DSD in LMS con SOX
Pagina 57 di 115
... 7 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 107 ... ultimo
Visualizzazione dei risultati da 561 a 570 su 1145
  1. #561
    Jan 2013
    Si, è la massima sincro.
    file wav
    codice:
    [Wed Feb 22 16:13:41 2017] INFO: execute command  : C":\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t dsf "C:\Users\filippo\Desktop\Sacd_dsf\GROOVE ARMADA - VERTIGO\01 - Groove Armada - Chicago.dsf" -t dsf -b 1 - lowpass -2 50000  gain -h rate -v -I -b 90.7 -f 11289600  sdm -f sdm-8
    [Wed Feb 22 16:23:59 2017] INFO: Running as Transcoder
    [Wed Feb 22 16:23:59 2017] INFO: maxDsdrate :256
    [Wed Feb 22 16:23:59 2017] INFO: dsdrate :undef
    [Wed Feb 22 16:23:59 2017] INFO: testfile: E:\Musica\file.wav
    [Wed Feb 22 16:23:59 2017] INFO: AudioScan: {
      info => {
                audio_offset    => 44,
                audio_size      => 136_096_128,
                bitrate         => 2_822_400,
                bits_per_sample => 32,
                block_align     => 8,
                channels        => 2,
                file_size       => 136_096_172,
                "format"        => 1,
                jenkins_hash    => "3486789984",
                samplerate      => 44_100,
                song_length_ms  => 385_760,
      tags => {},
    [Wed Feb 22 16:23:59 2017] INFO: file samplerate: 44100
    [Wed Feb 22 16:23:59 2017] INFO: bits Per Sample: 32
    [Wed Feb 22 16:23:59 2017] INFO: is runtime :                 1
    [Wed Feb 22 16:23:59 2017] INFO: forced Samplerate :
    [Wed Feb 22 16:23:59 2017] INFO: resampleWhen :               A
    [Wed Feb 22 16:23:59 2017] INFO: resampleTo :                 S
    [Wed Feb 22 16:23:59 2017] INFO: Max syncrounus sample rate :
    [Wed Feb 22 16:23:59 2017] INFO: isDsdOutput :                1
    [Wed Feb 22 16:23:59 2017] INFO: maxDsdrate :                 11289600
    [Wed Feb 22 16:23:59 2017] INFO: maxsamplerate :              384000
    [Wed Feb 22 16:23:59 2017] INFO: Target Sample rate :          11289600
    [Wed Feb 22 16:23:59 2017] INFO: execute command  : C":\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t wav "E:\Musica\file.wav" -t dsf -b 1 -  gain -h rate -v -I -b 90.7 -f 11289600  sdm -f sdm-8
    [Wed Feb 22 16:30:02 2017] INFO: Running as Transcoder
    [Wed Feb 22 16:30:02 2017] INFO: maxDsdrate :256
    [Wed Feb 22 16:30:02 2017] INFO: dsdrate :undef
    [Wed Feb 22 16:30:02 2017] INFO: testfile: E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(01) [DJ Krush] Song 1.wav
    [Wed Feb 22 16:30:02 2017] INFO: AudioScan: {
      info => {
                audio_offset    => 116,
                audio_size      => 56_213_504,
                bitrate         => 1_411_200,
                bits_per_sample => 16,
                block_align     => 4,
                channels        => 2,
                dlna_profile    => "LPCM",
                file_size       => 56_214_047,
                "format"        => 1,
                id3_version     => "ID3v2.3.0",
                jenkins_hash    => "3458093476",
                song_length_ms  => 318_670,
      tags => {
                COMM  => ["eng", "", "Track 2"],
                IART  => "DJ Krush",
                ICMT  => "Track 2",
                IGNR  => " ",
                INAM  => "Song 1",
                IPRD  => "DJ Krush   Zen",
                ITRK  => "01",
                NOTE  => "Medieval CUE Splitter (www.medieval.it)",
                NOTES => "Medieval CUE Splitter (www.medieval.it)",
                TALB  => "DJ Krush   Zen",
                TCON  => " ",
                TIT2  => "Song 1",
                TPE1  => "DJ Krush",
                TRCK  => "01",
    [Wed Feb 22 16:30:02 2017] INFO: file samplerate: 44100
    [Wed Feb 22 16:30:02 2017] INFO: bits Per Sample: 16
    [Wed Feb 22 16:30:02 2017] INFO: is runtime :                 1
    [Wed Feb 22 16:30:02 2017] INFO: forced Samplerate :
    [Wed Feb 22 16:30:02 2017] INFO: resampleWhen :               A
    [Wed Feb 22 16:30:02 2017] INFO: resampleTo :                 S
    [Wed Feb 22 16:30:02 2017] INFO: Max syncrounus sample rate :
    [Wed Feb 22 16:30:02 2017] INFO: isDsdOutput :                1
    [Wed Feb 22 16:30:02 2017] INFO: maxDsdrate :                 11289600
    [Wed Feb 22 16:30:02 2017] INFO: maxsamplerate :              384000
    [Wed Feb 22 16:30:02 2017] INFO: Target Sample rate :          11289600
    [Wed Feb 22 16:30:02 2017] INFO: execute command  : C":\PROGRA~2\SQUEEZ~1\server\Bin\MSWin32-x86-multi-thread\sox.exe" -q -t wav "E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(01) [DJ Krush] Song 1.wav" -t dsf -b 1 -  gain -h rate -v -I -b 90.7 -f 11289600  sdm -f sdm-8
    Mi sembra tutto OK, compreso il fatto che il maxsample rate è 384K. A riportarlo a 352K come forzatura evidentemente è LMS in qualche modo che dovrei investigare, ma tant'è.
