The “Black” bundle is almost ready for launch, with the Cosmos Black already making an early appearance. The Hyper Z600 “Black” is now revealed.
The difference is not only the sexy looking top-to-bottom black appearance (which by the way is the first ever for a Cooler Master cooler), but improvements to make this the best performing CPU cooler on the market.
Improvements include: a quiet 120mm PWM fan that intelligently adjusts the fan speed from 800 to 2200 rpm and an ingenious add-on, the airflow cover that slips on the top between the gap created by the heat-sink and the fan to minimize any loss in airflow gushed in by the fan.
The result is to maximize the flow of air to carry out any excessive heat.
Note, this unit is available ONLY with the 500 bundles at this point in time.
fonte VR Zone
a vederlo sembra messo bene.. poi tutto nero secondo mè dice la sua..
