Consiglio su M/B MSI K7266 pro2
Hybrid View
    Nov 2000
    Predefinito Consiglio su M/B MSI K7266 pro2
    Ho intenzione di comprare la m/b MSI K7266 pro2 su cui installare un processore XP 1800+.
    Pensate possa essere una buona scheda?
    Grazie a tutti.
    Special Features
    Fuzzy Logic3™
    Live BIOS™
    D-Bracket™ (Optional)
    Live Driver™
    Smart Key™ (Optional)
    Special Options
    Promise 20265R On-Board (for K7T266 Pro2-RU)
    -- Supports IDE RAID 0 or 1
    -- The two IDE RAID connectors support hard disk drives only
    Note: Only two hard disk drives will adopt RAID function.
    CPU
    Supports Socket A (Socket-462) for AMD® Athlon™ / Athlon™ XP / Duron™ processor
    Supports 800MHz up to 2000+ MHz processor
    Chipset
    VIA® KT266A (552BGA) Chipset
    - FSB @200/266MHz
    - AGP 4X and PCI Advanced high performance memory controller
    VIA® VT8233 (376BGA) Chipset
    - High Bandwidth V-link Client controller
    - Integrated Faster Ethernet LPC
    - Integrated Hardware Sound Blaster/Direct Sound AC97 audio
    - Ultra DMA 33/66/100 master mode PCI EIDE controller
    - ACPI
    FSB
    100/133(200/266)MHz clocks are supported.
    Main Memory
    Supports six memory banks using three 184-pin DDR DIMMs
    Supports a maximum memory size up to 3GB
    Supports 2.5v DDR SDRAM DIMM
    Slots
    One AGP slot
    - AGP (Accelerated Graphics Port) specification compliant
    - Supports AGP 2.0 1x/2x/4x
    One CNR (Communication Network Riser) slot
    Five 32-bit Master PCI Bus slots
    Supports 3.3V/5V PCI bus Interface
    On-Board IDE
    An IDE controller on the VIA® VT8233 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 33/66/100 operation modes
    Can connect up to 4 IDE devices
    Audio
    Chip integrated (2 channel S/W audio)
    - Direct Sound AC97 Audio
    On-Board Peripherals
    On-Board Peripherals include:
    - 1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
    - 2 serial ports (COMA + COMB)
    - 1 parallel port supporting SPP/EPP/ECP mode
    - 1 IrDA connector for SIR/ASKIR/HPSIR
    - 1 Audio/Game port
    - 1 D-Bracket™ header
    BIOS
    The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
    The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
    Dimension
    30.4 cm(L) x 23.5 cm(W) ATX Form Factor
    Mounting
    6 mounting holes.
    Special Functions
    USB Interface
    -- K7T266 Pro2-RU: 4 USB 2.0 ports, 4 USB 1.1 ports
    -- K7T266 Pro2: 6 USB 1.1 ports
    non e' affatto male kome karatteristike...
    io prenderei la versione -ru, kosi' hai altre 2 interfaccie ide e, se hai 2 hd uguali, sfrutti il raid .
    pebibyte
    Mar 2001
    OTTIMA
    la uso da qualche mese anche quella senza raid costa poco e va benone
    tutto nella sig
    pebibyte L'avatar di Figus
    Fagnano Olona (VA)
    confermo quello che dice musmax... anche io la uso da un po' e dè ottima... stabile e veloce... oltre che di un accattivante colore rosso....
    mebibyte L'avatar di Dave
    A 20Km a Nord di Padova
    Confermo E' una roccia sta scheda! E va pure veloce poco sotto le più blasonate Abit, Asus, ... Se però devi fare OC "estremo" ti consiglio di buttare l'occhio da un altra parte, se vuoi stabilità, configurabilità e cura tecnica vai pure ad occhi chiusi
    nibble
    Cassano Magnago
    Dove posso comprarla online?
    preferirei trovarla con il raid!
    Grazie!
    CIAUZ!
  1. MSI K7T266 Pro2 - RU
    By AMDSkater in forum -= Hardware generico =-
  2. URGENTE: MSI K7T Pro2(RU)
    By Swift in forum -= Hardware generico =-
  3. per i possessori di Msi K7T Pro2-A
    By pindanna in forum -= Overclocking e CPU =-
    Risposte: 16
  4. Msi k7t pro2-a
    By pindanna in forum -= Acquisti : Hardware - Software =-
  5. MSI K7T PRO2 problemi
    By ninjor in forum -= Hardware generico =-
