.
AX1700DMT3C: Voltage
AX1700DMT3C: Maximum temperature
AX1700DMT3C: FSB Speed
The following codes mean the following:
Voltage
L: 1.50V
U: 1.60V
K: 1.65V
M: 1.75V
All Palominos have default voltage of 1.75V, so all Palominos have voltage code of "M." TBredAs have a default range of 1.5-1.65V. TBredBs have a default range of 1.6V-1.65V.
Maximum Temperature
T: 90C
V: 85C
All AMD processors with a rating less than 2200+ have a maximum temperature of 90C, so they're all "Ts." Anything above that has a max temp of 85C, so they're all "Vs." FSB Speed
C: 266MHz
D: 333MHz
Here's how these codes translate in real life with real chips