    Al momento non lo considero per DSD.
    Ciao, Marco.
  2. #562
    tebibyte L'avatar di UnixMan
    Sep 2013
    OK, fatto. Ora non da più quell'errore.
    Ma non va: se seleziono l'uscita su "WAV" (per prima cosa volevo verificare che continuasse a funzionare in PCM, come prima), ignora la cosa e continua ad uscire in dsf!
    codice:
    *** /var/log/squeezeboxserver//C-3PO.log ***
    [Wed Feb 22 16:38:45 2017] INFO: C-3PO says hello! see /var/log/squeezeboxserver/C-3PO.log for errors log level is info
    *** /var/log/squeezeboxserver//server.log ***
    [17-02-22 16:38:46.2185] Slim::Utils::PluginDownloader::checkForUpdates (241) generating apps query to find latest plugin state
    [17-02-22 16:38:46.2833] Slim::Control::Jive::deleteMenuItem (537) randomplay menu id slated for deletion
    [17-02-22 16:38:47.3920] Slim::Web::JSONRPC::requestMethod (443) request not dispatchable!
    [17-02-22 16:38:48.1430] Slim::Player::StreamingController::playerActive (1993) 00:1c:c0:37:22:73 player already active: 00:1c:c0:37:22:73
    [17-02-22 16:38:48.1437] Slim::Formats::Playlists::M3U::read (47) Cannot open /var/lib/squeezeboxserver/prefs/clientplaylist_001cc0372273.m3u: No such file or directory
    [17-02-22 16:38:48.1439] Slim::Player::StreamingController::playerActive (1993) 00:1c:c0:37:22:73 player already active: 00:1c:c0:37:22:73
    [17-02-22 16:38:48.1441] Slim::Player::Squeezebox::reconnect (80) 00:1c:c0:37:22:73 restaring play on pseudo-reconnect at 0
    [17-02-22 16:38:48.1442] Slim::Player::StreamingController::playerReconnect (2072) 00:1c:c0:37:22:73
    [17-02-22 16:38:48.1444] Slim::Player::Squeezebox::reconnect (88) 00:1c:c0:37:22:73 forcing stop on pseudo-reconnect
    [17-02-22 16:38:48.1450] Slim::Player::Squeezebox2::getPlayerSetting (933) Getting pref: [playername]
    [17-02-22 16:38:48.1452] Slim::Player::Squeezebox2::getPlayerSetting (933) Getting pref: [disableDac]
    [17-02-22 16:38:48.1503] Slim::Utils::Prefs::Namespace::savenow (322) saving prefs for plugin.C3PO to /var/lib/squeezeboxserver/prefs/plugin/C3PO.prefs
    [17-02-22 16:38:48.1531] Plugins::C3PO::Plugin::_clientCalback (521) new ClientCallback received from
    mac address:            00:1c:c0:37:22:73
    modelName:              SqueezeLite-R2
    model:                  squeezelite
    max samplerate:         768000
    max dsd resolution:     512
    supported sample rates: 8000 11025 12000 16000 22050 24000 32000 44100 48000 88200 96000 176400 192000 352800 384000 705600 768000
    supported dsd rates:    64 128 256 512
    supported codecs :      wma flc dsf dff mp3 alc ogg wmap wav aif aac wmal
    [17-02-22 16:38:48.1551] Slim::Utils::Prefs::Namespace::savenow (322) saving prefs for plugin.C3PO to /var/lib/squeezeboxserver/prefs/plugin/C3PO.prefs
    [17-02-22 16:38:48.1599] Slim::Utils::Misc::msg (1244) Warning: [16:38:48.1597] Use of uninitialized value $forcedSamplerate in concatenation (.) or string at /var/lib/squeezeboxserver/cache/InstalledPlugins/Plugins/C3PO/Transcoder.pm line 752.
    [...seguono altri warning analoghi, poi...]
