Sembrano queste le nuove caratteristiche della xbox2, nulla di ufficiale ma potrebbero essere veritiere...
The Xenon GPU is a custom 500+ MHz graphics processor from ATI. The shader core has 48 Arithmetic Logic Units (ALUs) that can execute 64 simultaneous threads on groups of 64 vertices or pixels. ALUs are automatically and dynamically assigned to either pixel or vertex processing depending on load. The ALUs can each perform one vector and one scalar operation per clock cycle, for a total of 96 shader operations per clock cycle. Texture loads can be done in parallel to ALU operations. At peak performance, the GPU can issue 48 billion shader operations per second.
The GPU has a peak pixel fill rate of 4+ gigapixels/sec (16 gigasamples/sec with 4× antialiasing). The peak vertex rate is 500+ million vertices/sec. The peak triangle rate is 500+ million triangles/sec. The interesting point about all of these values is that they’re not just theoretical—they are attainable with nontrivial shaders.
Xenon is designed for high-definition output. Included directly on the GPU die is 10+ MB of fast embedded dynamic RAM (EDRAM). A 720p frame buffer fits very nicely here. Larger frame buffers are also possible because of hardware-accelerated partitioning and predicated rendering that has little cost other than additional vertex processing. Along with the extremely fast EDRAM, the GPU also includes hardware instructions for alpha blending, z-test, and antialiasing.
The Xenon graphics architecture is a unique design that implements a superset of Direct3D version 9.0. It includes a number of important extensions, including additional compressed texture formats and a flexible tessellation engine. Xenon not only supports high-level shading language (HLSL) model 3.0 for vertex and pixel shaders but also includes advanced shader features well beyond model 3.0. For instance, shaders use 32-bit IEEE floating-point math throughout. Vertex shaders can fetch from textures, and pixel shaders can fetch from vertex streams. Xenon shaders also have the unique ability to directly access main memory, allowing techniques that have never before been possible.
