aiuto scelta scheda madre per overclock!!!!
Pagina 2 di 2
1 2
Visualizzazione dei risultati da 11 a 14 su 14
    mebibyte
    Jun 2001
    quale sarebbe quello che porta il divisore a 1/5 a 166 mhz??
    il primo o il secondo?
    Nov 2001
    TV
    Il secondo.
    I've been running at CPU Clock set to 210MHz for almost 3 days to confirm it's divider is working. All my 3Com & D-Link NIC, as well as my Santa Cruz and Inno3D GeForce 2MX AGP Card are still working right now. If it has no AGP & PCI Divider, I am sure at CPU Clock = 210 MHz , all my cards would have been fried, because if there is no Divider, AGP would run at 210 / 2 = 105 MHz and PCI would run at 210 / 4 = 52.5 MHz. I don't think there's any PCI and AGP cards that can run at that high clock. So, in summary, In addition to the 3/4 DRAM Divider, AGP & PCI Divider are really working 100% good. The drawback is that at CPU Clock 210 MHz, I cannot connect to the internet using my Cable Modem. Lower it to 195 MHz did not help either. Only at CPU Clock around 178 to 180 MHz, can I connect to internet using Cable Modem. I hope EPOX will address this issue and fix it in the next bios revision
    Now I am back to my previous setting and HAPPY at CPU Clock 166 MHz WITHOUT DRAM 3/4 Divider set, so my PCI is at 33 MHz and my AGP is at 66 MHz.
    For now, this is the summary of AGP & PCI Divider:
    - CPU Clock at 100 to 120 MHz --> PCI Divider = 1/3 ; AGP Divider = 2/3
    - CPU Clock at 121 to 165 MHz --> PCI Divider = 1/4 ; AGP Divider = 1/2
    - CPU Clock at 166 to 199 MHz --> PCI Divider = 1/5 ; AGP Divider = 2/5
    - CPU Clock at 200 MHz & Above --> PCI Divider = 1/6 ; AGP Divider = 2/6
    Here's my prove, running at CPU Clock 210 MHz. The latest SiSoft Sandra Professional 1.11.8.53 wrongly detects the AGP & PCI Divider !!!
    My Specs
    Mobo: EPOX 8KHA+
    BIOS: 8KHAL00 dated 30 November 2001
    CPU: TBird 1.4GHz (AYHJA)
    HSF: Swiftech MC462A Rev1 + Delta 80mm 68 CFM
    HDD: 2 x Quantum Fireball AS 7200 RPM 40GB
    1 x Maxtor DiamondMax Plus 7200 RPM 46GB
    CDRW: Plextor 12/10/32A - FirmWare: 1.09
    DVDROM: Sony DDU1621 (16/40 X) - FirmWare: S1P5 (Region Free)
    Others: M$ Internet Keyboard Pro USB, Logitech Wireless Mouse USB
    NIC: 3Com EtherLink XL 10/100 PCI For Complete PC Management NIC (3C905C-TX), Compex RE100/WOL (using Realtek 8139 chipset)
    Graphic Card: Inno3D GeForce 2MX
    Driver: Detonator 12.40 - NATIVE Windows XP
    Memory: 2x 256MB Crucial PC2100 DDR + 1x 256MB Corsair XMS2400
    Soundcard: Voyetra Turtle Beach's Santa Cruz - Driver 4112 WHQL
    OS: Win XP Pro Final
    Case: Lian-Li PC-60 USB
    RAID Card: Chaintech ATA100-R (No Raid Array is set)
    Memory Setting DRAM Clock: 100 ; CAS 2-2-2-6-8-1T
    4 WAY Interleave ; VDIMM = 2.9 Volt
    mebibyte
    Jun 2001
    te quale mi consigli di prendere il primo o il secondo?
    pebibyte
    Catania
    Cross Posting!
    Quì chiudo!
Pagina 2 di 2
1 2
  1. aiuto scelta scheda madre
    By Wild79 in forum -= MotherBoards =-
    Risposte: 20
  2. Aiuto nella scelta della scheda madre
    By DJVegetas in forum -= MotherBoards =-
  3. Scheda madre...scelta finale.
    By seb87 in forum -= MotherBoards =-
  4. Scelta scheda madre Intel
    By Sniper in forum -= Overclocking e CPU =-
    Risposte: 17
  5. aiuto scelta scheda madre per overclock!
    By Leomeya in forum -= Hardware generico =-
    Risposte: 32
nexthardware.com
Testata Giornalistica iscritta al numero 2/2010 del Registro Stampe del Tribunale di Avezzano.
Direttore Responsabile, Giampietro Nonni
©2002-2012 - CREOInteractive s.a.s. - P.IVA 01576070666 - All rights reserved