    [17-02-22 16:38:48.1724] Plugins::C3PO::Plugin::_setupTranscoder (1335) commandTable: {
      "aif-aif-*-00:1c:c0:37:22:73" => {
                                         capabilities => {
                                                           D => "RESAMPLE=-r %d",
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           T => "START=-ss %s",
                                                           U => "END=-t %w",
                                         command      => "[ffmpeg] -vn -v 0 \$START\$ \$END\$ -i \$FILE\$ -f wav - | [sox] -q -t wav - -t wav -b 24 -  gain -h bass +3 rate -v -L -t -b 90.7 -f 768000  dither -f shibata -p 24",
                                         profile      => "aif-aif-*-00:1c:c0:37:22:73",
      "alc-pcm-*-00:1c:c0:37:22:73" => {
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           U => "END=-t %w",
                                         profile      => "alc-pcm-*-00:1c:c0:37:22:73",
      "dff-pcm-*-00:1c:c0:37:22:73" => {
                                         capabilities => { D => "RESAMPLE=-r %d", F => "noArgs", R => "noArgs" },
                                         command      => "[sox] -q -t dff \$FILE\$ -t wav -b 24 - lowpass -2 22000 lowpass -2 30000  gain -h bass +3 rate -v -L -t -b 90.7 -f 768000  dither -f shibata -p 24",
                                         profile      => "dff-pcm-*-00:1c:c0:37:22:73",
      "dsf-pcm-*-00:1c:c0:37:22:73" => {
                                         command      => "[sox] -q -t dsf \$FILE\$ -t wav -b 24 - lowpass -2 22000 lowpass -2 30000  gain -h bass +3 rate -v -L -t -b 90.7 -f 768000  dither -f shibata -p 24",
                                         profile      => "dsf-pcm-*-00:1c:c0:37:22:73",
      "flc-pcm-*-00:1c:c0:37:22:73" => {
                                         capabilities => { D => "RESAMPLE=-r %d", F => "noArgs", I => "noArgs", R => "noArgs" },
                                         command      => "[flac] -dcs --totally-silent \$START\$ \$END\$ -- \$FILE\$ | [sox] -q -t wav - -t wav -b 24 -  gain -h bass +3 rate -v -L -t -b 90.7 -f 768000  dither -f shibata -p 24",
                                         profile      => "flc-pcm-*-00:1c:c0:37:22:73",
      "wav-pcm-*-00:1c:c0:37:22:73" => {
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           U => "END=-t %w",
                                         profile      => "wav-pcm-*-00:1c:c0:37:22:73",
    [17-02-22 16:38:48.1729] Slim::Utils::Prefs::Namespace::savenow (322) saving prefs for server to /var/lib/squeezeboxserver/prefs/server.prefs
    [...ripetuto 6 volte, poi...]
    [17-02-22 16:38:48.1984] Slim::Player::Squeezebox2::playerSettingsFrame (1003) Pref [playername] = [R2@spmc]
    *** /tmp/squeezelite.log ***
    [16:38:48.144717] decode_flush:190 decode flush
    [16:38:48.144754] output_flush:423 flush output buffer
    [16:38:49.154580] output_thread:807 disabling output
    [17-02-22 16:38:55.0008] Slim::Utils::Prefs::Namespace::savenow (322) saving prefs for plugin.musicartistinfo to /var/lib/squeezeboxserver/prefs/plugin/musicartistinfo.prefs
    [17-02-22 16:38:58.0008] Slim::Utils::Prefs::Namespace::savenow (322) saving prefs for plugin.C3PO to /var/lib/squeezeboxserver/prefs/plugin/C3PO.prefs
    [17-02-22 16:40:09.0024] Slim::Utils::Prefs::Namespace::savenow (322) saving prefs for plugin.C3PO to /var/lib/squeezeboxserver/prefs/plugin/C3PO.prefs
    [17-02-22 16:40:23.6590] Slim::Player::StreamingController::stop (2097) 00:1c:c0:37:22:73
    [17-02-22 16:40:23.6592] Slim::Player::StreamingController::resetSongqueue (1776) Song queue is now
    [17-02-22 16:40:23.6834] Slim::Player::StreamingController::play (2100) 00:1c:c0:37:22:73
    [17-02-22 16:40:23.6841] Slim::Player::StreamingController::_setPlayingState (2357) new playing state STOPPED
    [17-02-22 16:40:23.6843] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state IDLE
    [17-02-22 16:40:23.7639] Slim::Player::Song::new (108) index 0 -> file:///bla/bla/bla.flac
    [17-02-22 16:40:23.7643] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state TRACKWAIT
    [17-02-22 16:40:23.7731] Slim::Player::StreamingController::_playersMessage (789) Now Playing: file:///bla/bla/bla.flac
    [17-02-22 16:40:23.7769] Slim::Player::Song::getNextSong (229) file:///bla/bla/bla.flac
    [17-02-22 16:40:23.7772] Slim::Player::StreamingController::_nextTrackReady (737) 00:1c:c0:37:22:73: nextTrack will be index 0
    [17-02-22 16:40:23.7774] Slim::Player::StreamingController::_Stream (1203) Song queue is now 0
    [17-02-22 16:40:23.7776] Slim::Player::StreamingController::_Stream (1206) 00:1c:c0:37:22:73: preparing to stream song index 0
