Sono indeciso tra queste ventole da montare sul pal 8045:
Y S TECH 80x80x25mm, TWO Ball Bearings, Case Fan, DC 12V, 3.12W 3700 RPM 48.5 CFM 37dBA 4 Pin Pass-thru connector( Questa non ha il connettore a tre pin quindi andrebbe collegata direttamente all'alimentatore)
YS TECH Adjustable 8CM cooling fan. Manual adjustable fan speed, VERIABLE SPEED FROM 800rpm to 3700rpm. 10.2CFM - 48.7CFM 18dBA - 39.5dBA
3pin connector. 80x80x25mm TWO Ball Bearings
Thermaltake 80X80X25mm FAN, 2 Ball Bearing, 2900+/- 10% RPM, 37CFM Air Flow, with 3pin/4pin adapter
Super Cool 8CM Clear BALL BEARING DC FAN W/ 2 BLUE LEDS Finish off that customer computer look with a clear fan with bright Blue L.E.D.'S. Specifications: Dimensions80X80X25mm 32.5CFM Sound Level 28dBA Rate Per min, 2700RPM Voltage 12VDC 0.13A, 1.6W
Thermaltake SMART FAN. Variable Fan Speed Control, by temperature sensor. Fan Dimension: 80x80x25 mm. Two Ball Bearing. 3-Pin. FAN Speed Control Setting: 2900 rpm at 25°C~ . 5000 rpm at 35°C. Air Flow: 46 CFM at 2900rpm. 53 CFM at 5000rpm
Quale di queste va bene??
