Adobe ha rilasciato Lightroom 6.6, CC 2015.6 e Camera Raw 9.6, introducendo il supporto a nuove fotocamere ed una nuova funzione chiamata Guided Upright.
Questa nuova funzione serve a correggere gli orizzonti e a ridurre o eliminare l'effetto di distorsione trapezoidale negli edifici in modo molto efficace, nei due video tutorial che seguono possiamo osservare una panoramica dettagliata ad opera di Julieanne Kost.
Nuovi supporti fotocamera in Lightroom 6.6/CC 2015.6 e Camera Raw 9.6:
- Canon PowerShot G7 X Mark II
- Leica MD (Typ 262)
- Nikon Coolpix B700
- Panasonic DMC-GX85 (DMC-GX80, DMC-GX7MK2)
Inoltre sono stati aggiunti i profili colore per le Pentax 645Z, Pentax K-1, Pentax K-3 II.
Ulteriori aggiornamenti in Lightroom 6.6/CC 2015.6:
Merge to Panorama and HDR now works with Smart Previews. Previously, Lightroom required the use of original images for the Merge to Panorama or HDR features.
The Preferences -> Lightroom mobile section now contains a "Pending Sync Activity" section. This area is useful for helping identify any potential issues related to image sync across the Lightroom family of applications (desktop, mobile and web).
Nuove fotocamere supportate per il collegamento Tethering:
- Canon EOS-1D X Mark II
- Canon EOS 80D
- Canon EOS 1300D
Risolti i suguenti problemi:
- The "As Shot" White Balance showed different values when using the Adobe Standard color profile and other camera matching color profiles. Please note that this only occurred with the Canon EOS IDx MKII, Canon EOS 80D, and Canon EOS Rebel T6 cameras
- Error: "The file appears to be damaged" When opening a Pano merge result from HDR merge sources
- DNG Flat Field plug-in would not work if the source image contained GPS metadata
- Added support for automatic lens profile corrections for Tokina and Tamron lenses on Canon and Nikon camera bodies
- Exif version info is removed while exporting
- Unable to export user-created / custom Develop presets. Please note that this only occurred on Mac
- Unable to create panoramas using Smart Previews when originals are unavailable or offline
- Tethered shooting with Canon 5D did not work on MacOS 10.11 El Capitan
- Unable to see the New Folder preview inside the Destination panel within the Import Dialog
- "Print to File" feature does not work if the default filename was changed by the customer. Please note that this only occurred on Mac OSX 10.11.3
- Removing Virtual Copy Smart Preview also deleted original's smart preview
- Older files expanded using the Recover Edges plug-in fail to merge with "Unknown Errors"
- Scrollbars missing from book module. Please note that this only occurred on Windows
- Lightroom would crash when using tethered shooting with certain Canon camera models
- Removing face tags causes photos to get stuck in "To Be Republished" state when using Publish Service Plugins such as Smugmug
- Inconsistent dialog behavior when using full-screen mode in Mac OSX 10.11
- Text overlays within the Slideshow Module appeared fuzzy
Per ulteriori informazioni vi rimandiamo alla pagina ufficiale Adobe, per i download diretti di Camera Raw 9.6 e Lightroom 6.6 per Windows e Mac OS potete usufruire dei link in calce.
Allegati:
Camera Raw 9.6 Windows
Camera Raw 9.6 Mac OS
Lightroom 6.6/2015.6 Mac OS
Lightroom 6.6/2015.6 Windows