    [17-02-22 16:40:23.7778] Slim::Player::Song::open (363) file:///bla/bla/bla.flac
    [17-02-22 16:40:23.7915] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    [17-02-22 16:40:23.7921] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    [17-02-22 16:40:23.7923] Slim::Player::Song::open (387) seek=false time=0 canSeek=2
    [17-02-22 16:40:23.7928] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    [17-02-22 16:40:23.7930] Slim::Player::Song::open (408) Transcoder: streamMode=F, streamformat=dsf
    [17-02-22 16:40:23.7931] Slim::Player::Song::open (547) isRemote? No
    [17-02-22 16:40:23.7933] Slim::Player::Song::open (548) is sock defined? No
    [17-02-22 16:40:23.7935] Slim::Player::Song::open (552) usepipe? No
    [17-02-22 16:40:23.7939] Slim::Player::TranscodingHelper::tokenizeConvertCommand2 (617) Using command for conversion: "/usr/bin/flac" -dcs --totally-silent -- "/home/data/audio/music/new_flac/riccardo/Antony And The Johnsons (2009) The Crying Light/01 Her Eyes Are Underneath The Ground.flac" | "/usr/share/squeezeboxserver/Bin/x86_64-linux/sox" -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8 & |
    [17-02-22 16:40:23.7941] Slim::Player::Song::open (563) Tokenized command: "/usr/bin/flac" -dcs --totally-silent -- "/home/data/audio/music/new_flac/riccardo/Antony And The Johnsons (2009) The Crying Light/01 Her Eyes Are Underneath The Ground.flac" | "/usr/share/squeezeboxserver/Bin/x86_64-linux/sox" -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8 & |
    [16:40:23.683755] decode_flush:190 decode flush
    [16:40:23.683797] output_flush:423 flush output buffer
    [17-02-22 16:40:24.0048] Slim::Player::StreamingController::_Stream (1265) 00:1c:c0:37:22:73: stream
    [17-02-22 16:40:24.0070] Slim::Player::StreamingController::_Stream (1302) Song queue is now 0
    [17-02-22 16:40:24.0073] Slim::Player::StreamingController::_setPlayingState (2357) new playing state BUFFERING
    [17-02-22 16:40:24.0074] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state STREAMING
    [17-02-22 16:40:24.0652] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    [17-02-22 16:40:24.0658] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    [16:40:24.006643] codec_open:218 codec open: 'd'
    [16:40:24.006709] stream_sock:384 connecting to 127.0.0.1:9000
    [16:40:24.006791] stream_sock:413 header: GET /stream.mp3?player=00:1c:c0:37:22:73 HTTP/1.0
    [16:40:24.128032] stream_thread:176 headers: len: 115
    HTTP/1.1 200 OK
    Server: Logitech Media Server (7.9.0 - 1468928517)
    Connection: close
    Content-Type: audio/dsf
    [16:40:24.274274] _read_header:158 DSF version: 1 format: 0
    [16:40:24.274318] _read_header:168 channels: 2
    [16:40:24.274325] _read_header:169 sample rate: 5644800
    [16:40:24.274331] _read_header:170 lsb first: 1
    [16:40:24.274337] _read_header:171 sample bytes: 2305843009213693951
    [16:40:24.274343] _read_header:172 block size: 4096
    [16:40:24.274349] _read_header:178 found dsd len: 12
    [16:40:24.274355] dsd_decode:765 setting track_start
    [16:40:24.274361] dsd_decode:818 DSD128 stream, format: DSD_U32_BE, rate: 176400Hz
    [16:40:24.282515] output_thread:694 open output device: hw:CARD=D20
    [16:40:24.282567] alsa_open:366 opening device at: 176400
    [16:40:24.282777] alsa_open:439 opened device hw:CARD=D20 using format: DSD_U32_BE sample rate: 176400 mmap: 1
    [16:40:24.282807] alsa_open:530 buffer: 499 period: 3 -> buffer size: 88023 period size: 29341
    [17-02-22 16:40:24.9529] Slim::Player::StreamingController::playerTrackStarted (2180) 00:1c:c0:37:22:73
    [17-02-22 16:40:24.9531] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PLAYING
    [17-02-22 16:40:24.9533] Slim::Player::StreamingController::_Playing (361) Song 0 has now started playing
    [17-02-22 16:40:24.9539] Slim::Player::StreamingController::_Playing (390) Song queue is now 0
    [16:40:24.952367] _output_frames:61 start buffer frames: 179200
    [16:40:24.952421] _output_frames:146 track start sample rate: 176400 replay_gain: 0
    [17-02-22 16:40:28.4083] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    [17-02-22 16:40:28.4089] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [flac] -dcs --totally-silent $START$ $END$ -- $FILE$ | [sox] -q  -t wav - -t dsf  -b 1 - gain -h rate -vMn 5644800 sdm -f  sdm-8
    [17-02-22 16:40:33.0004] Slim::Utils::Prefs::Namespace::savenow (322) saving prefs for plugin.randomplay to /var/lib/squeezeboxserver/prefs/plugin/randomplay.prefs
    se non capisco male, sta continuando ad utilizzare la configurazione in convert.conf.
