ho lo scannercompact scan Usb 19200 della Trust ..ma sotto win xp nn va dove posso trovare i driver?? ho scaricato il pacchetto per l'xp da 15mb dal sito della trust ma nn lo rileva aiuto....
INSTALLATION INSTRUCTIONS FOR THE 11924 TRUST COMPACT SCAN USB 19200 ON WINDOWS XP:
NOTE:
These instructions can only be used with installing model 11924 Trust Compact Scan USB 19200 on Windows XP, it is not intended for installing the models 11379 and 12386 on Windows XP!
Please check the correct article/item number of your scanner. It is mentioned on the product and/or the package. If you cannot find this, look if you can find a barcode that starts with 87134... For example 8713439118803. Take the last 6 digits (118803) and delete the last one. Then you have the item no. (with this example 11880).
NOTE:
These instructions must be used in combination with the Windows 2000 driver of the 11924 Trust Compact Scan which can be downloaded from the Trust internet site.
NOTE:
Before you continue with the instructions below, please make sure all previous installed drivers and software of the scanner are removed and the scanner is disconnected.
A. DOWNLOADING THE WINDOWS 2000 DRIVER FROM THE TRUST INTERNET SITE
1. Go to "http://www.trust.com/customercare/11924" and click the link "Drivers & Manuals"
NOTE: If you are a first time visitor you must fill in your email address first to enter this site
2. Download the Windows 2000 driver files version 1.5 "11924_01.EXE", "11924_02.EXE", "11924_03.EXE" and "11924_04.EXE"
3. Doubleclick the downloaded files and click "OK" to extract the Windows 2000 driver files
4. Type in a driver location (example: C:\Download\Driver11924) and click the button "Unzip"
NOTE: All the files (11924_01.EXE, 11924_02.EXE, 11924_03.EXE and 11924_04.EXE) must be extracted in the same driver location!
5. After extracting click the button "Close" to close the self extractor
B. INSTALLING THE TWAIN DRIVER
6. In Windows XP go to "Start" and select the option "Run..."
7. Type in "regedit" and click "OK" to start the Registry Editor
8. In the Registry Editor go to the following location:
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion"
9. In the directory "CurrentVersion" right-click the key "ProductName" and select the option "Modify".
10. Modify the Value data from "Microsoft Windows XP" in "Microsoft Windows 2000"
11. Close the Registry Editor.
12. Go to the directory with the extracted 11924 driver files and doubleclick "Start.EXE"
13. Select the prefered language and click "OK"
14. A "Welcome" screen appears. Click "Next" to continue
15. A "Choose Destination Location" screen appears. Click "Next" to continue
16. A "Setup type" screen appears. Select the option "Custom" and click "Next" to continue
17. De-select the options "Direct Scan, Scan Dialog Box", "Acrobat Reader, Scanner Manual" and "TextBridge Classic"
NOTE: the options mentioned above are not included with the internet driver!
18. Click "Next" to continue with the installation of the "Trust Compact Scan USB 19200 Driver"
19. A "Start Copying Files" screen appears. Click "Start Install"
20. After installation click "OK" to restart your computer.
21. After restart follow the steps 6 to 11 to undo the changes in the registry
(Change "Microsoft Windows 2000" back to "Microsoft Windows XP")
C. INSTALLING THE HARDWARE
16. Connect the scanner to a free USB port
17. Windows XP detects the "Compact Scan USB 19200"
18. Select the option "Install the software automatically (Recommended)" and click "Next"
19. A message appears mentioning that the driver has not passed the Windows Logo Testing. Click the button "Continue Anyway"
20. After installation click "Finish"
The Trust Compact Scan USB 19200 is now installed and ready to use with Image Editing software like Photo Express.
NOTE: The option "Test Cover Sensor" of the included Test Program of the Trust Compact Scan USB 19200 does not work on Windows XP. The option "Test Carrier Movement" works properly. Go to "Start - All Programs - Trust - Compact Scan USB 19200" and select the option "Test Program" to start the application.
Important notice
Within the Trust assortment there are several versions of the Compact Scan USB 19200, each with a different item number. Please be sure that you are downloading the driver for the Compact Scan USB 19200 with the correct item number.
Installing the wrong driver can cause serious problems.
You are now about to download the driver for the product with the item number 11924.
Click here to download the driver for 11379.
Click here to download the driver for 12386.
The item number is a five digit number and can be found on the box, the scanner itself and in the manual. Click here for more information about where to find your item number.
fai attenzione al nr dell'oggetto.
e' partikolarmente importante la parte finale, in kui viene detto ke + modelli sono usciti sotto lo stesso nome... e ke i driver sono differenti.
grazie vivissime vi faro sapere se va...
nada...
non dovresti avere altri problemi...
trust fa ottimo hw a prezzi konvenienti.
Anch'io ne ero convinto finchè 1 mese fa circa non scopro che il mio Easy Connect 19200 Plus era "troppo obsoleto" (parole del sito Trust) per avere dei driver per XP!!!! E a dire assai ha 2 anni di vita!!!!Originally posted by frenc
nada...
Per non parlare del fatto che il vetro ha cominciato a scollarsi!
Spero x cam che ora la situazione sia migliorata!![]()
nada faccio na partizione con win me per forza,...
