NO, se metti E fa upsample ( downsample) solo se non supportata.Perfetto!!! cosi non ci sono problemi!!!
e devo dire che i valori che hai scelto di default non sono male:
certo se riusciresti a far partire durante lo script qualche interfaccia per inserire sti valori in auto nel file...sarebbe proprio il topcodice:# Defaults for squeezelite initscript # sourced by /etc/init.d/squeezelite # installed at /etc/default/squeezelite by the maintainer scripts # The name for the squeezelite player: SL_NAME="$(hostname -s)" # ALSA output device # check the output of command: "squeezelite -l" # and place here the relevant one. # If not defined will use ALSA default device. # # Examples: #SL_SOUNDCARD="default:CARD=Set" #SL_SOUNDCARD="default:CARD=Amanero" #SL_SOUNDCARD="front:CARD=x20,DEV=0" #SL_SOUNDCARD="iec958:CARD=D20,DEV=0" #SL_SOUNDCARD="plughw:CARD=D20,DEV=0" #SL_SOUNDCARD="hw:CARD=D20,DEV=0" SL_SOUNDCARD="front:CARD=X20,DEV=0" # Squeezebox server (Logitech Media Server): # Uncomment the next line if you want to point squeezelite at the IP address of # your squeezebox server. This is usually unnecessary as the server is # automatically discovered. #SB_SERVER_IP="192.168.x.y" # Additional options to pass to squeezelite: # Please do not include -z to make squeezelite daemonise itself. # Give command: "man squeezelite" for option details. Examples: #SB_EXTRA_ARGS="" #SB_EXTRA_ARGS="-C 1 -a 250:10:32:1 -r 352800-384000 -u vME:0:::98" #SB_EXTRA_ARGS="-C 1 -a 250:10:32:1 -r 352800-384000 -u vLE:2:::98" #SB_EXTRA_ARGS="-C 1 -a 250:10:32:1 -r 352800-384000 -u vIE:8:::98" #SB_EXTRA_ARGS="-C 1 -a 250:10:32:1 -r 352800-384000 -u vIE:32::64:9" SB_EXTRA_ARGS="-C 5 -a 250:10:32:1 -r 44100-384000"
Scusa se cambio la stringa cosi
SB_EXTRA_ARGS="-C 5 -a 250:10:32:1 -r 352800-384000 -u vLE:2:::98"
e a squeezelite arriva un file giá in pcm o aif a 352800 , non fa resample vero?
PS: Paolo come consigliavi di settare la CPU? con le cpu utilis?