    P.S.: la configurazione:
Nome:   c3po-test-conf.jpg
Visite: 157
Dimensione:   79.4 KB
    Ciao, Paolo.
  3. #563
    Jan 2013
    File Flac
    codice:
    [17-02-22 16:46:20.2294] Slim::Player::StreamingController::stop (2097) 00:e0:4c:68:d1:46
    [17-02-22 16:46:20.2295] Slim::Player::StreamingController::resetSongqueue (1776) Song queue is now
    [17-02-22 16:46:20.2307] Slim::Player::StreamingController::play (2100) 00:e0:4c:68:d1:46
    [17-02-22 16:46:20.2310] Slim::Player::StreamingController::_setPlayingState (2357) new playing state STOPPED
    [17-02-22 16:46:20.2311] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state IDLE
    [17-02-22 16:46:20.2323] Slim::Player::Song::new (108) index 0 -> file:///E:/Musica/DA_CANCELLARE/DJ%20Krush%20-%20Zen/(01)%20[DJ%20Krush]%20Song%201.flac
    [17-02-22 16:46:20.2324] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state TRACKWAIT
    [17-02-22 16:46:20.2335] Slim::Player::StreamingController::_playersMessage (789) Now Playing: file:///E:/Musica/DA_CANCELLARE/DJ%20Krush%20-%20Zen/(01)%20[DJ%20Krush]%20Song%201.flac
    [17-02-22 16:46:20.2349] Slim::Player::Song::getNextSong (229) file:///E:/Musica/DA_CANCELLARE/DJ%20Krush%20-%20Zen/(01)%20[DJ%20Krush]%20Song%201.flac
    [17-02-22 16:46:20.2351] Slim::Player::StreamingController::_nextTrackReady (737) 00:e0:4c:68:d1:46: nextTrack will be index 0
    [17-02-22 16:46:20.2352] Slim::Player::StreamingController::_Stream (1203) Song queue is now 0
    [17-02-22 16:46:20.2353] Slim::Player::StreamingController::_Stream (1206) 00:e0:4c:68:d1:46: preparing to stream song index 0
    [17-02-22 16:46:20.2354] Slim::Player::Song::open (363) file:///E:/Musica/DA_CANCELLARE/DJ%20Krush%20-%20Zen/(01)%20[DJ%20Krush]%20Song%201.flac
    [17-02-22 16:46:20.2358] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -l "C:\ProgramData\Squeezebox\Logs" -x "C:/PROGRA~2/SQUEEZ~1/server" -i flc -o dsf $START$ $END$ $RESAMPLE$ $FILE$ --nodebuglog
    [17-02-22 16:46:20.2505] Slim::Player::TranscodingHelper::checkBin (275)    couldn't find binary for: lame
    [17-02-22 16:46:20.2506] Slim::Player::TranscodingHelper::getConvertCommand2 (443) Error: Didn't find any command matches for type: flc
    [17-02-22 16:46:20.2508] Slim::Player::Song::open (387) seek=false time=0 canSeek=0SEEK_ERROR_TRANSCODED
    [17-02-22 16:46:20.2510] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -l "C:\ProgramData\Squeezebox\Logs" -x "C:/PROGRA~2/SQUEEZ~1/server" -i flc -o dsf $START$ $END$ $RESAMPLE$ $FILE$ --nodebuglog
    [17-02-22 16:46:20.2511] Slim::Player::Song::open (408) Transcoder: streamMode=F, streamformat=dsf
    [17-02-22 16:46:20.2513] Slim::Player::TranscodingHelper::tokenizeConvertCommand2 (617) Using command for conversion: "C:\ProgramData\Squeezebox\Cache\InstalledPlugins\Plugins\C3PO\Bin\MSWin32-x86-multi-thread\C-3PO.exe" -c 00-e0-4c-68-d1-46 -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -l "C:\ProgramData\Squeezebox\Logs" -x "C:/PROGRA~2/SQUEEZ~1/server" -i flc -o dsf "E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(01) [DJ Krush] Song 1.flac" --nodebuglog |
    [17-02-22 16:46:20.2515] Slim::Player::Song::open (558) Tokenized command: "C:\ProgramData\Squeezebox\Cache\InstalledPlugins\Plugins\C3PO\Bin\MSWin32-x86-multi-thread\C-3PO.exe" -c 00-e0-4c-68-d1-46 -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -l "C:\ProgramData\Squeezebox\Logs" -x "C:/PROGRA~2/SQUEEZ~1/server" -i flc -o dsf "E:\Musica\DA_CANCELLARE\DJ Krush - Zen\(01) [DJ Krush] Song 1.flac" --nodebuglog |
