MotherBoard PI-AM2RS780V e KINGSTON HYPERX DDR2-1066 PC2-8500 CL5
    Feb 2011
    Predefinito MotherBoard PI-AM2RS780V e KINGSTON HYPERX DDR2-1066 PC2-8500 CL5
    Come da oggetto ho una MB PI-AM2RS780V con un AMD Phenom(tm) II X3 705e Processor con memorie KINGSTON HYPERX DDR2-1066 PC2-8500 CL5,moduli da 1GB.
    CPU-Z da queste informazioni:
    Chipset
    Northbridge AMD 780G rev. 00
    Southbridge ATI SB700 rev. 00
    Memory Type DDR2
    Memory Size 2048 MBytes
    Channels Dual, (Unganged)
    Memory Frequency 400.2 MHz (1:2)
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 18
    Bank Cycle Time (tRC) 24
    Command Rate (CR) 2T
    Uncore Frequency 2000.8 MHz
    Memory SPD
    DIMM # 1
    SMBus address 0x50
    Memory type DDR2
    Module format Regular UDIMM
    Manufacturer (ID) Kingston (7F98000000000000)
    Size 1024 MBytes
    Max bandwidth PC2-6400 (400 MHz)
    Part number 99U5315-053.A00LF
    Serial number 943A6D46
    Manufacturing date Week 34/Year 10n
    Number of banks 1
    Data width 64 bits
    Correction None
    Nominal Voltage 1.80 Volts
    EPP no
    XMP no
    JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
    JEDEC #1 3.0-3-3-9-12 @ 200 MHz
    JEDEC #2 4.0-4-4-12-16 @ 266 MHz
    JEDEC #3 5.0-5-5-18-23 @ 400 MHz
    Il BIOS è l'ultimo disponibile ed è:
    DMI BIOS
    vendor Phoenix Technologies, LTD
    version 6.00 PG
    date 12/17/2008
    Quali sono le esatte impostazioni nel BIOS per fare andare la memoria a 1066 e non a 800Mhz ?
    Grazie
    Davide Varotto
    Oct 2005
    Verona
    Benvenuto.
    Devi entrare nel bios e nel sottomenù "frequency and voltage control" troveraai la voce per settare le memorie a 1066 MHz.
  1. Overclock QX6700 + MSI X48c + HyperX PC2-8500
    By st3z in forum -= Overclocking e CPU =-
  2. OCZ 2GB Reaper HPC Edition Kit (2x1024MB) PC2-8500/DDR2-1066 [CT+s.s.]
    By dinamite2 in forum -= Vendite : Hardware - Software =-
  3. Vendo 2 X 1 Gb Ddr2 Crucial Ballistix Tracer Led Pc2-8500 1066 Mhz[pg+sped]
    By pirus in forum -= Vendite : Hardware - Software =-
    Risposte: 11
  4. Vendo Crucial Ballistix 2GB (2X1GB) PC2-8500 DDR2-1066 [PA + Sped]
    By Roddy in forum -= Vendite : Hardware - Software =-
