P4 PRESCOTT 0,09 micron FSB 667 L2 1MB con tecnologia HyperThreading
    tebibyte L'avatar di DjRudy
    Jun 2002
    Cenaia (PI)
    Predefinito P4 PRESCOTT 0,09 micron FSB 667 L2 1MB con tecnologia HyperThreading
    http://www.ebnews.com/story/OEG20020917S0039
    Intel Corp. executives are claiming that contrary to the general perception that the Prescott processor would be rolled out as another version of the P4, the company expects the device will be a full-blown P4 successor.
    The chip is slated for introduction in the second half of 2003. At the Intel Developer Forum (IDF), the company said Prescott will feature HyperThreading and an enhanced P4 NetBurst architecture, as well as a new integrated on-chip security technology called La Grande. To be manufactured on a 90nm technology process using 300mm wafers, the chip also is expected to usher in a 667MHz frontside bus.
    In an interview with EBN, Intel president Paul Otellini said that, "Prescott will have so many advanced features that it is not just another Pentium 4 processor, but a new generation of its own," Otellini.
    Louis Burns, vice president and co-general manager of the Intel Desktop Products Group, said Prescott is based on an enhanced NetBurst architecture, the 20-stage instruction pipeline that is the hallmark of the P4. Burns also indicated that the chip will scale up Intel's use of HyperThreading, a multiprocessing technique that allows a single processor to run concurrent instructions to boost performance.
    According to one analyst, advances in the HyperThread architecture will enable Prescott to process even more instruction streams simultaneously, surpassing the performance of the 3.06GHz P4, Intel's fastest announced chip to date.
    Bill Siu, vice president and co-general manager of the Desktop Platform group, said that since each new Intel processor generation has included higher-density on-die memory, it would be logical to expect Prescott to have a beefed-up L2 cache. Siu said Prescott will also use Intel's next-generation chipset, the Springdale. Intel has disclosed few of the chipset's details, although it is expected to be rolled out in the fourth quarter with support for DDR333 memory.
    Sources with knowledge of Intel's roadmap believe the company will build the chipset on a 90nm process.
    Addressing growing security concerns in the PC market, Intel last week also gave a glimpse of La Grande, an on-die technology that will interface with Microsoft's Palladium and other upcoming security software.
    "We're going to take hardware security up a notch and work with future software developers" to implement the new system, Otellini said. "La Grande is not a Pentium 4 product. It will be a next-generation architecture."
    While Prescott will succeed the P4 by adding new features and improving others, Intel and analysts agreed that the chip represents less a complete overhaul of the Pentium architecture than a substantially improved revision.
    Greg Fawson, an analyst at InQuest Market Research, Gilbert, Ariz., said the new chip will follow in the footsteps of past upgrades, from the Pentium Pro to the Pentium II and Pentium III. Exactly how much of a departure the new chip entails will likely be revealed when the company assigns Prescott a brand name, according to other analysts.
    Jun 2002
    Cenaia (PI)
    ke bella gara cn il barton.....
    pebibyte L'avatar di Harlock
    Aug 2001
    Bagnolo Mella , (BS) Italy
    il link non va !!!!
    pebibyte
    Mar 2001
    copia & incolla
    comunque il lato oscuro ntel mi sta tentando ogni giorno che passa di piu'...
    sento che sto cedendo
    Jun 2001
    S. Benedetto del Tronto
    Originally posted by musmax
    copia & incolla
    La tua parte oscura verrà spazzata via dal vento impetuoso, chiamato "HAMMER"
    aspettate gente aspettate
    kibibyte L'avatar di wolfhangher
    Melara
    Predefinito eheheh
    Originally posted by Harlock
    il link non va !!!!
    qui Harlock hai perso dei punti
    Scherzo ciauz by wolfhangher
    Cmq ho letto recentemente che anche AMD pensa ai 0.9 micron...... anzi mi sembra più avanti
    se trovo la rivista mando l'articolo...... o...... lo letto qui sul forum....... ah no ho letto questo articolo.......transistor da 0,01 micron na rivoluzione eheheh
    mando il link
    http://www.01net.it/01NET/HP/0,1254,4_ART_37599,00.html
    e.... siccome Harlock può avere dei problemi lo incollo qui in basso...
    Verso chip da un miliardo di transistor
    AMD annuncia transistor da 10 nanometri
    Mentre all'IDF Intel dimostra un processore da 0,13 micron overclocked a oltre 4 GHz, AMD annuncia di aver fabbricato transistor da 0,01 micron, i più piccoli mai prodotti con processi industriali; si potrebbe arrivare a un miliardo di transistor nello spazio di un chip che oggi ne contiene 100 mili
    10 settembre 2002. Anche quest'anno AMD attira l'attenzione su di sé nei giorni in cui Intel tiene l'IDF. Se Intel rivela di essere al lavoro per produrre chip da un miliardo di transistor, AMD rilancia annunciando di aver prodotto transistor da 10 nanometri con processi di fabbricazione industriali. Questi transistor hanno dimensioni sei volte inferiori rispetto a quelli più piccoli oggi in produzione e sono realizzati con una struttura a doppia porta.
    Si chiamano Fin Field Effect Transistor (FinFET) perché si basano su una piccola pinna verticale (fin) di silicio che contribuisce a controllare la corrente residua attraverso il transistor quando esso si trova nello stato off. La doppia porta permette di raddoppiare la corrente che può essere inviata attraverso il transistor.
    Questo progetto permette ad AMD di proseguire nella curva di incremento delle prestazioni e della densità senza discostarsi in modo significativo dagli attuali processi di fabbricazione comunemente adottati dall'industria. Secondo i ricercatori, infatti, le caratteristiche dei nuovi dispositivi fanno ritenere che la tecnologia CMOS abbia ancora un forte potenziale di scalabilità. I transistor CMOS FinFET prodotti nel Submicron Development Center di AMD sono il risultato della collaborazione con tra AMD e l'Università di California a Berkeley, con il contributo della Semiconductor Research Corporation. La nuova tecnologia verrà illustrata al prossimo International Electron Devices Meeting, che si terrà a San Francisco il 9-11 dicembre prossimi
    Aug 2001
    we , avevo fretta , cio' solo cliccato sopra e son scappato via !!!!
    a me mi vengono a dire copia/inkolla ! tsk !
    comunque tornando in tread , prima di tutto bisogna vedere se quella e' una notizia veritiera ( idem per gli 0,1 AMD ) comunque la vedo male per intel a partire dal 2003 visto che la tabella di confronto sara' questa :
    Athlon XP ( Barton ) vs Celeron
    Athlon XP-64 ( clawhammer) vs Pentium 4
    Opteron ( sledgehammer ) vs Itanium II/Xeon MP
    aia aia aia...
    ciao !
  1. Risposte: 2
  2. 2x1Gb Cellshock DDR2-667 value (Micron D9GMH)[TO+sped]
    By CapFTP in forum -= Vendite : Hardware - Software =-
  3. [PT] Teamgroup 667 3-3-3 chip Micron D9
    By vkbms in forum -= Vendite : Hardware - Software =-
  4. [TV e sped] P4 Prescott 2.8A fsb 533
    By fabietto_18 in forum -= Vendite : Hardware - Software =-
  5. vendo SOYO 5ema+ con 1mb cache+k6III 400
    By ASTERIX in forum -= Acquisti : Hardware - Software =-