    [17-02-22 16:46:20.2751] Slim::Player::StreamingController::_Stream (1265) 00:e0:4c:68:d1:46: stream
    [17-02-22 16:46:20.2762] Slim::Player::StreamingController::_Stream (1302) Song queue is now 0
    [17-02-22 16:46:20.2763] Slim::Player::StreamingController::_setPlayingState (2357) new playing state BUFFERING
    [17-02-22 16:46:20.2764] Slim::Player::StreamingController::_setStreamingState (2366) new streaming state STREAMING
    [17-02-22 16:46:20.8425] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -l "C:\ProgramData\Squeezebox\Logs" -x "C:/PROGRA~2/SQUEEZ~1/server" -i flc -o dsf $START$ $END$ $RESAMPLE$ $FILE$ --nodebuglog
    [17-02-22 16:46:20.8572] Slim::Player::TranscodingHelper::checkBin (275)    couldn't find binary for: lame
    [17-02-22 16:46:20.8573] Slim::Player::TranscodingHelper::getConvertCommand2 (443) Error: Didn't find any command matches for type: flc
    [17-02-22 16:46:20.9899] Slim::Player::StreamingController::playerTrackStarted (2180) 00:e0:4c:68:d1:46
    [17-02-22 16:46:20.9900] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PLAYING
    [17-02-22 16:46:20.9901] Slim::Player::StreamingController::_Playing (361) Song 0 has now started playing
    [17-02-22 16:46:20.9904] Slim::Player::StreamingController::_Playing (390) Song queue is now 0
    [17-02-22 16:46:23.6419] Slim::Player::TranscodingHelper::getConvertCommand2 (446) Matched: flc->dsf via: [C-3PO] -c $CLIENTID$ -p "C:\ProgramData\Squeezebox\prefs\plugin\C3PO.prefs" -l "C:\ProgramData\Squeezebox\Logs" -x "C:/PROGRA~2/SQUEEZ~1/server" -i flc -o dsf $START$ $END$ $RESAMPLE$ $FILE$ --nodebuglog
    [17-02-22 16:46:23.6567] Slim::Player::TranscodingHelper::checkBin (275)    couldn't find binary for: lame
    [17-02-22 16:46:23.6568] Slim::Player::TranscodingHelper::getConvertCommand2 (443) Error: Didn't find any command matches for type: flc
    [17-02-22 16:46:27.0839] Slim::Player::StreamingController::pause (2116) 00:e0:4c:68:d1:46
    [17-02-22 16:46:27.0845] Slim::Player::StreamingController::_setPlayingState (2357) new playing state PAUSED
    [17-02-22 16:46:27.0849] Slim::Player::Source::playmode (96) 00:e0:4c:68:d1:46: Current playmode: pause
    Qui c'è qualcosa di interessante:
    codice:
    Da te viene impostato C-3PO come transcoder ed in quel caso funziona (potresti anche verificare il log di C-3PO, volendo) mentre da me imposta il comando in lms (flac|sox), quindi socketwrapper e quindi il problema.
    Sicuramente c'è una differenza nelle impostazioni, probabilmente nelle capabilities impostate, riesci a farmi vedere l'impostazione della tabella dei comandi x come esce nel log all'avvio?
    Grazie.
    Ciao, Marco.
  4. #564
    Jan 2013
    codice:
    model:                  squeezelite
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           U => "END=-t %w",
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           U => "END=-t %w",
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           U => "END=-t %w",
    HTTP/1.1 200 OK
    Connection: close
Visite: 157
Dimensione:   79.4 KB
    SI, ammesso che quello sia l'unico lettore (però non mi spiego perchè ti presenti la tabella dei comandi 6 volte) NON sta usando le imposazioni di C-3PO, che prevedono di uscire in pcm da flac, quindi hai ancora attivo il comando in custom convert o altrove (porebbe essere dsdPlay). Dovretsi verificare in tipi Files.
    Il problema con dsdPlay è importante... Se si registra dopo c-3po, ne sovrascrive i settaggi per il player, l'unico modo è disabilitarlo (tanto non serve più).
