Come sempre solo ottimi prodotti da Noctua.
Ottimo dissi ....Noctua non ci dorme sopra ed ecco la variante ...diciamo maggiorata ...del NH-L9i (intel) NH-L9a....ora due in uno ...NH-L9x65
Aumentando l'altezza del dissi senza compromettere il suo scopo...ma migliorando questo punto:
prima:
Caution: The NH-L9i is a highly-compact low-profile quiet cooler designed for use in small form factor cases and HTPC environments. While it provides first rate performance in its class, it is not suitable for overclocking and should be used with care on CPUs with more than 65W TDP (Thermal Design Power). Please consult our TDP guidelines to find out whether the NH-L9i is recommended for your CPU.
Ora:
Caution: The NH-L9x65 is a highly-compact low-profile quiet cooler designed for use in small form factor cases and HTPC environments. While it provides first rate performance in its class, it is not suitable for overclocking and should be used with care on CPUs with more than 84W TDP (Thermal Design Power). Please consult our TDP guidelines to find out whether the NH-L9x65 is recommended for your CPU.
Che dire ottimo lavoro da parte di noctua
