Overclock i7-980X + EVGA X58 3X SLI Classified (E760) Helpme!
    Elder
    Jan 2010
    Arbedo - Switzerland
    Predefinito Overclock i7-980X + EVGA X58 3X SLI Classified (E760) Helpme!
    Ho bisogno del parere di esperti per poter arrivare ad avere la CPU a 4GHz con il bus a 200Mhz (200 X 20) ma ho difficoltà a superare i 165Mhz di bus. Cosa sbaglio?
    Cooler: Noctua NH-U12P
    Scheda madre: EVGA X58 3X SLI Classified (E760)
    CPU: Intel i7-980X
    Ram: 3X2Gb Kingston HyperX KHX2000C9AD3T1K3/6GX
    Per ora ho raggiunto i 4Ghz con questa configurazione:
    Frequency Control:
    CPU Clock Ratio ( 27 )
    CPU Host Frequency (Mhz) ( 150 )
    MCH Strap ( Auto )
    CPU Uncore Frequency (Mhz) ( 3307Mhz { 22X } )
    CPU Clock Skew ( 0 ps )
    Spread Spectrum ( Disabled )
    PCIE Frequency (Mhz) ( 105 )
    Memory Feature:
    Memory Speed ( Standard )
    Memory Control Setting ( Enabled )
    Memory Frequency ( 1067Mhz / 2:8 )
    Channel Interleave Setting ( 6 Way )
    Rank Interleave Setting ( 4 Way )
    Memory Low Gap ( 2.5 )
    tCL Setting ( AUTO )
    tRCD Setting ( AUTO )
    tRP Setting ( AUTO )
    tRAS Setting ( AUTO )
    tRFC Setting ( AUTO )
    Command Rate ( AUTO )
    tRL ( +0 )
    Voltage Control:
    EVGA VDroop Control ( Without VDroop )
    CPU VCore ( 1.3375 )
    CPU VTT Voltage ( +325 )
    CPU PLL VCore ( 1.650 )
    IOH PLL VCore ( 1.350 )
    DIMM Voltage ( 1.65 )
    DIMM DQ Vref ( +100mV )
    QPI PLL VCore ( 1.40 )
    IOH VCore ( Auto )
    IOH/ICH I/O Voltage ( Auto )
    ICH VCore ( AUTO )
    VTT PWM Frequency ( 610 KHZ )
    CPU PWM Frequency ( 1333 KHZ )
    CPU Impedance ( Less )
    QPI Signal Compensation ( Less )
    CPU Feature:
    Intel SpeedStep ( Disabled )
    Turbo Mode Function ( Enabled )
    CxE Function ( Disabled )
    Execute Disable Bit ( Disabled )
    Virtualization Technology ( Enabled )
    Intel HT Technology ( Disabled )
    Active Processor Cores ( All )
    QPI Control Settings ( Enabled )
    QPI Link Fast Mode ( Enabled )
    QPI Frequency Selection ( 6.400 )
    OC Recovery ( Enabled )
    Turbo Performance ( Disabled )
    PnP/PCI:
    PnP/PCI (PCI Express)
    Maximum Payload Size ( 4096 )
    Power Management Setup:
    ACPI Suspend Type ( S3 )
    HPET Support ( Enabled )
    HPET Mode ( 64-bit )
    Saluti.
    Originariamente inviato da Dmanighetti
    CPU: Intel i7-980X
    Frequency Control:
    CPU Clock Ratio ( 20 )
    CPU Host Frequency (Mhz) ( 200 )
    MCH Strap ( Auto o 1600)
    CPU Uncore Frequency (Mhz) ( 16X )
    PCIE Frequency (Mhz) ( 100)
    Memory Feature:
    tCL Setting ( 7 )
    tRCD Setting ( 7 )
    tRP Setting ( 7 )
    tRAS Setting ( 21 )
    Command Rate ( 1 )
    tRL ( +0 )
    Voltage Control:
    CPU VTT Voltage ( +200 )
    QPI PLL VCore ( 1.25 )
    IOH VCore ( Auto )
    ICH VCore ( AUTO )
    CPU Impedance ( Auto )
    QPI Signal Compensation ( Auto )
    CPU Feature:
    Turbo Mode Function ( Disabled )
    Intel HT Technology ( Enabled )
    QPI Frequency Selection ( 4.800 )
    PnP/PCI:
    Saluti.
    Ciao se hai usato come base il template di sopra è impossibile arrivare ai 200x20.
