La Casa giapponese rende disponibili per il download due nuovi firmware per le mirrorless Micro Quattro Terzi GH3 e G5.
Il download è disponibile al link in calce.
Di seguito le caratteristiche.
These are the new GH3 features:
- "Low Light AF" is added that makes it possible to set focus on the subject in low-lit situations (-3EV).
- "Silent Mode" is added which suppresses electronic shutter, shutter sound, operation sound and flash emission with a single setting.
- "Exposure Comp. Reset" is added which resets the setting of exposure compensation to ±0 whenever the camera is turned off or the shooting mode is changed.
- Performance of AF is enhanced in use with H-PS14042 and H-PS45175.
- Connection problem with Apple Mac computers via Wi-Fi is fixed.
These are the new G5 features:
- Correction of wording on [Motion Picture] menu
Correct the wording "60p/60i/30p" of AVCHD frame rate on [Rec Quality] menu to "50p/50i/25p". This update is for PAL broadcast regions only, and you don't need this update if wording is already "50p/50i/25p".
Allegati:
Download firmware GH3 e G5