    EDIT: no, non è DSDPLAY, o è il comando in custom-convet.conf o per player in sostituizione ai parametri generali di c-3PO.
    Tenere custom-convert.conf attivi in contemporanea a C-3PO (ma anche senza c-3po) provoca la sovrapposizione dei profili in funzione dell'ordine di caricamento dei diversi files, lo si può vedere attivando lo specifico debug.
    C-3PO è brutale e quando passa disabilita tutti i profili registrati prima di lui per il player ed i codecs interessati e li sostituisce, ma se qualcosa viene dopo di lui e fa la stessa cosa...
    p.s.
    hai certamente abilitato un debug sulle preferenze.
    Ultima modifica di marcoc1712 : 22-02-2017 a 17:16
    Ciao, Marco.
  5. #565
    Aug 2011
    Grazie.
    il log di LMS? riavviandolo?
  6. #566
    Jan 2013
    SI, o scorrendolo all'indietro fino a che non torvi qualcosa di simile a questo:
    codice:
    [17-02-22 14:38:36.5881] Plugins::C3PO::Plugin::_setupTranscoder (1335) commandTable: {
      "aif-dsf-*-e8:de:27:03:05:02" => {
                                         command      => "[C-3PO] -c  \$CLIENTID\$ -p \"C:\\Documents and Settings\\All Users\\Dati  applicazioni\\SqueezeboxTest\\prefs\\plugin\\C3PO.prefs\" -l  \"C:\\\\Documents and Settings\\\\All Users\\\\Dati applicazio
    ni\\\\SqueezeboxTest\\\\logs\" -x \"G:/Sviluppo/slimserver\" -i aif -o  dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "aif-dsf-*-e8:de:27:03:05:02",
      "alc-dsf-*-e8:de:27:03:05:02" => {
    ni\\\\SqueezeboxTest\\\\logs\" -x \"G:/Sviluppo/slimserver\" -i alc -o  dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "alc-dsf-*-e8:de:27:03:05:02",
      "dff-dsf-*-e8:de:27:03:05:02" => {
    ni\\\\SqueezeboxTest\\\\logs\" -x \"G:/Sviluppo/slimserver\" -i dff -o  dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "dff-dsf-*-e8:de:27:03:05:02",
      "dsf-dsf-*-e8:de:27:03:05:02" => {
    ni\\\\SqueezeboxTest\\\\logs\" -x \"G:/Sviluppo/slimserver\" -i dsf -o  dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "dsf-dsf-*-e8:de:27:03:05:02",
      "flc-dsf-*-e8:de:27:03:05:02" => {
                                         command      => "[flac] -dcs  --totally-silent \$START\$ \$END\$ -- \$FILE\$ | [sox] -q -t wav - -t  dsf -b 1 -  gain -h rate -v -I -b 90.7 -f 5644800  sdm",
                                         profile      => "flc-dsf-*-e8:de:27:03:05:02",
      "wav-dsf-*-e8:de:27:03:05:02" => {
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           T => "START=-s %s",
                                                           U => "END=-w %w",
    ni\\\\SqueezeboxTest\\\\logs\" -x \"G:/Sviluppo/slimserver\" -i wav -o  dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "wav-dsf-*-e8:de:27:03:05:02",
    Ciao, Marco.
  7. #567
    Aug 2011
    codice:
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           T => "START=-s %s",
                                                           U => "END=-w %w",
    codice:
    [17-02-22 17:22:08.0831] Plugins::C3PO::Plugin::_clientCalback (521) new ClientCallback received from
    mac address:            00:e0:4c:68:d1:46
    model:                  squeezelite
    max samplerate:         384000
    max dsd resolution:     256
    supported codecs :      mp3 alc ogg dff aif aac flc dsf wav
    [17-02-22 17:22:08.0882] Plugins::C3PO::Plugin::_setupTranscoder (1335) commandTable: {
      "aif-dsf-*-00:e0:4c:68:d1:46" => {
                                         command      => "[C-3PO] -c \$CLIENTID\$ -p \"C:\\ProgramData\\Squeezebox\\prefs\\plugin\\C3PO.prefs\" -l \"C:\\ProgramData\\Squeezebox\\Logs\" -x \"C:/PROGRA~2/SQUEEZ~1/server\" -i aif -o dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "aif-dsf-*-00:e0:4c:68:d1:46",
      "alc-dsf-*-00:e0:4c:68:d1:46" => {
                                         command      => "[C-3PO] -c \$CLIENTID\$ -p \"C:\\ProgramData\\Squeezebox\\prefs\\plugin\\C3PO.prefs\" -l \"C:\\ProgramData\\Squeezebox\\Logs\" -x \"C:/PROGRA~2/SQUEEZ~1/server\" -i alc -o dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "alc-dsf-*-00:e0:4c:68:d1:46",
