Non per i deboli di cuore: DSD1024
    Moderatore L'avatar di bibo01
    Oct 2010
    Predefinito Non per i deboli di cuore: DSD1024
Nome:   WD-EMM-DA2.jpg
Visite: 373
Dimensione:   36.8 KB
    The DA2 is EMM Labs next generation flagship DAC. It’s been redesigned from the ground up, with the following revisions:
    1. The improved analog stages are said to offer increased transparency.
    2. The multi-award winning MDAT2 DSP has been refined and updated to synergistically work with the new 16xDSD MDAC. The new MDAT2 DSP does real-time transient detection, processing and up-conversion of all incoming audio, PCM and DSD, before sending it to the new 16xDSD MDAC.
    3. Proprietary hardware galvanic isolation for the USB interface.
    4. Every other system from the proprietary jitter removal MFAST to the MCLK clock have been carefully revised for better sound.
    Inputs -> 1xAES, 1xUSB Audio, 2xSPDIF, 2xTOSLINK
    Outputs -> Balanced and un-balanced analog outputs (both can be used at the same time)
    EMM Labs claims that with the MDAT DSP engine and MDAC already running at 16xDSD (DSD1024, 45Mhz/49Mhz) the unit is basically future proof and is a substantial improvement over the DAC2X.
    The DA2 will be shipping in late 2015 with a projected RRP of US$25,000 in the standard finish. There is also the limited edition TX2 SACD/CD transport (40 units only) that goes with the DA2 which will also retail for US$25,000.
    Standard finishes are silver with titanium insert and buttons or black with black insert and buttons. Premium plated inserts and buttons are available including 24K gold and nickel/silver etc. with custom plating also available.
    In pratica fa un upsampling di tutto il segnale in entrata a SDM 45Mhz e 49Mhz. Ovviamente gli ingressi accetteranno molto meno.
    Ultima modifica di bibo01 : 10-10-2015 a 15:57
    Jan 2013
Visite: 373
Dimensione:   36.8 KB
    Cominciamo ad avvicinarci a zone 'sensibili' per i disturbi RFI...
    Ciao, Marco.
    mebibyte
    Aug 2012
    Milano - Varese
    In effetti anche il design fa molto ... apparecchio medicale ... ascolti la musica e fai la magnetoterapia ( mi servirebbe giusto giusto ) da mettere sul ginocchio.
    Lunedi chiedo se me lo passa, la Mutua !
    Dec 2010
    Cagliari
    Confesso che io sono ancora fermo alla domanda circa la necessità del dsd256. Per l' esperienza fin qui fatta con audiolinux sul naa la mia risposta è no. Ora parte un' altra sperimentazione con dei driver test di xmos che dovrebbero permettere dsd 256 anche con windows, ma c' è da fare una piccola modifica alla scheda USB di jlsounds. Vedremo nei prossimi giorni. Di sicuro costa meno di 25.000 american cucuzzes!
    gibibyte L'avatar di krellz
    Oct 2012
    da ex possessore del DAC2X ricordo come il dsd di questo dac è stata la migliore performace fino ad ora registrata da me nel mio sistema. poi ho cambiato e preso il calyx, poi altre strade ancora...
    il DAC2X però mi è rimasto nel cuore...
    non oso immaginare la prestazione di questa nuova meraviglia !!! mi chiedo se upsempla tutto a dsd1024 ma che potenza elaborativa ha ?!
    tebibyte L'avatar di UnixMan
    Sep 2013
    Originariamente inviato da krellz
    mica lo fa in software con una CPU...
    Verosimilmente usa un DSP e/o un sistema implementato direttamente in hardware (e.g. FPGA o roba del genere).
    Ciao, Paolo.
    Oct 2012
    anche il Lumin usa un FPGA...
    sarà qualcosa di hardware allora !
