Nuova versione per DDU (Display Driver Unistaller)
Pagina 6 di 7
1 2 3 4 5 6 7 ultimo
Visualizzazione dei risultati da 51 a 60 su 63
  1. #51
    Predefinito Display Driver Uninstaller v.14.3.0.0.
    update
    D.D.U. v.14.3.0.0 (data rilascio 5 Aprile 2015)
    Changelog :
    • Driverstore/Pnplockdownfiles improvements.
    • Environment path cleanup enhancements
    • Intel will not be selected if an nVidia or AMD GPU is found
    • Check updates fixes.
    • Russian translation update (Danis Miryasov)
    download info ed home: DisplayDriverUnistaller
  2. #52
    Predefinito Display Driver Uninstaller v.15.0.0.0
    D.D.U. v.15.0.0.0
    (data rilascio 18 Aprile 2015)
    Changelog:
    • Fix a critical cleaning bug that could have prevented the AMD and nvidia Cleaning to be completely done
    • AMD Cleanup Improvements.
    • removal of the AMDKMPFD lowerfiler and service from the PCI Express ROOT Complex and ROOT PCI BUS.
    • Korean language updates
    • V15.0.0.1
    • Added an extra check before removing the AMDKMPFD service.
    • some work on the control/video section
    download info ed home: DDU Download
    Ultima modifica di brugola.x : 19-04-2015 a 18:26
  3. #53
    Predefinito Display Driver Uninstaller (DDU) v.15.1.0.0
    Display Driver Uninstaller (DDU) v.15.1.0.0 (data rilascio 27 aprile 2015)
    Changelog:
    • Fixed the AMDKMPFD lowerfilter removal for windows 10
    • DDU will not clean the system if there is a Needed reboot from Windows Updates
    • Reworked some variables. Changed how translation work. No more need to copy English stuff on the translated folders.
    • Small AMD CCC addition from info user "Vbs" gave me on guru3d forums.
    download info ed home: Display Driver Unistaller
  4. #54
    Predefinito Display Driver Uninstaller v.15.1.0.2
    D.D.U. v.15.1.0.2 (data rilascio 02 Maggio 2015)
    Changelog:
    • Additional AMD Windows 10 Support.
    • Addition AMD CleanUP
    • Fixed a Cleaning bug that could prevented the removal of some registry keys.(All cards)
  5. #55
    Predefinito Display Driver Uninstaller v.15.2.0.0
    D.D.U. v.15.2.0.0 (data rilascio 20 Maggio 2015)
    Changelog:
    • Enhancement to AMD cleanUP in Windows 10 particularly for the windows update drivers. (Thanks Jackalito and FunkyMike for spotting/reporting)
    • Made some of the buttons a bit smaller, and reduced form size a small amount.
    • Fixed the donation label not being able to be fully read when using the German language setting.
    • Spanish (Jackalito)and Dutch (MojoW) Translation updates.
  6. #56
    Predefinito Display Driver Uninstaller v.15.3.0.0
    D.D.U. v.15.3.0.0 (data rilascio 4 giugno 2015 )
    Changelog:
    • Additional nVidia support for Windows 10
    • Kill the most common programs (MSI AB, EVGA PREC X, RTSS) that read GPU stats before uninstalling.
    • Chinese (Traditional) Danfong Hsieh
    • Chinese (Simplified) BenYeeHua
  7. #57
    Predefinito Display Driver Uninstaller v.15.3.0.1
    D.D.U. v.15.3.0.1
    (data rilascio 11 giugno 2015 )
    Changelog:
    • Fixed a bug in the "AMD HD Audio Bus removal" …
    • Fixed a PhysX related cleanUP bug.
    • Additional nVidia CleanUP (Credits : Dragondale13)
    • Additional AMD CleanUP (Credits: Dalby)
  8. #58
    Predefinito Display Driver Uninstaller v.15.3.0.2
    D.D.U. v.15.3.0.2 (data rilascio 17 Giugno 2015)
    Changelog:
    • New option (disabled by default) for the removal of AMDKMPFD driver/filter.
    • (this option was causing problem on some configuration, use/test it only if you have a backup)
    • Thanks for DM789 testing
    • Translation update : Korean (Zames Dean)
  9. #59
    Predefinito Display Driver Uninstaller v.15.3.0.3
    D.D.U. v.15.3.0.3 (data rilascio 27 Giugno 2015)
    Changelog:
    • Small changes to the control/video section.
    • (do not remove the BasicDisplay or VGA) from the control/ video.
    • Enabled the checkbox9 name translation for the option form.
  10. #60
    Jan 2013
    Rovereto, Italy
    Nuova versione qui
Pagina 6 di 7