      "dff-dsf-*-00:e0:4c:68:d1:46" => {
                                         command      => "[C-3PO] -c \$CLIENTID\$ -p \"C:\\ProgramData\\Squeezebox\\prefs\\plugin\\C3PO.prefs\" -l \"C:\\ProgramData\\Squeezebox\\Logs\" -x \"C:/PROGRA~2/SQUEEZ~1/server\" -i dff -o dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "dff-dsf-*-00:e0:4c:68:d1:46",
      "dsf-dsf-*-00:e0:4c:68:d1:46" => {
                                         command      => "[C-3PO] -c \$CLIENTID\$ -p \"C:\\ProgramData\\Squeezebox\\prefs\\plugin\\C3PO.prefs\" -l \"C:\\ProgramData\\Squeezebox\\Logs\" -x \"C:/PROGRA~2/SQUEEZ~1/server\" -i dsf -o dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "dsf-dsf-*-00:e0:4c:68:d1:46",
      "flc-dsf-*-00:e0:4c:68:d1:46" => {
                                         command      => "[C-3PO] -c \$CLIENTID\$ -p \"C:\\ProgramData\\Squeezebox\\prefs\\plugin\\C3PO.prefs\" -l \"C:\\ProgramData\\Squeezebox\\Logs\" -x \"C:/PROGRA~2/SQUEEZ~1/server\" -i flc -o dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "flc-dsf-*-00:e0:4c:68:d1:46",
      "wav-dsf-*-00:e0:4c:68:d1:46" => {
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           T => "START=-s %s",
                                                           U => "END=-w %w",
                                         command      => "[C-3PO] -c \$CLIENTID\$ -p \"C:\\ProgramData\\Squeezebox\\prefs\\plugin\\C3PO.prefs\" -l \"C:\\ProgramData\\Squeezebox\\Logs\" -x \"C:/PROGRA~2/SQUEEZ~1/server\" -i wav -o dsf \$START\$ \$END\$ \$RESAMPLE\$ \$FILE\$ --nodebuglog",
                                         profile      => "wav-dsf-*-00:e0:4c:68:d1:46",
    [17-02-22 17:22:09.4206] Slim::Player::TranscodingHelper::getConvertCommand2 (443) Error: Didn't find any command matches for type: unk
  8. #568
    Sep 2013
    custom convert non ce l'ho... avevo aggiunto direttamente in convert.conf. E quelli ovviamente erano abilitati. Ma pensavo che (ri)abilitando i relativi formati in C-3PO ne venisse fatto automaticamente l'override...
    io sto entrando in FLAC, non in dsf!
    ci ho messo "info".
    BTW: ho disabilitato tutto in "file types", quindi modificato e salvato la configurazione di C3PO, ed adesso in PCM ci va e suona.
    Ma se invece provo ad uscire in dsf, un disastro... trztztrtztrtztzz... mi stai facendo friggere i tweeter!
    questi i comandi generati:
    codice:
    squeeze+ 18444  0.0  0.0   4336   752 ?        S<   17:30   0:00 sh -c "/usr/bin/flac" -dcs --totally-silent -- - | "/usr/share/squeezeboxserver/Bin/x86_64-linux/sox" -q -t wav - -t dsf -b 1 -  gain -h rate -v -L -b 90.7 22579200  sdm -f sdm-8
    squeeze+ 18446 99.1  0.3 127100 15548 ?        R<   17:30   1:13 /usr/share/squeezeboxserver/Bin/x86_64-linux/sox -q -t wav - -t dsf -b 1 - gain -h rate -v -L -b 90.7 22579200 sdm -f sdm-8
    tra l'altro, vuole uscire sempre in DSD512, nonostante io lo abbia disabilitato!
    (tra l'altro, manca una opzione dove impostarlo... c'è solo la solita roba sul setup del player, ma serve una opzione nel setup generale!)
    Ciao, Paolo.
  9. #569
    Jan 2013
    codice:
    model:                  squeezelite
                                         capabilities => {
                                                           F => "noArgs",
                                                           R => "noArgs",
                                                           T => "START=-s %s",
                                                           U => "END=-w %w",
    Come pensavo, sono le capabilities. Buono a sapersi che così funziona, ma se abiliti lo stdin (per Qobuz) da me non funziona più, riesci a provare? (basta abilitare stdin per flac, poi mandagli pure un file, se hai ancora Qobuz e vuoi provare anche quello, meglio ancora).
    Ciao, Marco.
  10. #570
    Aug 2011
    funziona lo stesso, ma mi esce questa finestra che se la chiudo va in stop il play
    presumo per il fatto che ho attivato info in registrazioni...
    qobuz al momento non ho...mi riabboneró...e vediamo...
Pagina 57 di 115
