Salve,
hp appena installato ubuntu sul mio nuovo portatile e come al solito mi ritrovo senza accelerazione 3d.
Qualcuno mi può indicare come abilitare l'accelerazione?
Il chipset è un INTEL 945 GM
Salve,
dimenticavo !!!
allego il mio xorg.conf
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "it"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizEdgeScroll" "0"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Synaptics Touchpad"
EndSection
dimenticavo ancora ho installato ubuntu 8.04 e qui di seguito riporto la conf.hardware
brent@brent-hp:~$ lspci
00:00.0 Host bridge: Intel Corporation Mobile 945GME Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GME Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 01)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
00:1f.2 SATA controller: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA AHCI Controller (rev 01)
02:06.0 CardBus bridge: ENE Technology Inc CB1410 Cardbus Controller (rev 01)
02:08.0 Ethernet controller: Intel Corporation 82562ET/EZ/GT/GZ - PRO/100 VE (LOM) Ethernet Controller Mobile (rev 01)
10:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG Network Connection (rev 02)
ho letto sul sito della intel che hanno rilasciato un nuovo driver che forse farebbe al caso mio ma non ho capito granchè sul come scaricarlo ed istallarlo.
help help help
e questo è l'output del direct rendering
brent@brent-hp:~$ glxinfo
name of display: :0.0
display: :0 screen: 0
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_EXT_texture_from_pixmap
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.4 (2.1 Mesa 7.0.3-rc2)
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_fragment_program,
GL_ARB_imaging, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_vertex_program,
GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_clip_volume_hint, GL_EXT_copy_texture, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_point_parameters,
GL_EXT_polygon_offset, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_APPLE_packed_pixels,
GL_ATI_draw_buffers, GL_ATI_texture_env_combine3,
GL_ATI_texture_mirror_once, GL_ATIX_texture_env_combine3,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_fragment_program, GL_NV_light_max_exponent, GL_NV_point_sprite,
GL_NV_texgen_reflection, GL_NV_texture_rectangle, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_SGI_color_matrix, GL_SGI_color_table,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow, GL_SGIX_shadow_ambient, GL_SUN_multi_draw_arrays
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x23 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None
0x24 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None
0x25 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x26 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x27 24 dc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 0 0 None
0x28 24 dc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 0 0 None
0x29 24 dc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x2a 24 dc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 0 0 None
0x4f 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 Ncon
brent@brent-hp:~$
Ti passo il link al forum di supporto di Ubuntu per il tuo portatile, è in inglese e ancora riferito alla 7.04 ma dovrebbe andare benissimo anche per Hardy.
Comunque questa dovrebbe essere la soluzione al problema accelerazione video, usando il manager dei "restricted driver" incorporato nella distro.
La combinazione ctrl-alt-backspace riavvia il server grafico, quindi la sessione verrà terminata (salva eventuali file aperti!!) e tornerai alla finestra di login, con l'accelerazione grafica attiva se tutto è andato a buon fine.Originariamente inviato da Ubuntu support
Ultima modifica di frakka : 24-04-2008 a 00:37
In riferimento agli output che hai postato purtroppo non ci ho capito moltissimo. Mi pare che Hardy rivoluzioni un pochino la gestione del server grafico rispetto alle versioni precedenti, infatti dall'esame dell'xorg.conf non si capisce un granchè, non accenna neppure a quale driver video è in uso.
Parla solo di "Configured Video Device" che è esattamente come se scrivesse:"Bho! C'è una scheda video... "
Molto più utile diventa, quindi, l'output di lspci, che elenca dettagliatamente l'hardware rilevato. Anche dall'output del direct rendering non ci capisco molto, ma l'unica cosa che mi sembra chiara è questa:
Se non sbaglio dovrebbe essere la conferma che stà usando i driver OpenGL generici (Mesa), invece di quelli Intel, che probabilmente non sono installati o configurati a dovere.codice:OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.4 (2.1 Mesa 7.0.3-rc2)
Purtroppo penso che questa nuova versione di ubuntu sia ancora da perfezionare in quanto sulla 7.10 avevo il 3d mentre da quando ho aggiornato tramite il gestore aggiornamenti non ce l'ho più.
E' possibile che una versione che dovrebbe ritenersi migliore della precedente in realtà non fa più funzionare cose che invece andavano benissimo?
HELP HELP HELP
Certo che è possibile. Nuovo kernel, nuovi moduli. Un errore nella compilazione e non funziona più nulla... Anche perchè la versione ufficiale della 8.04LTS dovrebbe essere uscita solo da un paio di giorni.
Hai provato l'aggiornamento che ti ho suggerito?? Nessun risultato?
Purtroppo la maggior parte della documentazione non è ancora stata aggiornata ad Hardy. Se non funziona così c'è poco da fare se non provare a compilare e caricare i moduli a manina ma non è proprio semplicissimo. Soprattutto perchè non ho a portata di mano un hw uguale al tuo su cui provare la procedura.
Ultima modifica di frakka : 27-04-2008 a 02:37
Si, ho provato ma non ho avuti buoni risultati.
inoltre su questo link ho trovato altri utenti che hanno avuto il mio stesso problema
http://ubuntuforums.org/showthread.php?p=4792313
pare sia un bug di "gioventù"; vedrò se nei prossimi giorni esce qualcosa dalla Intel. Per il resto mi sembra ottima. Tu che ne pensi?
Ancora non l'ho provata.
Aspetto di avere un hd di recupero su cui fare una installazione di prova prima di mettere mano al sistema principale. Se l'installazione va a buon fine e non ho particolari problemi aggiorno via gestore aggiornamenti la 7.10 che stò usando ora. Mi preoccupano soprattutto i driver ATI.
Io la provai quando era Alpha6, mi pare. Troppo indietro per poter parlare.