    Ti ho messo in rosso con i valori corretti i parametri che probabilmente non ti fanno neanche fare il boot oltre i 165 di BCLk. In grassetto ho aggunto i valori che utilizzo io sulla mia macchina.
    Ho notato che spari tanti volt sul VTT, ma le cpu te le regalano?
    Che raffreddamento usi?
    Elder
    Jan 2010
    Beh il template era per arrivare a 4Ghz di cpu, visto che oltre i 165 non andavo ho preso un'altra strada.
    Se la cpu schiatta ci pensa poi mamma Intel .
    Raffreddamento rigorosamente ad aria.
    Grazie ora provo a cambiare le impostazioni.
    Saluti.
    . L'avatar di Hiwa
    May 2007
    CPU VTT Voltage ( +325 ) altissimo sono 1.52 metti +175
    per 200 di bclk metti 3600
    ciao caro
    Elder
    Jan 2010
    ciao caro
    Grazie maestro, effettivamente a 3600 regge senza problemi con bclk a 200.
    Peccato solo che questa Evga non sopporti le Avantium Leopard. Mentre andavano benissimo sulla Rampage II, con questa vanno solo in dual channel ed il bios ne vede solo 4Gb anche se poi Windows vede tutti e 6 i Gb installati, boh misteri delle ram.
    Ciao caro.
    Elder
    Jan 2010
    Predefinito Nuovo template
    Alla fine sommando gli aiuti ricevuti ho raggiunto i 3.6Ghz in questo modo:
    Frequency Control:
    CPU Clock Ratio ( 18 )
    CPU Host Frequency ( 200 )
    MCH Strap ( 1600 )
    CPU Uncore Frequency ( 3205Mhz { 16X } )
    Memory Feature:
    Memory Low Gap ( AUTO )
    tCL Setting ( 9 )
    tRCD Setting ( 9 )
    tRP Setting ( 9 )
    tRAS Setting ( 24 )
    Command Rate ( 1T )
    tRL ( +0 )
    Voltage Control:
    CPU VTT Voltage ( +175 )
    IOH VCore ( Auto )
    ICH VCore ( Auto )
    CPU Feature:
    PnP/PCI:
    Saluti.
    Moderatore L'avatar di MARCO74
    Mar 2007
    Ciao la 760 è molto rognosa per le ram prova ad installare un singolo banco per volta e fai il boot poi monta anche gli altri due banchi.
    Dum differtur, vita transcurrit. L'avatar di brugola.x
    hai provato ad alzare un pò il QPI?
    io il mio 975 lo tengo, in daily use a 165x25 (4125MHz) con mem a circa 990MHz (X12) e NBFreq a 3960 (X24).
    questi sono i voltaggi che applico
    Ultima modifica di brugola.x : 05-09-2010 a 16:30
    Elder
    Jan 2010
    Originariamente inviato da MARCO74
    Hai ragione, è peggio di una suocera con la rabbia e lo scorbuto eheh.
    Grazie per il consiglio, proverò a fare come dici.
    Saluti.
    Elder
    Jan 2010
    Vedi, il mio problema è che mi sono fissato di avere il bclk a 200Mhz. Ora con questa frequenza di bclk devo per forza tenere una frequenza del processore più bassa oppure rinunciare ai 200Mhz di bclk e tenere la frequenza del processore attorno ai 4Ghz con bclk fra 150 e 165Mhz.
    In poche parole non posso avere il panino ed il soldino...
    Saluti.
Attualmente 1 utenti stanno visualizzando questo thread. (0 membri e 1 ospiti)
  1. EVGA X58 3-SLI Classified - Intel X58
    By salvocan in forum -= MotherBoards =-
    Risposte: 13
  2. Vendo EVGA X58 Classified 3 SLI
    By pippo369 in forum -= Vendite : Hardware - Software =-
  3. Cerco EVGA X58 Classified 4-Way SLI
    By Dmanighetti in forum -= Acquisti : Hardware - Software =-
  4. vendo EVGA Motherboard EATX Intel X58 SLI Classified V S1366 141-BL-E760-A1
    By Spl in forum -= Vendite : Hardware - Software =-
    Risposte: 14
  5. Vendo EVGA X58 SLI Classified 760 141-BL-E760-A1!
    By dj883u2 in forum -= Vendite : Hardware - Software =-
Segnalibri
nexthardware.com
Testata Giornalistica iscritta al numero 2/2010 del Registro Stampe del Tribunale di Avezzano.
Direttore Responsabile, Giampietro Nonni
©2002-2012 - CREOInteractive s.a.s. - P.IVA 01576070666 - All rights reserved
Search Engine Optimization by vBSEO
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101
