Adobe ha rilasciato le versioni finali di Camera Raw 8.8 e DNG Converter 8.8 per Photoshop CC / CS6, in questa versione vengono introdotti i supporti per diverse nuove fotocamere, numerosi profili lente e sono stati risolti alcuni bug.
Nuove fotocamere supportate:
  • Casio EX-ZR3500
  • Canon EOS 750D
  • Canon EOS 760D
  • Fujifilm X-A2
  • Fujifilm X-Q2
  • Hasselblad Stellar II
  • Nikon D5500
  • Olympus OM-D E-M5 II
  • Panasonic Lumix DMC-GF7
  • Panasonic Lumix DMC-ZS50
Nuovi profili lente aggiunti:
  • Canon EF 24-85mm F3.5-4.5 USM
  • Canon EF 100-400mm f/4.5-5.6L IS II USM
  • TAMRON SP 15-30mm F / 2.8 Di VC USD
  • DJI Inspire 1 FC350
  • Voigtlander LTM 28mm f/1.9 Ultron Aspherical
  • Voigtlander LTM 28mm f/3.5 Color Skopar
  • Voigtlander LTM 35mm f/1.7 Ultron Aspherical
  • Voigtlander LTM 50mm f/2 Heliar
  • Voigtlander LTM 50mm f/2.5 Color Skopar
  • Voigtlander LTM 50mm f/3.5 Heliar
  • Voigtlander LTM 75mm f/2.5 Color Heliar
  • Voigtlander LTM 90mm f/3.5 APO Lanthar
  • Voigtlander VM 40mm f/2.8 Heliar
  • Voigtlander MFT 17.5mm f/0.95 Nokton Aspherical
  • Voigtlander MFT 25mm f/0.95 Nokton
  • Voigtlander MFT 42.5mm f/0.95 Nokton
  • Nikon AF NIKKOR 14mm f/2.8D ED
  • Nikon AF-S DX NIKKOR 55-200mm f/4-5.6G ED VR II
  • Nikon AF-S NIKKOR 300mm f/4E PF ED VR
  • Nikon NIKKOR 50mm f/1.2 AIS
  • TAMRON SP 15-30mm F/2.8 Di VC USD A012N
  • Voigtlander SL II 20mm f/3.5 Color-Skopar Aspherical
  • Voigtlander SL II 28mm f/2.8 Color-Skopar Aspherical
  • Voigtlander SL II 58mm f/1.4 Nokton
  • SIGMA 18-200mm F3.5-6.3 DC MACRO OS HSM
  • dp1 Quattro
  • dp2 Quattro
  • SIGMA 50mm F1.4 DG HSM Art Lens
  • TAMRON 16-300mm F/3.5-6.3 DiII PZD MACRO AB016S
  • TAMRON 28-300mm F/3.5-6.3 Di PZD A010S
  • TAMRON SP 70-200mm F/2.8 Di USD A009S
  • TAMRON SP 150-600mm F/5-6.3 Di USD A011S
  • TAMRON SP 90mm F/2.8 Di MACRO 1:1 USD F004S
  • Sony FE 16mm F3.5 Fisheye
  • Sony FE 21mm F2.8
  • Sony FE 24-240mm F3.5-6.3 OSS
  • Sony FE 28mm F2
  • Sony FE 35mm F1.4 ZA
  • Sony FE 90mm F2.8 Macro G OSS
  • ZY Optics Mitakon Speedmaster 50mm f0.95 Pro
  • Yuneec CGO2gb
Bug risolti:
  • Risolto il problema dei riflessi magenta durante l'elaborazione dei file RAW prodotti dalla Canon EOS 70D con alcune impostazioni ISO
  • Eliminato il problema del banding in concomitanza con la correzione vignettatura automatica per l'obiettivo Voigtlander VM 21mm f/1.8 Ultron
  • Eliminato il problema di eccessiva correzione della vignettatura con l'obiettivo Pentax FA645 MACRO 120mm F4
  • Eliminato il problema del banding in concomitanza con la correzione vignettatura automatica per l'obiettivo Nikon AF-S NIKKOR 24-85mm f/3.5-4.5G ED VR
  • Dati EXIF del nome dell'obiettivo Zeiss OTUS 85mm f/1.4
  • Eliminato il problema di eccessiva correzione della vignettatura con l'obiettivo Zeiss Distagon T 1,4_35 ZM
  • Profilo lente aggiornato e allineato agli aggiornamenti firmware dell'obiettivo SIGMA 150-600mm F5-6.3 DG OS HSM S014
Il
download è disponibile da subito, ai link in calce i collegamenti alle versioni Windows e Mac.
Allegati:
Adobe Camera Raw e DNG Converter 8.8 Windows
Adobe Camera Raw e DNG Converter 8.8 Macintosh
