CARISSIMI AMICI DEL FORUM VORREI ESPORVI IL MIO PROBLEMA SE COSI SI PUO CHIAMARE:
INIZIO CON LA CONFIGURAZIONE AMD K7 900, SU ASUS K7V ULTIMISSIMO BIOS, CREATICE GEFORCE 32 DDR, 392 MB RAM 3X128, SOUND BLASTER LIVE PLATINUM, CONTROLLER SCSI AHA 2940 UW, HD IBM 20 GB, PLEXTOR 40X SCSI ABBINATO CON YAMAHA 8424 SCSI IL SISTEMA E BEN VENTILATO LE TEMPERATURE SON OK (PREMETTO CHE NON MI PIACE AVERE UN PC OVERCLOCCATO MA VOGLIO SOLO CARBURARLO SETTANDOLO AL MEGLIO) IL CONTROLLER SCSI E INSERITO NEL SECONDO SLOT PCI MENTRE LA LIVE PLATINUM NEL QUARTO VANNO BENE? ALIMENTATORE 300 WATT USO SIA WIN98 SE, CHE WIN 2000 PER MOTIVI DI LAVORO E SVAGO EHEHEHEH DRIVER VIDEO 5.30 CON RELATIVO BIOS DELLA GEFORCE AGGIORNATISSIMO,DIRECTX 7.1A VIA 4.22 AGP 4.03 ALLORA IN W98 LANCIANDO SIA PCILIST CHE WCPUID MI DICONO CHE HO L'AGP A 4X MA IL SIDE BAND ADDRESSING DISABILITATO ALLORA FABIO MI CONSIGLIA DI USARE AGPWIZARD LANCIO IL PROGRAMMA ABILITO IL SIDE BAND TUTTO OK MA APPENA RIAVVIO IL PC,IL SIDE BAND ADDRESSING SI DISABILITA AUTOMATICAMENTE ( PREMETTO CHE NEL BIO HO SIA AGP 4X CHE IL FAST WRITE SU ENABLE) MA PER ABILITARLO IN W98 HO DOVUTO AGGIUNGERE AL REGISTRO LA VOCE RELATIVA PER L'AGP 4X BOH! ORA POTRESTE DIRMI DOVE SI NASCONDE IL GUAIO?
CI SAREBBE UN'ANIMA GENTILE CHE ABBIA UNA CONFIGURAZIONE SIMILE MA SENZA STO PROBLEMA E MI SPEDISCA TUTTI I SETTAGGI DEL BIOS DELLA MB MAGARI SPIEGANDOMI IL SIGNIFICATO DELLE VOCI? COSI DA POTER SETTARE TUTTO ALLA PERFEZIONE? VI PREGO DI AIUTARMI A RISOLVERE STO PROBLEMA VISTO CHE QUANDO AVEVO INSTALLATO TUTTO ALL'INIZIO ERA OK POI AGGIUNGO CHE CON WIN 2000 L'AGP E A 2X TASSATIVO ED ANCHE LI IL SIDE BAND ADDRESSING E DISABILITATO NON CI STO DORMENDO PIU
RINGRAZIO ANTICIPATAMENTE TUTTI COLORO CHE VORRANNO AIUTARMI.
ALFREDOORSINI@TISCALINET.IT
PS. HO INSTALLATO TUTTO SEGUENDO QUEST'ORDINE WIN98 VIA 4.22 AGP 4.03 DIRECTX E DETONATOR 5.30 POI TUTTO IL RESTO.
LinkBack URL
About LinkBacks
Rispondi quotando
