Linux & PC-AM2RS 790G
    Mar 2009
    Question Linux & PC-AM2RS 790G
    No riesco a far funzionare la ethernet connection sul nouvo motherboard - risulta sempre "no ethernet conncetion". ho provato ad isntallare i drivers sul disko di Sapphire ma non riesco
    colci@giga-ubuntu:~/Desktop/r8169-6.003.00$ make clean modules
    make -C src/ clean
    make[1]: Entering directory `/home/colci/Desktop/r8169-6.003.00/src'
    rm -rf *.o *.ko *~ core* .dep* .*.d .*.cmd *.mod.c *.a *.s .*.flags .tmp_versions Module.symvers rset
    make[1]: Leaving directory `/home/colci/Desktop/r8169-6.003.00/src'
    make -C src/ modules
    make -C /lib/modules/2.6.27-7-generic/build SUBDIRS=/home/colci/Desktop/r8169-6.003.00/src modules
    make[2]: Entering directory `/usr/src/linux-headers-2.6.27-7-generic'
    CC [M] /home/colci/Desktop/r8169-6.003.00/src/r8169_n.o
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c:1056: error: unknown field ‘get_perm_addr’ specified in initializer
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c:1056: error: ‘ethtool_op_get_perm_addr’ undeclared here (not in a function)
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c: In function ‘rtl8169_init_one’:
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c:1544: error: implicit declaration of function ‘SET_MODULE_OWNER’
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c: In function ‘rtl8169_change_mtu’:
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c:1988: error: implicit declaration of function ‘netif_poll_enable’
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c: In function ‘rtl8169_wait_for_quiescence’:
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c:2186: error: implicit declaration of function ‘netif_poll_disable’
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c: In function ‘rtl8169_try_rx_copy’:
    /home/colci/Desktop/r8169-6.003.00/src/r8169_n.c:2608: error: implicit declaration of function ‘eth_copy_and_sum’
    make[3]: *** [/home/colci/Desktop/r8169-6.003.00/src/r8169_n.o] Error 1
    make[2]: *** [_module_/home/colci/Desktop/r8169-6.003.00/src] Error 2
    make[2]: Leaving directory `/usr/src/linux-headers-2.6.27-7-generic'
    make[1]: *** [modules] Error 2
    make: *** [modules] Error 2
    Non capisco niente. C'e una guida qualche parte su come installare i driver linux e far funzionare il lan o qualcuno pou' aiutare.
    grazie tanto
    C.
    ciao e benvenuto, non ho mai provato linux su questa piattaforma, che distriduzione / versione stai usando?
    Mar 2009
    Predefinito Linux & PC-AM2RS 790G
    Ho Ubuntu 8.10, kernel 2.6.27-11 con AMD phenom 8650. Devo dire che il problema con il onboard LAN e stato risolto - ma non so che cosa ho fatto. Ho preso i drivers dal cd sapphire, copiato sul dektop, provato ad installare con le procedure sopra come dal file readme, spento il computer, riaceso (ho imparato questa metodolgia dal libretto troubleshooting di Bill Gates), provato con altri drivers sul disco sapphire, spento, riacceso e vedo che il colegamento al lan funzione.
    Sarebbe carino se sapphire potreeb fornire un cd che carica i drivers in automatica anche sul linux - l'autorun e la progamme automatica di installazione funzione solo con windows (credo o magari ho perso qualcosa. Adesso che Linux e cosi facile da utilizzare in generale non e piu' richesta un consocenza del command line, se non per fare qualche operazione strano tipo caricare il drivers del mainboard.
    Una volta collegato ad internet, ubuntu ha scaricato l'aggrionamento di se stesso, chiesto di attivare l'ATI/AMD proprietrary FLGRX graphics driver. Ho fatto il mount del windows shares sul altro computer con XP e tutto funzione perfettamente. Presto windows sara' una memoria vaga e distante, e meno male.
    Boh... Non capisco quali problemi abbia incontrato la compilazione dei moduli, sono piuttosto strani.
    Sembrano errori in fase di compilazione ma leggendo quello che cerca di fare sembra più che stia cercando di installare il modulo. Forse avresti risolto eseguendo il make con "sudo" ma se ti funziona tutto tanto meglio.
  1. Debian Su Linux & C.
    By parsifal in forum -= GNU/Linux e sistemi operativi alternativi =-
    Risposte: 43
  2. VPN & Linux...
    By Paolino in forum -= GNU/Linux e sistemi operativi alternativi =-
  3. Geffo 2 mx & LINUX
    By xadoom in forum -= Schede video e acceleratori =-
  4. Linux & ADSL
    By ThUnDeRz in forum -= Internet/Reti e Sicurezza =-
