[Beta Driver] Disponibili per il test i Catalyst 13.5 beta 2
    Predefinito [Beta Driver] Disponibili per il test i Catalyst 13.5 beta 2
    Oggi è giorno di driver, sono usciti i Catalyst 13.4 WHQL ma sono apparsi in rete i nuovi driver beta 13.5 beta 2
    System Requirements:
    • Windows 8 (32 & 64-bit versions)
    • Windows 7 (32 & 64-bit versions with SP1 or higher)
    • Windows Vista (32 & 64-bit versions with SP2 or higher)
    Compatibility:
    • AMD Radeon HD 7900 Series
    • AMD Radeon HD 7800 Series
    • AMD Radeon HD 7700 Series
    • AMD Radeon HD 6000 Series
    • AMD Radeon HD 5000 Series
    • AMD Mobility Radeon HD 7000M Series
    • AMD Mobility Radeon HD 6000M Series
    • AMD Mobility Radeon HD 5000 Series
    Info:
    • DriverVer=04/16/2013, 12.102.3.0000
    • 12.102.3-130416a-155949E-ATI
    • Catalyst: 13.5
    • CCC: 2013.0416.1036.17145
    • D3D: 9.14.10.0968
    • OGL: 6.14.10.12198
    • OCL: 10.0.1124.2 (Driver Integrated)
    Feature Highlights of the AMD Catalyst™ 13.5 Beta
    Performance gains seen on the entire AMD Radeon™ HD 7000 Series for the following:
    • Far Cry 3: Improves performance up to 4% with Anti-Aliasing enabled
    • Shogun II: Improves performance up to 20% with 8x Anti-Aliasing enabled
    • Tomb Raider: Improves performance up to 6%
    • Bioshock: Improves performance up to 6%
    • Borderlands 2: Improves performance up to 17%
    Corruption is no longer seen on the AMD Radeon HD 7790 when TressFX is enabled in Tomb Raider
    Download Driver Link:
    Ultima modifica di brugola.x : 25-04-2013 a 19:46
    NOTA! È necessario disinstallare AMD Catalyst 13.4 (se si è già installato AMD Catalyst 13.4) prima di installare AMD Catalyst 13.5 Beta
    è disponibile il download dei nuovi Catalyst 13.5 beta 3 (only mobility)
    Feature Highlights of The AMD Mobility Catalyst™ 13.5 Beta3 Driver for Windows:
    • Adds support for the AMD Radeon HD8000M Series
    DriverVer=04/25/2013, 12.102.3.0000
    download diretto driver mobile: http://www2.ati.com/drivers/beta/amd...lity_beta3.exe
    download ed info: AMD Catalyst? 13.5 Windows® Beta Driver
    nibble
    Jan 2013
    Ancona
    qualcuno ha provato questi beta? Sono stabili? Migliorano qualche gioco o benchmark?
    io li ho sù da quando sono usciti e per quello che ci faccio io con il pc mi vengono dietro alla grande, poi cambia da una serie di vga all'altra e obiettivamente le variabili in gioco sono davvero troppe, se non sei soddisfatto di quelli che hai sù ora provali
    PS che driver hai sù ora?
    nibble
    Jan 2013
    Ancona
    ora ho i 13.3 e la scheda è una Sapphire 7970 sinceramente mi trovo abbastanza bene visto che non ho crash e altri tipi di problemi...pero se vanno più veloci non esiterei a installarli
