Fidelizer - Programma di ottimizzazione audio per Vista/Seven
Like Tree1Likes
Visualizzazione dei risultati da 1 a 10 su 68
    Moderatore L'avatar di bibo01
    Oct 2010
    Predefinito Fidelizer - Programma di ottimizzazione audio per Vista/Seven
    Prendendo spunto da AA, segnalo questo nuovo programma per l'ottimizzazione audio di Vista/Seven.
    Promette bene
    Fidelizer will instantly turn your Windows Vista/7 computer to audiophile workstation for sophisticated audiophile player like J River, XXHighEnd, HQPlayer, foobar, etc. It involves no permanent modifications so system will remain safe and sound after restart so even system with normal Windows installation can experience better sound quality when needed. I'm still considering adding some useful permanent tweaks after this program is proven itself.
    Features:
    -Stop over 80 services leaving only audio related ones
    -Cutting edge core audio's thread, I/O priorities optimization
    -State-of-art clock rate and resolution adjustment
    After optimizing your system, most services related applications including network will stop running and some services may start again depending on running applications.
    Please leave your feedback and suggestions for better and more flexible software in future.
    You can download and test Fidelizer from Windows X's Live | Downloading Fidelizer Let me know if it helps anything in your system.
    assaggiatore di arancini
    May 2010
    Si conosce un dettaglio degli interventi?
    Oct 2010
    Originariamente inviato da Xfree
    Non dettagliato.
    Changes in version 1.1
    -Added autorun support (can be disabled by running program again without autorun)
    -Added believable selectable features instead of advertising features comment
    -Allowed user to keep specific services like networking and related interface controllers like HID and touch support
    May 2010
    Si, l'avevo avviato, però ero curioso di conoscere quali servizi andava a disabilitare e soprattutto quali tweak apportava al MMCSS.
    Comunque, quando avrò nuovamente la scheda audio lo proverò, anche se ho già un Windows 7 daily use parzialmente ottimizzato.
    Oct 2010
    La cosa interessante qui e' che fa queste ottimizzazioni on-the-fly, lasciando invariata l'installazione.
    Si possono avviarle in automatico allo startup oppure disabilitarle.
    mebibyte L'avatar di Massimo Bianco
    May 2009
    Ciao Gianluca.
    Hai avuto modo di provare l'efficacia del programma?
    Grazie.
    Ultima modifica di Massimo Bianco : 02-03-2011 a 19:13
    Massimo Bianco
    May 2010
    Si riavvia e torna tutto normale.
    exbibyte L'avatar di wasky
    May 2004
    Roma Vittoriosa
    Da provare ma, su installazione Fresca IMHO
    May 2009
    Perchè solo su un'installazione "fresca"?
    Massimo Bianco
    gibibyte
    Dec 2005
    Perchè non puoi provare le bonta di un programma di tweaking o del tweaking manuale se hai gia incasinato la macchina,si direbbe subito che il problema è il programma e non che l'utente è incapace
  1. Ottimizzazione Scheda Audio
    By bibo01 in forum cMP² = cMP + cPlay
  2. Tools di ottimizzazione per Windows Vista
    By parsifal in forum Microsoft Windows Vista
    Risposte: 24
  3. Posso far funzionare un programma a 32bit su vista 64bit???
    By SanDiego in forum Microsoft Windows Vista
    Risposte: 24
  4. audio basso con file video e audio su netebook con vista
    By liviu in forum Microsoft Windows Vista
    Risposte: 22
nexthardware.com
Testata Giornalistica iscritta al numero 2/2010 del Registro Stampe del Tribunale di Avezzano.
Direttore Responsabile, Giampietro Nonni
©2002-2015 - CREOInteractive s.a.s. - P.IVA 01576070666 - All rights reserved
